Question about Syntax SV266AD Motherboard
Need a manual for reconnecting power supply to motherboard
I JUST BOUGHT A NEW POWER SUPPLY FOR MY COMPUTER. AND I NEED A MANUAL TO SHOW HOW TO RECONNECT THE CABLES.
  • 32 Answers
You should have a big 20/24 plug that will connect on the motherboard right next to the CPU. Then take the molex plugs (the little plastic 4 holed connectors) and plug them into your CD drives and hard drives. The floppy plug should be a little white hard plastic plug.
Posted on Jul 19, 2007
SOURCE:
I just bought aThermaltake TR2 700w power supply I need to know how to connect to gateway DX4885 (LGA1150)
You need to get your Gateway owner;s manual and look at the motherboard description.
I your case the DX4885 motherboard uses a proprietary 12 pin power connector, and you cannot use the Thermaltake power supply with it.
If you are attempting to upgrade this machine so you can do gaming, etc. (presumed from your choice of a 700W psu), then give it up and buy a different computer. This Gateway was built with proprietary parts to be cheap as possible.
Here is more on the power connector, which includes instructions to modify the power cables of a standard ATX Power supply -which I do not recommend that you do yourself- take it to a knowledgeable technician. Odd motherboard power connector
Jul 03, 2014 | Computers & Internet
My old power supply had 4 wires going to the front panel on\off switch. The Dynex power supply does not support the switch. what do I use to turn the unit on or off. Will the unit function with out the...
Normally the front panel on/off power button and the front panel reset button plug into connector pins on your motherboard.
If you can find a User Manual for your motherboard it will show you exactly where the switch leads plug in on the motherboard. The motherboard's manufacturer and model number will be printed on the board somewhere.
Good luck.
Feb 05, 2011 | Dynex DX-400WPS 400-Watt Power Supply
I bought a new power supply - how do I replace it? Can I get step by step instructions?
there are 4 screws ont he back of th computer usually remove thsoe but unplug power first then disconnect the cords from your drives and the motherboard put that power supply out of the way with your new power supply reconnect everything put the new one where your old one was and boot it up this model might have a caddy remove the caddy and check for the supply support screws
Dec 13, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
I have a problem with my pc it will not boot up it starts to boot then just turns off I cant get and diag done to troblem shoot the problem PC specs Win XP sp3 3gb ram DDR2 Celeron D...
now, this sort of shut down is difficult to diagnose on remote, i would suggest downloading your motherboard manual beforehand. before you do anything, i would suggest read in manual where is reset pin and how to reset bios to original state, but do not do that yet, it will lost all your mods settings and return m/b - bios to original state. there are several possible causes of that fault.
1. faulty memory stick
2. thermal or fault on power supply
3. thermal or fault on motherboard
4. corrupted bios
we will start with easiest to check re 1.
a. switch off your computer,
b. remove power cable from power supply,
c. remove side wall,
d. remove memory sticks and replace them with known working ones from another computer
e. reconnect power supply and switch computer on, if computer works correctly, you solved your problem and need to replace memory sticks
power supply is not much more difficult re2.
c. remove power supply cables from motherboard and all accessories, do not remove power supplly from it's craddle yet
d. connect cables from new power supply to your motherboard and processor fan, connect them to your hdd and cdrom,
e. connect power cable to new power supply and start your computer, if computer run correctly, switch it off, remove old power supply and replace with new one
most tiddly bit... when you arrive here that meant that previous two did not solved your problem, re 3:
c. disconnect all cables from your m/b
d. connect power supply to m/b and processor fan
e. connect ps2 keyboard
f. connect monitor if "all in one" m/b, video card and then monitor in any other case
g. insert power cable to power supply
h. switch on your computer
i. acess bios (that is usually done by tapping "delete" key, find in your manual) if possible, if not then:
i1. switch off power supply
i2. remove power cable from power supply
i3. re-set bios (you need to locate reset pins/switch/button on you motherboard in manual)
i3. reconnect power supply cable \
i4. switch on the computer
j. acess bios and set your thermal to 75centigrade or 80 centigrade and 5min
k. close bios saving changes
l. re-boot your computer and leave it for 10min, if computer still run, that will indicate your problem lies elsewhere.
checking auxiliaries:
c. connect cd-rom
d. reinstall power cable and re-start your computer
e. allow 10min run and check if computer is still running
switch off. remove cable and connect your hard disk drive, run or switched off? if off, you need to check your hdd...
any other auxiliaries need to be connected again in steps and if finaly you find one which terminated boot up, this meant that this particular element is responcible and need replacing. you need as well consider that your power supply maybe perfect on the bench, but will be too small for load required adn simple upgrade to more powerfull mother board can solve the problem.
hope that half book on problem solving solve yours :-)
Jul 30, 2010 | Computers & Internet
My hp a1632x will not turn on nothing! the green led is lit on the power supply. the supply was checked with a checker and show good. pulled each plug on drives, memory, etc and reconnect power each time...
The power supply can still be good however, if the connection on the motherboard has fried then you need a new motherboard or a new computer which would be your decision.
Sep 27, 2009 | HP Computers & Internet
Old power supply no good. bought this dynex 400 watt atx cpu power supply and need to know how to connect wires as there are some plugs that can go in multiple spots.
as long as you have the 20 or 24 plug in and the 4pin square plug in plus the hard drive dvd floppy fans i donot no your motherboard or graphic card so i cannot say anymore only next time write down your conections before removing power supply or get manual for your pc
Jul 30, 2009 | Dynex 400-Watt ATX CPU Power Supply
Hp pc m7640n won't turn on and power supply light is out
OK, this can be a hard thing to fix. Most of the time, the power supply is the first thing to go on a PC. However, when you stated that the motherboards LED came on after you unpluged the PS from the motherboard, it leads me to believe that the motherboard is the issue but the power supply might be outputting higher voltages and the motherboard might be shutting down. Since the power supply is cheaper then most motherboards, I would recommend getting a new one. Check ebay for a new power supply. It should be about $20 with shipping. If the same thing happens, then you need a new motherboard...
May 30, 2009 | HP Pavilion m7640n PC Desktop
Issue with a In Shin Power Supply
ok, the part # is not the model # . I need the MODEL # of the board to help U .
Dec 30, 2007 | Computers & Internet
Motherboard
Well you really need to get a manual for that. Check the website and download the manual with that model, for sure there is one.
I guess you have connected all the connectors there incorrectly so better look for a manual.
Dec 09, 2007 | EliteGroup ECS 755-A2 Motherboard
My motherboard BIOS is not starting
look for the CLRCMOS or CLR or JBAT1 terminals. These are the cmos settings and may need to be cleared, so refer to your motherboard manual for which one you have. Although what has probably happened is that when the PSU blew it may well have shorted the cmos chip which cannot be repaired, or damaged the graphics.
Apr 12, 2007 | Intel SuperMicro SUPER Motherboard - 810...
Open Questions:
See all Syntax SV266AD Motherboard Questions
Syntax SV266AD Motherboard Logo
222 people viewed this question
Top Syntax Computers & Internet Experts
Ekse
Robert Salgado
Robert Salgado
Eric Sutherland
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
