Question about PANDIGITAL Tablets & eReaders
How do i reset a previously owned Pandigital R70G100 to use apps?
I purchased a used Pandigital Tablet & eReader, but i'm unable to use any internet apps. Also, should I be able to access Google Play Store?
SOURCE: Cannot access Appslib app library
I couldn't either! So, I uninstalled the appslib and reinstalled it and it works great now! You have to reset everything and you will lose apps I guess if you have any, I had none so this didn't affect me. If you go to Coby's website and under FAQ's it explains how to uninstall and install. Good luck!
Posted on Dec 31, 2010
  • 242 Answers
SOURCE: pandigital novel 7" WHITE ereader wont turn on.
You can try pressing the reset button with a straightened paperclip of pin. If that doesn't do anything removing the back and unplug the battery. Leave it unplugged for a minute or two and reconnect it. Be careful unplugging it as you don't want to put to much force on the wires. You can use a small screw driver or tweezers to pry on the plug. The white plug here is what you're locking for. See if it powers on and hopefully it does. If not you may have to contact Pandigital.
Hope this helps
Ray
Posted on Mar 12, 2011
SOURCE: How do I set up and receive email on Pandigital
Welcome to FixYa! To set up your yahoo email: 1.Type in yahoo email and password, 2. Select done 3. Then look for manual setup, select imap account. Make sure user name and password are right.
  • imap server is imap.mail.yahoo.com, port is 993, security type is ssl always. Click next.
  • smtp is smtp.mail.yahoo.com, port is 465 security type is ssl always. Click next.
4. Choose how often you want it to check for new mail, name account, setup signature, select done. It should have a refresh tab, select it and your all setup.
Or you could just go to www.yahoo.com in the web application of your e-reader and then logged into your email from there. Thank you for using FixYa! Have a nice day!
Posted on May 20, 2011
Mustgo
  • 2359 Answers
SOURCE: My pandigital ereader won't connect
I rare case,the wifi module can disconnect for it socket.
It's usually cause by mishandling the unit.
If it's under warranty then you should send it in for repair.
====== The DIY method is to power off the unit.
Place a large soft towel on a table.
Place the display face down.
Apply GENTLY pressure (side to side and top to bottom) on the back of the unit.
PLEASE apply pressure gently!!!!!!!!!
With some luck,you will press the wifi card back into its socket.
Posted on Sep 11, 2011
edgedev
  • 81 Answers
SOURCE: How to reset Pandigital 7 in. Planet Tablet to
There are two ways to do it. You can either update the firmware and it will erase everything for you, or you can do a factory reset, and return to factory settings. Go to Settings, PDN settings (not the Android settings menu) and scroll right to the Reset Defaults location. Tap on the reset button and you will be taken back to factory default settings. It might take a while to reload, but after everything it will be back to factory defaults from when you first bought it. Updating the firmware might be your best option if you care to resell it, because it may cause less issues for the next person and less chance of any returns.
Posted on Oct 17, 2011
I need to download the Google App Store in my Pandigital 7" Tablet (4.1). I keep getting an error that says the browser is no longer supported. Is there a secret or an update I need to run?
You need to search for a guide to install manually the GAPPS (google apps & services) on your tablet. Many low cost tablet are provided with no play store and other services. But it's not difficult!
Nov 02, 2015 | PANDIGITAL Tablets & eReaders
I have a Pandigital Supernova tablet. I am having trouble accessing google play? Does my tablet support it? It has a 2.3 Android app launcher.
there are detailed instructions on android tblet forum.com. it's possible but takes time to get it right, estimated exp. level semi pro..do able...
Jun 16, 2014 | PANDIGITAL SuperNova
I have a pandigital black novel tablet And I And unable to download any apps and all my apps have been erased. And my sd card is not working b c when I try to download a app It tells me that I dont have...
Tablets have internal storage and external SD cards (optional) storage. Apps will download to the internal storage. So under Settings > Storage make sure you have space on your internal storage.
Dec 30, 2012 | Tablets & eReaders
How do i reset my tablet when it's locked?
Disconnect the power source for few minutes then reconnect.
Feb 24, 2012 | PANDIGITAL SuperNova
How do i go about replacing my pandigital,can't charge it
Contact the supplier for help it's better. Or they may change a new one to you if it's in warranty.
Android 4.0 Tablet PC
Feb 07, 2012 | PANDIGITAL Digital Book 843967071153...
How to reset pandigital planet tablet
There should be a small hole to stick a paper clip into to do a reset,press it gently til it reboots
Oct 17, 2011 | PANDIGITAL Digital Book 843967071153...
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
Tablets & eReaders Logo
Top PANDIGITAL Tablets & eReaders Experts
brian soufane
mega_mind
Are you a PANDIGITAL Tablet and eReader Expert? Answer questions, earn points and help others
