Question about Watches
Coleman watch is on but cant change the time
I changed the battery abd it work for a couple days. Now I cant change the time
    Genius:
  • Watches Master
  • 1,669 Answers
Try this site:
http://www.ehow.com/how_8204646_set-date-coleman-watch.html
Posted on Jan 21, 2013
  • 4 Answers
SOURCE: changing time-for day lights saving time on watch
A. Press and hold MODE until HOURS digits flash (you’ll be in Alarm Mode). Press MODE again
to enter TIME mode. SECONDS digits will flash.
B. Press ADJUST to set SECONDS to zero.
C. Press START/STOP to select MINUTES.
D. Press ADJUST to change.
E. Repeat to set HOURS, MONTH, DATE, and DAY of WEEK. Go through 12 hours to set AM
or PM.
F. Press MODE when done.
Posted on Nov 08, 2008
  • 3 Answers
SOURCE: cant remember how to change (hands) time on casio fishing gear
Push the MODE (down left) bottom six times, you will see in your display HS then push the ADJUST bottom (up left) until your digital time start to flashing then push the SEARCH (down right) bottom the hands time will start to move, once you have set the time you want push the ADJUST bottom (up left) once and push the MODE (down left) once and you done.
Ricardo DeLeon
Posted on Mar 12, 2009
SOURCE: change day
The trick is to turn the ring to the "Date" setting, Pull the stem out once for the Month and Date. Pull the stem out (hard, but gently) a second time for the Day of the week. Each pull will be confirmed by a 'beep. Be persistent and good luck.
Posted on Mar 30, 2009
  • 2501 Answers
SOURCE: coleman watch Model No. 40-328 How To change from 24 to 12 hour
I couldn't find the instructions for your watch but as watches tend to have similar operating characteristics, try this:-
Press the mode button until you come to a message that says something like "12hr" or "24hr" or something that indicates display change.
Then press one of the two buttons on the right to change to the display you require.
Some experimenting may be required!
Posted on Feb 03, 2010
  • 2501 Answers
SOURCE: Blue Angels Skyhawk Watch for Him: cant figure out how to change the time...
You can get instructions by going to http://www.citizenwatch.com/COA/English/settings.asp.
Fill in the required details and download instructions.
Posted on May 06, 2010
Coleman watch 40-747. Changed battery (not totally dead), now nothing. How do I "reset" so it will begin working again. Nothing in manual - just a tiny paper inside the watch.
Check to confirm the new battery was installed with + side up, then follow the directions shown on the piece of paper.
Jul 06, 2016 | Watches
I have timex expedition watch model T49664 with altitude. It works well for last 3 years then battery died. Twice i change CR2430 even once in timex showroom. But the battery dies in 15 days. Plz help
After changing the battery press and hold all the buttons at the same time to reset this will make the watch and battery works properly so that the battery wont drain easily. I hope I have been helped you.
Nov 09, 2014 | Watches
I have a Coleman digital watch. Four button. I replaced the battery and need to reset the time and date.
Click on your watch model number to open the instruction sheet below.
Your model number is located on the caseback of your watch
go here> http://www.gsi-usa.com/instructions/
Aug 16, 2014 | Coleman Mens Digital Dual Time Sport Watch...
Watch erratic. Slows suddenly between days of working well.
Sounds like a failing battery to me. Its very common for a watch to loose time when battery needs to be changed.
Jan 09, 2010 | Timex Watches
How do I set time etc on a coleman sports watch, have manual but doesn't make sense, it's model 40-408
The watch has four buttons. The lower left button is labeled MODE on the face of the watch. There are four modes and pressing the MODE button will step through each mode until you return to the mode at the start of the process. Start at the "Normal" timekeeping mode and press the "MODE" button three times until the digital display rightmost two figures for seconds flash.
Press the lower right button labeled RESET until the item you want to change is flashing. Pressing RESET cycles through seconds, minutes, hours, day, month, day of the week in the top sub-dial and then back to seconds again.
When the item you want to change is flashing press the top right button labeled START to step the displayed item to the value you want. When you are satisfied all the settings are correct, press the lower left button marked MODE to return to normal operation.
Coleman 40-408 User's Guide
Nov 03, 2009 | Bulova Watch
Regarding my Citizen Eco Drive E870-5017891
Well.. if your watch is automatic (battery not included) you have to take care of that watch like avoid hard shock like the watch fells from a hight etc . secondly is your watch operate on battery there much got weak or your watch hand alignment is out in this case you must get your watch to there service center and this is not a serious problem they won't charge you much for this problem ..i hope that i helped you
Aug 25, 2007 | Citizen 8700 BL8000-54L Wrist Watch
Watches Logo
166 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
