Need codes where can i find them
To set up the volume control on your virgin remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
TV Codes
Akai 0236, 0544, 0630
Alba 0037, 0065, 0246
Amstrad 0205, 0440, 0065
Bush 0246, 0263, 0377
Decca 0064, 0100, 0544
Ferguson 0101, 0363, 0221
Fidelity 0244, 0221, 0460
Finlandia 0374, 0387, 0236
Goodmans 0065, 0064, 0100
Granada 0379, 0387, 0391
Grundig 0563, 0582, 0515
Hinari 0037, 0064, 0065
Hitachi 0253, 0384, 0377
JVC 0681, 0081, 0122
Matsui 0263, 0205, 0037
Mitsubishi 0136, 0382, 0064
NEI 0065, 0365, 0459
Nokia 0508, 0501, 0576
Panasonic 0678, 0254, 0278
Philips 0584, 0065, 0040
Saisho 0039, 0205, 0263
Samsung 0065, 0584, 0037
Sanyo 0236, 0073, 0100
Sharp 0121, 0064, 0065
Sony 0533, 0038, 0039
Tatung 0065, 0100, 0544
Thomson 0363, 0653, 0137
Toshiba 0536, 0063, 0271
If I have not listed your make of TV in the table above,
1. Press to go to the Home Screen.
2. Choose Telewest Services.
3. Choose Technical Assistance.
4. Choose TV Control Codes.
5. A full list of TV brand codes will appear.
If the volume control is still not working after trying all the codes for your TV model, or your TV model is not listed, then your TV is not compatible with our remote control and you will need to use your TV remote to control the volume as normal.
You can also use your TV remote control to adjust the volume in the normal way. Good Luck
