Question about Microwave Ovens
The part that holds the door switches inside the oven is broken; can the part be replaced
  • Microwave Ovens Master
  • 17,129 Answers
Yes this can be stuck using a instant glue if the broken pieces can be found. Usually this needs to hold the switch and lock in alignment.
So try this out , you can remove the front panel and get access to this assembly.
Posted on Jan 22, 2013
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Microwave NN-T785SF Door switches are broken.
Oddly enough, the switch holder is called a "door hook". For this model, it is part # F3020-1200 in case that is bad.
The hook assembly that protrudes from the door is called the "door key".
If you gently push up on the door key there should be spring tension. If it just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door key or the inner door panel.
If it's the door panel,it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door key is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the attached photo)and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts for this brand is Tritronics. Or you can call them toll-free at 866-779-5835. Their Web site will be down until Jan. 2nd.
Posted on Jan 01, 2009
MNfisherman
  • 11896 Answers
SOURCE: hook broken that holds rack inside oven. can this
You should be able to get a replacement from partselect . com or repairclinic . com
Some have screws and some are held with adhesive.
Posted on Jul 26, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: I have a MMV4205BAB mounted
Unfortunately on this model you would have to replace the whole door.
You can find handy exploded views and order parts by model number here.
Posted on Dec 18, 2010
Testimonial: "You answer verified what I already suspected. Thanks."
Door spring latch broken - how to repair
Inside side of door there are screws that hold glass like a sandwich between outside side and inside side of the door. They are usualy fastened with screws. You have to unscrew and take a part to remove broken latch to replace it with new part.
If you need additional info how to get parts for appliance please do not hesistate to contact me thru this site.2d04cfd.jpg
Feb 21, 2010 | Panasonic NN-T964SF Microwave Oven
Power to back of oven going in and out of the oven but nothing happening not even the clock is coming on. please help.
Hi
Thanks for using FixYa. When microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 13, 2010 | Belling Microwave Ovens
No power to microwave
Hi
When your microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 14, 2009 | Microwave Ovens
Turntable keeps turning
This is usually caused by either a bad door switch, a loose door switch mount, or a sometimes problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please reply back here if you still need help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | GE JVM1440 Microwave Oven
Microwave oven - Amana Model MVH220E
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Jun 19, 2008 | Amana MVH220E Microwave Oven
Oven doesn't work
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
Jun 11, 2008 | Frigidaire GLMV168K Microwave Oven
2000 HR Endeavor "over the range microwave oven"
It may be a loose or broken door switch mount or possibly a bad switch.
I have attached (via e-mail) our safety, disassembly & door switch files.
Essentially you make sure it's *unplugged*, then remove the outer cover.
Then you can see inside behind the control panel where the door latches go into the chassis.
Just opening and closing the door a few times while observing closely will show you where the problem is.
I stock these switches and I can send you one for $6.00, or you can get one from a local appliance parts store, or some hardware stores and home centers like Home Depot or Lowe's.
Once you've looked all this over, please let me know if I can help further.
May 30, 2008 | Sharp R-1405 / R-140 Microwave Oven
Oven will not work unless I push on the door
It's probably a broken tab on the dooir switch mount or a screw holding the door switch mounts is loose.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find an exploded view and order parts by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can also order Sharp parts from Tritronics at http://www.wehaveparts.com
Dec 06, 2007 | Sharp R-1480 Microwave Oven
Smasung MW7490w door/turntable problem
It's probably a defective door switch, probably the upper one, or the mount which holds the switch is broken. Opening the door while cooking (without first hitting the STOP button) is the primary cause of door switch failure. There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door. The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly. Usually it's not a loose screw, but instead a broken tab on the switch holder, allowing the switch to rotate just out of position.
Sep 23, 2006 | Samsung SMH7159 Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
