Question about Enterasys Matrix V2 (v2h124-24p) Networking Switch
Enterasys v2h124 reset - Enterasys Matrix V2 (v2h124-24p) Networking Switch
Where can I find latest firmware?
googling enterasys ap3640 firmware update may yield useful results
Aug 09, 2014 | Enterasys Networks Enterasys AP3640...
Not connect from console port
Verify that the correct settings and cable/connectors (rollover cable, correct COM port specified) are being used when establishing the console connection.
From the manual-
3.9.2 Connecting to an IBM or Compatible Device
To connect an IBM PC or compatible device, running the VT terminal emulation, to an
Enterasys Networks module Console port (Figure 3-20), proceed as follows:
1. Connect the RJ45 connector at one end of the cable (not supplied) to the Console port on the
Enterasys Networks module.
Connecting to Console Port for Local Management
Hardware Installation 3-31
2. Plug the RJ45 connector at the other end of the cable into the RJ45-to-DB9 adapter (supplied
with the device).
3. Connect the RJ45-to-DB9 adapter to the communications port on the PC.
4. Turn on the PC and configure your VT emulation package with the following parameters:
Parameter Setting
Mode: 7 Bit Control
Transmit: Transmit=9600
Bits Parity: 8 Bits, No Parity
Stop Bit: 1 Stop Bit
source: Install Guide for Enterasys 1H582-25 / 1H582-51 (http://www.retrevo.com/support/Enterasys-1H582-51-Switches-manual/id/2785dj098/t/2/)
Jun 22, 2011 | Enterasys MATRIX E1 (1h582-51-g)...
How can i reset the password of my switch if lose it?
There should be a reset button on the back, that will remove everything on it. You will need a pen or sharp object to push down the reset button.
Mar 01, 2011 | Enterasys C3G124-48P 48-Port Gigabit...
How i can reset the password in a enterasys C3G124-48, if lose it
Before trying anything too drastic, I'd try using the username "admin" without the quotes and leaving the password blank. If that doesn't work, then you'll have to use the reset switch that's located on the back of the switch (number 1 in the pic below). nickmyers46.jpg
The following steps are taken from the manual for the switch.
1. Press-and-hold the reset switch while the switch device is operational. This change of the login password to the default password will be indicated through CLI only.
2. Logon the device management. You can now logon to the switch through the console port and assign a new password using the command line interface (CLI).
Password recovery
You can only reset to default. Download here the manual and follow the instructions (Reset Switch)
http://secure.enterasys.com/support/manuals/hardware/4099_05.pdf
Oct 10, 2009 | Enterasys C1H124-48 Networking Switch
CAn I use Enterasys serial module for the RS?
Which serial module do you have? Is it a cabletron or enterasys-branded one?
Apr 14, 2009 | Enterasys Riverstone RS 8000 (G80-CHS)...
Enterasys Matrix V2 (v2h124-24p) Networking Switch Logo
Top Enterasys Computers & Internet Experts
George Nalley
Level 1 Expert
Marcin
Jax Planet
Jax Planet
Are you an Enterasys Computer and Internet Expert? Answer questions, earn points and help others
