Question about Yamaha Audio Players & Recorders
Yamaha CR-620 receiver has no audio. The lights on signal meter and other meters are on, but no audio. Recently, after turning on the power, the audio would come on as much as 20 minutes after powere
CR-620 receiver.
3 Suggested Answers
SOURCE: Yamaha R-700 Natural Sound Stereo Receiver won't turn on.
My stereo receiver aiwa MX-NH2000 can not turn on. It has standby.
Posted on May 06, 2010
  • 73 Answers
SOURCE: I have a 70's era Yamaha Natural Sound Stereo
If there is no audible physical click from the speaker output relay, after about 10 to 20 seconds, there is an electronic fault in one or both amplifier circuits, which will require repair. If you like the sound of this unit enough to pay maybe $50 give or take, get it repaired. Otherwise, you can pick a similar unit up at a thrift shop for a few dollars.
Posted on Aug 29, 2010
Realistic STA-2270 Stereo Receiver
The pivot that balances the fm signal meter has jammed, it would have to be taken apart, the outer lens removed to attempt a repair, this is a very tricky operation, if you hit the receiver on the side nearest to the meter, the needle should move back and forth freely,"indicating the meter is good" but if it fails to move the mechanical part of the meter is faulty.
Apr 14, 2012 | Marantz 2270 Am/fm Stereo Receiver
I have a 70's era Yamaha Natural Sound Stereo Receiver CR-620. It just recently stopped working. It turns on, but doesn't transit sound. Can it be fixed or is it terminal?
Aug 29, 2010 | Yamaha Audio Players & Recorders
Alinco DR-635. On two meters, there is no received audio.
I think your 2M section has a dead FET in the receiver front end. The FET transistors are bad about being destroyed by ESD, as they are not gate protected. This is a repair shop job, unless you are very good with repairing surface mount technology. The 635 is a good rig, well worth the repair costs. Consider using a factory repair shop, to get the job done right. There is an Alinco group on Yahoo Groups, join them and ask where to send your radio for repair. They will know who is reliable enough to trust your treasured radio to for repair.
Good Luck,
Longshorts.
Jul 06, 2009 | Radio Communications
Yamaha CR-820 has no FM
You have to connect an external antenna to the FM ANT. terminals on the back of the receiver.
Jun 28, 2009 | Audio Players & Recorders
I have a Yamaha CR-820 unit and cannot receive an FM signal. AM is fine. Also the FM meter reads as no signal. Please help.
If I remmber correctly, the FM section is a couple of ICs (LAxxxx or LCxxxx). I will look this up when I get back to my shop. Check in the tuner area for a coupld of 14 pin ICs. Check for 12V or 5V in the area and look for poor solder joints in the area as well.
Let me know what you find. I'll post back with additional details.
Dan
Jun 28, 2009 | Yamaha Audio Players & Recorders
May 03, 2009 | Yamaha Audio Players & Recorders
Reciever shut off AND WILL NOT TURN BACK ON
Sounds like it could be a major problem. But...It could be as simple as a fuse.
Do you know how to use an Ohm Meter or a Multi Meter??
If not, there is still something you can check, if you feel comfortable taking the thing apart.
1. Power it down.
2. Open it up, and look for blown fuses.
3. You can't always tell by looking...especially if the are "Slow-Blow" fuses.
4. If you know how to use a multi meter, you can check the fuses in place.
4a. You have to turn it on.
4b. Put your multi meter on VAC. Put the probes on both sides of a fuse. If you measure no voltage the fuse is good. If it measures voltage, the fuse is bad. (I know it sounds backwards, but a meter only measures the difference between voltages, and a good fuse will have the same voltage on both sides, hence no voltage)
4c. Replace bad fuses.
5. If you are uncomfortable with the powered on method, you can remove the fuses, ONE AT A TIME, (so you don't get confused...no pun intended), with POWER OFF. A fuse puller is a useful tool. If you don't have one, BE CAREFUL!
5a. Put your multi meter on Ohms. Measure resistance across the fuses. If resistance is real low (like less than 4 ohms), the fuses are good. If the resistance is high (like 1k to infinity), the fuse is bad.
I hope this helps.
Good Luck!
Apr 08, 2009 | Yamaha HTR-6030 Receiver
Power Issues
The part was $8 plus shipping to new york was $11
Aug 18, 2008 | Yamaha RX-V995 Receiver
My pioneer deh-1900 mp will not turn on
did you use a wire harness adapter or did you connect the wires from the radio directly to the wires in the car? do you have a computer safe test light or a digital vom meter? do not use a conventional test light in this car or an analogue meter to check for power
Feb 09, 2008 | Pioneer DEH-1900MP CD Player
57 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
