Question about Whirlpool LGB6300 Gas Dryer
Drum won't stop turning when door is open - Whirlpool LGB6300 Gas Dryer
    New Friend:
  • 169 Answers
Sounds like a faulty door switch.
Posted on Jan 22, 2013
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
Cabrio washer door won't open!
if you plug it back in.... set at any cycle it should release then unplug asap. the aggitor/drum belt is what you are smelling.
Feb 14, 2018 | Whirlpool WTW5700XW Cabrio HE Washer
How do you replace the door switch in a Kenmore 70 Series 68702 electric dryer?
What is the model number of your unit? Look inside the door area.
Nov 19, 2012 | Dryers
Aeq6000 won't turn off
This has to do with the control board failure. The control board runs every aspect of the dryer and will need to be replaced. Here is the new control board.
Oct 20, 2012 | Frigidaire AEQ6000ES Electric Dryer
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
Does not turn off when door is open
The image below shows the wiring diagram for your model of dryer. The door switch is shown in the closed position. When the door is opened, the contact is broken that completes the neutral circuit through the door switch. (I am not showing that your model of dryer has a drum light. If it did, then the drum light would illuminate when the door is opened.)
Based on your symptom, a bad door switch is apparently causing this problem. It is not breaking the neutral circuit to stop the motor from running. Replacing the door switch assembly should fix this problem. NOTE: Be sure to unplug the dryer before accessing any internal components.
Apr 16, 2012 | Kenmore Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
My dryer will heat but won't turn, I replaced the Dryer motor but it still doesn't turn. The door switch works fine, when I push the start button it clicks like normal and when I open the door I...
Have you looked for a belt on the drum of the dryer? Mine has a motor but it is attached to a wheel that turns large belt that extends around the drum.
Oct 03, 2017 | Roper Dryers
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
Whirlpool LGB6300 Gas Dryer Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
