Question about LG Vu CU920 Cellular Phone
LG PHONE STUCK ON EMERGENCY DOWNLOAD
HOW DO U GET UR PHONE OFF OF EMERGENCY DOWNLOAD?
  • 4 more comments
  • Aroeoner Feb 07, 2009
    phone is stuck on emergeny download
  • jack_821 Feb 09, 2009
    Phone is stuck on Emergency download. Have taken the battery out several times and still on.
  • Anonymous Feb 10, 2009
    stuck on emergency download screen wat do i do?
  • Anonymous Mar 07, 2009
    just got it TODAY! went to emergency download, dont know how to fix it....help?
  • Anonymous Mar 25, 2009
    stuck on Dload
I had the same problem!! This might help: 1. Take out the battery, SIM card, and memory card (if applicable). 2. Let the phone sit in the sun for a couple of days. 3. Put the SIM card back in the phone and plug the phone charger into the phone. 4. When prompted, insert the battery into the phone 5. When battery is fully charged, remove the charger and depress the call button simultaneously.
I tired this and the phone is now working!!! Also, I do not seem to have lost any of the features!
Good Luck!!!
Posted on Mar 09, 2009
  • amarti2493 Mar 09, 2009
    Oh, I last thing: DO NOT EVER turn the phone off!!! You'll end up with the same problem...............
I HAD THE SAME PROBLEM SO AS POSTED BY PREVIOUS MEMBERS, I TOOK OUT THE BATTERY AND SIM CARD. I THEM USED A BLOW DRYER INSTEAD OF PUTTING IN THE SUN AND BLOW DRIED INSIDE THE PHONE, THE SIM AND BATTERY. ONCE I PUT THEM BACK IN I IMMEDIATLY PUT IN ON THE CHARGER AND THE EMERGENCY NOTICE WENT AWAY. IT MAY HELP TO NOTE THAT I HAD DROPPED IT IN SOME WATER WHICH IS WHAT MAY HAVE TRIGGERED IT. THE BLOW DRYER TOOK ALL THE MOISTER OUT FROM INSIDE INCASE I COULDNT SEE ALL THAT WAS WET. GOODLUCK!
Posted on Oct 02, 2009
I was charging my lg phone on my laptop so i decide tu download some music i unplugged the phone and then plugged it back and a window on my laptop appeared to dowload and lg site so the computer can...
You have bricked your phone by disconnecting it while it was updating. Emergency mode is the safe mode of phones, you should never disconnect your phone while it is updating or transferring files.
Apr 28, 2011 | LG GT540 Cell Phone
Charged phone last night... this morning there's an "Emergency Download" LG message
is the message from ur network service provider or else from lg people if its from lg then it should be of something important why dont u put the message here so that more clear answer can be provided
May 23, 2010 | LG Vu CU920 Cellular Phone
I dropped it in the water but it was barely wet.
em , what i think there is a firmware problem ! so u will need to see an expert of have a look for the software online download it and install it on ur phone nd it should be fine ! hope i have be helpfull
Mar 08, 2010 | LG Vu CU920 Cellular Phone
I dropped my lg vu in water how do i fix it...it's stuck on the emergency download screen
fill a freezer size Ziplock bag with rice and leave the battery cover off and no battery installed but in the bag with the phone and leave it for 2 days. it may work! let me know..
Sep 30, 2009 | LG Vu CU920 Cellular Phone
What am I to do when the screen says "Emergency Download"??? My phone is an LG Vu.
i have an lg vu , when things like this happen i call 611 , which is the number to coustumer care. they do troubleshoots on ur phone! dont exsperiement with your phone at this point just call. when i exsperimented my phone shutdown and i had to get a new one ! :)
Aug 16, 2009 | LG Vu CU920 Cellular Phone
After water damage worked for a month now says emergency download
you have probably oxidized system board of phone, put it to service, they should clean it
Jul 11, 2009 | LG CHOCOLATE VX8500 Cellular Phone
I'm stuck on the yellow screen thats says "refreshing"
This could be a software or a hardware fault. If you recently changed the firmware or made other modifications to the file-system using EFS Explorer (or similar software), it may well be software related.
If you think the problem may be software related, try using Emergency Download mode to reflash your phone.
Possible faults to check with the hardware include:
  • The battery is empty, damaged or worn out. Try taking the battery out and connection your phone using the USB cable only.
  • The contacts of the battery are damaged or the battery has leaked.
  • The screen may be damaged and will not display a picture - check if the lower buttons light up when the End Call (Red) key is pressed.
In the case of a hardware fault or if you are unsure, contact the store from where your purchased your phone on for advice on the best action to take.
Emergency Download Mode __________________________________________ What is Emergency Download Mode? Emergency Download Mode allows you to connect your phone to your computer and use flashing tools (e.g. LGDMP) to restore or change your firmware.
_________________________________________________________
How do I access Emergency Download Mode?
  1. Make sure your phone is off.
  2. Hold down the Green (Call) + C (Delete) + Red (End Call) + Image Stabiliser (Lock) buttons
  3. Your phone should turn on and go straight to a screen saying 'Emergency Download' without first showing the usual LG Logo.
  4. You can now connect your phone using the USB cable and use Flashing tools to fix your phone.
_____________________________________________________________
Use the EFS explorer mode and check the maps.
If there is a map named TOTO and a map LGAPP.
First rename the map LGAPP in to any name you want or change
it like this AAAA.
Secend Rename the map TOTO to LGAPP.
Delete the first map you renamed the LGAPP.
When your finished choose disconnect and wait until the process is done.
You will see the phone starts up in a normal mode if not then
you've to reflash the phone.
I hope this will helps.
May 25, 2009 | LG KU990 Viewty
Emergency download
  1. put out aku
  2. wait till dispear the "Emergency download"
  3. than put in aku
  4. new  open it
Feb 16, 2009 | LG KU990 Viewty
Emergency Download/LG
mine does too i took battery out then back in it worked but now it syas that again. charge it up
Feb 27, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG Vu CU920 Cellular Phone Logo
6,124 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
