Question about Toshiba Satellite A75-S226 Notebook
No power to LCD, drives after power jack repair
I'm past the repair of the power jack that gave intermittant power to the laptop only when jiggled and then only for moments. I've de-soldered and re-soldered a new power jack; now have power light on at all times and even able to charge the battery. Problem: although there's power to USB ports, the cooling fans run at boot up, nothing appears on LCD; DVD drawer and hard drive don't seem to be receiving power. Removed hard drive, memory and DVD yet no response in the form of beeps or messages on LCD.
(Toshiba Satellite A75-S226)
  • acharlie2 Jan 27, 2009
    Didn't think it was the mobo because the unit fired up okay prior to repair...except for conking out w/the loose DC jack. Anyway,I may have shorted something but don't know how using the techniques I used. Thanks anyway.
    acr
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
It would appear that you need to dis-assemble the laptop again and check:
  • if the solder job on the new powerjack covered other solderpoints other than the pins of the jack;
  • for any solder balls, solder splash on some of the other components. This could have been brought about when the jack was de-soldered;
  • loose/mis-aligned connectors;
  • wires/cables kinked or crimped when putting back the brackets/casing.
Pls post back result(s). Good luck and kind regards.
Posted on Jan 27, 2009
    Master:
  • 505 Answers
The problem is with the motherboard. Get it checked or replaced by a qualified technican.
Thanks
The input on the laptop where i stick the charger inn isn't working, what do i do?
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop
Oct 09, 2010 | HP 6530b Notebook
My elitegroup laptop was no power at all, then the pin positive is shorted to pin negative
DC Jack diagnosis:
8. When you are done, re-assemble back the laptop.
Oct 09, 2010 | EliteGroup G320 Notebook
My acer aspire 3680 could not power on by bat and adaptor
DC Jack diagnosis:
Oct 08, 2010 | Acer Aspire 3680 Laptop
My LG R400 laptop has a bad charging port.how do i repair it
DC Jack diagnosis:
Oct 04, 2010 | LG Computers & Internet
Cannot power up or charge battery. Power supply is working. Does the power receptical commonly break from the motherboard?
DC Jack diagnosis:
Oct 03, 2010 | HP Pavilion ze4420us Notebook
Acer 5570z will not boot up or turn on
It could be one of the following:
1. Bad/damaged power jack.
2. Bad motherboard.
DC Jack diagnosis:
Sep 26, 2010 | Acer Aspire 5570-2067 Notebook
Computer will not power up. No problems before Turning off
2. Bad motherboard.
DC Jack diagnosis:
Sep 26, 2010 | Toshiba Satellite A215-S4747 Notebook
Not working dont get power in motherbord
Sep 23, 2010 | Acer ASPIRE 3680-2022 Notebook
MY LAPTOP WORK ON BATTRY BUT CAN NOT WORK WITH ADEPTOR
Sep 12, 2010 | Lenovo Computers & Internet
Laptop Backlighting Goes Off Intermittently
It's hardware. You'll have to check:
inverter
lcd
lcd backlight
lcd cable
It's one of the four.
Jun 15, 2009 | HP Compaq nx9030 Notebook
Toshiba Satellite A75-S226 Notebook Logo
79 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
