Question about Garden
Toro lawn mower 22 in 149 cc 6.75 - Garden
3 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: Racing of a Honda 160 CC lawn mower engine
When a small engine "surges" in all speed ranges the possible causes are:
*Dirty air filter
*Water or contamination in the fuel system.
*Breaks in the spark plug wire (leaking), loose or corroded terminal connections causing an intermittent failure.
*Misadjusted or malfunctioning governor.
Problems with surging only when under load or at idle are likely caused by carb blockage or misadjustment.
Hope this helped and good luck to ya!
Posted on Jul 20, 2009
rwvanlue
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
Toro Model 20070 lawn mower starts and runs, just does not seam to have a lot pf power does anyone have a lack of power issue with their Toro 20070 Pace Lawn mower. Runs fine just no balls
could be dirt in the carby , blocked fuel filter or lack of adjustment in the accelerator cable
I will go for a cable adjustment as they slip under the clamp on the carby bracket when the throttle is pull wide open
May 30, 2016 | Toro Power Lawn Mower
How to clean a toro lawn mower carbeurator
Hi Blair, The link below is a youtube video showing how to clean your toro lawn mower carby, Also there's video's down the right side of the link that will help as well............CHEERS..
Clean out Toro lawnmower carburetor jet
Apr 27, 2016 | Toro Garden
Toro 6.75 hp mower, 149 cc. Kohler motor. How do I remove carburetor to clean?
Don't remove the entire Carburetor, just unbolt the Bowl from under the carb.
12mm wrench maybe
Jul 01, 2013 | Garden
Have a Toro Personal Pace 190 cc electric start mower. About 18 months old. Battery can be fully charged but it only seems to start it about every third or fourth time. Pulling the cord starts it every...
battery or cable problems
When using the battery , there is insufficient power left to run the ignition system
when pull starting what is in the battery is sufficient to start the engine
Feb 20, 2018 | Toro Lawn Mower With Toro Power Tools
Toro lawn mower
ethaanol in fuel...happens when gas sits too long...especially in a gas can in the garage
Apr 10, 2010 | Toro Lawn Mower With Toro Power Tools
Toro lawn mower wont start
pour alittle gas in carburator & then try starting see what happen if it starts & then dies then you have a carburator problem
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
Mower runs very rough
Sounds like a bad diaphragm in the carburetor.
Jim
Sep 28, 2009 | Toro Lawn Mower With Toro Power Tools
Need to replace pull string on lawn mower
how do i change the pulling string on my toro 22 recycler
Jun 13, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
1,084 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
