Life smart 1500w infrared heater turns on than shuts off shortly after it heats up.
When you turn on the heater it will run till it warms up than it shuts down shortly after it starts heating , like a breaker due to too much heat, once it cools down you can hear it reset & you can turn it back, to watch it do it again.
  • 4 Answers
SOURCE: Heat turns off
Sounds like the high limit switch on the heater is kicking off. The flash is the switch shutting off the heating element. The only way to reset it is to turn unit off for about 5 minutes. Possible problems are: 1.) Bad thermostat 2.) blower motor not turning fast enough which means motor is bad.
Posted on Oct 13, 2007
SOURCE: 2000 watt baseboard heater is making loud clicking noise
Most base board heaters installation instructions say to attach to the wall with screws which are slack ( not fully tightened) in order to allow the heater case to expand and contract otherwise you get a clicking noise
Posted on Oct 31, 2008
SOURCE: Electricity cost per hour
1500w / 1000w = 1.5 kwh. Every hour you run (assuming it is at 100% peak power) you use 1.5 kw. Just multiply that rate by how much it your power company charges per kwh.
Estimating high at 10 cents per kwh it would be $1 for every 10 hours you run the heater, or $2.40 per day, or about $72 per month if you ran it 24/7 for 30 days.
It is FAR cheaper to use these types heaters to heat one small room than an entire apartment or house if you are only in one room the majority of the time.
Posted on Jan 15, 2009
SOURCE: hyundai accent stops running after heats up
I had the exact smae problem and threw aaway a ton of money on bad "guesses" at what was wrong. The actual fix was replacing the crank shaft position sensor for 50 or 60 bucks. Swapped out bad for good and cars has run great every day since.
  • 360 Answers
SOURCE: Maytag MDBH970AWS Heating element won't turn off
The heater relay is located on the control board, a faulty relay or a faulty control board would cause the problem you have described. The fix is to replace the control board. Parts for your unit should be available from most appliance parts retailers, if there is not one local to you, the part is available at www.apliancepartspro.com. along with an exploded view of your unit
Hope this helps.
please take the time to rate this solution
Posted on Mar 05, 2009
Turns on for 1 minute and gets Er - I cleaned filter
It may be getting too hot and activating the safety shut off. This may need a new board. I have never worked on one of these but it has to be fixable. Depending on the cost of the unit as to whether or not it is worth it.
Mar 04, 2016 | Duraflame Powerheat 1500W Infrared Quartz...
Heater Shuts Off after 2-3 minutes
Does it matter if the thermostat is 120v or 250v?
Jan 31, 2014 | Lifesmart Renew Infrared Quartz Heater...
Heater runs 1 cycle then turns off
Replaced 301 80C 16A thermostat, purchased on ebay for $6.00, fixed problem. to Fix standing at front, Remove left side panel, two small screws hold thermostat in place. LifeSmart wants $36.00 for same part. Fixed problem.
Oct 18, 2013 | Lifesmart Renew Infrared Quartz Heater...
I had heat before i change the thermostat what happened?
You may have trapped air in the coolant system. Take off the radiator cap, turn heater control to high heat, and run the engine till it is fully warmed up and the thermostat has opened. Then shut off car and replace radiator cap after topping up coolant. Heater may work now. Good luck.
Feb 10, 2013 | Cars & Trucks
Tips on how to fix a Life Smart LS-500-1PC Infrared Heater
The above fix is NOT for a Life Smart LC-500-1PC.. this is Life Smart LC-500-1PC. http://lifesmartproducts.com/current-products/infrared-heaters/52-2011-products/332-ls-500-1pc.html
Sounds like the thermostat is out. Order one, and hope it comes with a repair manual!
Dec 27, 2012 | Reddy Heater-30-55,000 BTU Variable
I have life smart infrared heater 1500w. when power source on. turn power button on and set temp. unit runs and blows warm air for about three to five mins then shuts off. can restart with power button but...
The thermostat needs to be replaced. The Company sent the replacement part for free. The also said they would send the instructions to fix it, but they did not. I am looking for instructions online. ;-(
Nov 17, 2010 | Heating & Cooling
Dec 12, 2008 | Lasko Ceramic Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
