Question about Sony Cyber-shot DSC-H5 Digital Camera
I have a problem with the flash on my Sony DSC H5 in auto setting. It pops up and flashes ALL the time regardless of light.
In the automatic setting it pops up and flashes all the time regardless of light.
    Genius:
  • 1,019 Answers
Possible censor fault but it could be worse if the flash was not working at all.
Posted on Jan 25, 2013
  • Carl Belken
    Carl Belken Apr 20, 2013
    Thanks, I was thinking the same thing but as it turned out all I neeed to do was reset the camera. Thansk
Gort007
  • 1187 Answers
SOURCE: Sony DSC-H3 Flash wont pop up automatically
Your flash setting is on "Manual".
[Menu]
[Flash]
Use the "arrows" to change from manual to automatic.
Posted on Oct 01, 2009
SOURCE: Sony DSC-F828 Faulty Flash
Try resetting the camera. It is next to the battery release. I had a similar issue and posted help. No remedey. So, after praying about this issue, I was lead to power it down and eliminate all the power by taking out the battery push the power button and many others. I found the reset button pushed it and it is all working now. The praying for a solution was key. Praise Jesus. DRD
Posted on Jul 03, 2009
  • 41 Answers
SOURCE: Flash problems
As you haven't said which shooting mode the problem occurs under (e.g. Auto, Scene etc) I can only suggest that you try different shooting modes to gain access to changing the Flash settings. Hope this helps.
Posted on Apr 29, 2008
SOURCE: Flash stopped working on Sony Cybershot DSC-H10
What a coincidence. Even my camera is 14 months old & I too have exactly similar problem.
Can some one throw some light on this pls??
Posted on Dec 21, 2009
welcomejee
  • 10594 Answers
SOURCE: DSC H-5 the flash pops up but does not flash,
Flash pops up shows that flash release mechanism is working as camera wants to flash.
There are 3 thick wires connecting between flash bulb and flash charging circuit in camera, one of thick wire seems internally broken and causing problem.
Camera will be apart to check wires.
Let me know, if you are willing to apart camera, for further help.
Thanks.
Posted on Dec 31, 2009
Sony Cyber-Shot DSC-P73 Digital Camera suddenly flash is not working
The flash may be broken.
If not these are the flash settings on the camera in case a different flash mode has been set accidently.
Set the mode dial to [camera icon], and press [up arrow] on the control button repeatedly to select a flash mode.
The flash mode has the following features.
No indicator (Auto):
The camera decides to use the flash based on lighting
conditions. The flash will be used when
there is not enough light or when shooting a
subject against a light source.
(Forced flash):
The flash will be used regardless of the amount of ambient light.
(Slow synchro):
light. In this mode, the shutter speed is
slower under dark conditions, so you can
clearly shoot a background that is out of the flash-lit area.
(No flash):
The flash will not be used.
Oct 18, 2014 | Sony Cyber-Shot DSC-P73 Digital Camera
My sony cyber-shot DSC-H10 flash stopped working. The flash pops up like it is going to work, but does not flash. I can take pictures but with noflash. Can you help me?
You flash is in ' Flash forced OFF ' position.Press on the flash control button repeatedly until one of the four modes are selected.
1.Flash Auto - Flashes when there is insufficient light or backlight ( Default Setting )
2.Flash forced on
3.Slow synchro - The shutter speed is slow in a dark place to clearly shoot the background that is out of flash light.
4.Flash forced off - ( Your current mode ).The flash automatically pops up and strobes when using the flash.Close the flash by hand after use.
Jun 03, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
I have a Sony Cyber-shot DSC-W90. When I try to change the flash settings, a notification pops up on the screen saying, "Flash settings cannot be changed." I tried setting it in each mode (including Auto)...
Go to Menu/ Home and initialize camera to reset it for factory default settings to fix flash light settings bug.
If problem still not solved, let me know do you see any error code flashing in top right corner of lcd?
Aug 24, 2010 | Sony Cyber-shot DSC-W90 Digital Camera
DSC H-5 the flash pops up but does not flash, camera is set to automatic mode and flash is turned on.
Thanks.
Dec 31, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
[Menu]
[Flash]
Oct 01, 2009 | Sony Cybershot DSC-H3 Digital Camera
How do I turn my flash on--I have a sony cybershot DSC HF camera! Thanks!
Do you mean a DSC H5? If so, at the top of the control button there should be a symbol that looks like a lightning bolt with a arrow on the bottom. Push that to go through the various flash settings.
You can get the manual here:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSC-H5&region_id=1
The 'Read This First' file is a quick guide to using your camera and is also available on that page. And, if you didn't mean H5, then you can change the model.
Aug 01, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Can't change flash settings to Sony Cybershot DSC-H10 camera
Glad ur problem solved !
kindly rate my response WELL in system
Regards
Zohail
May 28, 2009 | Sony Cybershot DSC-H3 Digital Camera
Shutter button popped off & I am out of warrenty.
You can replace it DIY. Here is a link show you how to replace the button and where you can get the parts.
How to replace the shutter button on SONY CyberShot DSC-H5 digital camera
Mar 17, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Sony cyber-shot dsc-h3 flash problem
http://www.avforums.com/forums/digital-cameras-photography-photo-editing/826916-sony-dsc-h3-flash-wont-open.html
Sep 04, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Blurred picturew when using the flash
Move picture Mode Dial to Auto settings (Green color mark) and try again.
Jun 11, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony Cyber-shot DSC-H5 Digital Camera Logo
87 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
