Question about Fujitsu P42XTA51US Television
How to connect my HP laptop to my fujitsu p42xta51
My laptop has HDMI & 15 pin-port. HDMI port o TV is available, that is not being used. not sure what kind of cable is needed to connect laptop to the RS-232C or RGB1 INPUT TERMINAL ON TV
  • 1 more comment
  • LINDA LATTANZIO Jan 25, 2013
    oh my laptop is a HP Pavilion m6 notebook .
  • LINDA LATTANZIO Jan 26, 2013
    had hdmi connector issues- taken care of now --> everything working fine. thank you.
    driver with laptop wasn't working- fixed that & everything is ok.
3 Suggested Answers
  • 32 Answers
SOURCE: I have a Fujitsu p50xha40us and the HDMI stopped
You may have a fault on the main digital PCB, failing that, check that the HDMI connector is not damaged. If you need further help then call Fujitsu General 020 8 731 34322
Brads
Posted on May 31, 2010
SOURCE: hi I bought a second
I also have the same problem. I think maybe getting an electrician out is our best bet. The cables and connections are so confusing. Hopefully you manage to sort your tv out. It may be an s-video cable that you need. I think I may try that.
Emma
Posted on Mar 02, 2011
Fujitsu P42xta51: Does my fujitsu have ATSC tuning
Yes, the P42XTA51U has an ATSC (digital OTA) tuner. This is given in the specifications for the Fujitsu 51 Series TVs. That document is available here: http://www.hdtvsolutions.com/Fujitsu-P63XTA51US.htm . The direct link to the specifications sheet is http://www.hdtvsolutions.com/pdf/ht_tuner_brochure.pdf . Fujitsu had to include an ATSC tuner because the TV was manufactured in 2005. U.S. law required TVs over 36" have an ATSC tuner starting in 2005.
If you use the appropriate antenna, you'll be able to watch OTA broadcasts. I recommend checking with TVfool.com for antenna suggestions and the angle between your location and the transmitters. ( antennaweb.org assumes an external antenna but is very conservative in the list of available stations.)
I hope this helps.
Oct 30, 2015 | Fujitsu Plasmavision 42" TV
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
I have a 60" Mitsibishi TV and I am trying to
When your notebook computer is connected to an HDMI device, you may encounter certain display and sound issues. For example, if you have your notebook computer connected to an LCD TV and/or surround sound speakers with a high-definition multimedia interface (HDMI) cable as part of a home theater system, you may encounter some common HDMI display and/or sound issues such as the following: If you are experiencing one of the following issues, click the link to go directly to a section of this document for a resolution. If you are experiencing an HDMI display or sound issue that is not listed above, please contact HP for assistance. Set HDMI sound output c02654744.gif Make sure that HDMI device is enabled and selected. To make it the default sound playback device, select ATI HDMI Output and then select Properties . The HDMI cable must be connected when it is configured. Use correct HDMI cable for your HDMI device There are three types of HDMI: 19-pin (normal head), 19-pin (small head), and 29-pin. If your computer and HDMI device use different cable types, adapters are available. For more information, see HP Notebook PCs - Overview of HDMI and DVI Connections for PCs . Content protected error message If you are playing an HD DVD on your notebook computer while it is connected to an LCD TV with an HDMI cable, you may see an error message that reads, The content is protected. The content is not allowed to be played in current mode. This error sometimes occurs when single mode settings are selected. To resolve the issue, click to accept the message when prompted, and the movie will play. images do not display properly When the notebook computer is in HDMI mode, images sometimes are distorted or do not display at all. To resolve this issue, use the HP Support Assistant to test your computer and install any updated drivers. Alternately, download and install the latest NVIDIA GeForce driver from your model from the HP Software & Driver downloads page . For more information about downloading and installing drivers for your HP notebook computer, please see the Locating HP Software, Drivers, and BIOS Updates in Vista support document. Surround sound option is unavailable First, confirm that your notebook recognizes HDMI audio by right-clicking the Volume icon in the Windows system tray and selecting Playback Devices . If you do not see HDMI Output then you may need to reinstall or update your audio drivers. Also, make sure your notebook's BIOS is up-to-date. When using WinDVD to play a movie after selecting HDMI as the default audio output, the surround sound option may be unavailable. To resolve this issue, please update to WinDVD version 9.0 or later at the HP Software & Driver downloads page . If you are using the MediaSmart program, make sure you are using the latest version. For more information about downloading and installing software updates for your HP notebook computer, please see the Locating HP Software, Drivers, and BIOS Updates in Vista support document.
Oct 04, 2011 | Computers & Internet
What type of cable do I get to connect presario 900 laptop to TV?the
You can use either an HDMI cable or a VGA cable to connect your computer to your TV. Your computer has both HDMI and VGA ports. You can use either ports but you cannot use both or else your video card will crash.
Thank you for visiting FixYa! have a nice day!
Apr 27, 2011 | HP Compaq Presario CQ60615DX Notebook
How do you connect a mac to an HDMI device and can you get sound to the tv ?
Hey, you would need a Mini display to HDMI cable and unfortunately the sound cannot be ported through the mini display port.
Mar 14, 2011 | Apple Customized 15" MacBook Pro Laptop...
Can I connect my Toshiba NB 205 to my TV to watch etflix movies? the netbook has a VGA out, and the TV has S-cable and HDMI inputs. Thanks!
Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Microphone - Input - Mini-phone 3.5 mm , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 3 x Hi-Speed USB - 4 pin USB Type A
The above interfaces are in your laptop. There is no S-cable or HDMI interface.
If your TV have VGA port you can connect your TV to the VGA port in laptop. This will alow you to convert the TV as monitor.
May 31, 2010 | Toshiba Computers & Internet
I have a Dell computer that runs Windows Vista and I want to hook it up to use my TV as a monitor to watch a webcast. Please advise.
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
NEED MOre HELP check this link for video :
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Jan 20, 2010 | Computers & Internet
What cable do I need to connect latitude D600 to a hdtv ?
*S-Video
Nov 22, 2009 | Dell Latitude D600 Notebook
Notebook connection to tv
S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
Dec 26, 2008 | HP Pavilion dv6000z Notebook
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
Fujitsu P42XTA51US Television Logo
24 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
