Question about Dryers
Dryer will not turn off in Automatic mode
The Timer does not advance in Automatic Mode So I am believing that it is the operating thermostat but where would that be location be on this model?
    President:
  • Dryers Master
  • 2,651 Answers
Look to a faulty/clogged/blocked vent befoer switching partsno your machine. nost common fault for too long to dry on auto-- or wont advance on auto dry is innadequate venting
Posted on Jan 27, 2009
Dryer timer will not advance in any mode.. timed, or auto mode. Dryer works, but will not turn off unless you open door or advance timer. Do I need to replace the timer?
the timer will need to be replaced if it's stuck in the mode as you stated. the timer is built with cog teeth gears that rotate slowly as the timer operates normally. If a cog tooth breaks off the timer is stuck in that position causing your problem here
Jul 11, 2011 | Whirlpool LEB6200 Electric Dryer
I recently installed a thermal cut off and high limit thermostat on a whirlpool ler5636kq1 dryer. It was the kit that you had to cut and crimp the wires to the thermostat and I followed some step by step...
I believe there is a sensor below the vent screen, it has two screws and may be covered with lint or fuzz from the dry sheets. I would take apart and gently clean and see if this fixes the problem, Good Luck Tim
Feb 05, 2011 | Whirlpool Dryers
I have the exact same problem. Would not heat so I replaced the thermal cut off and high limit thermostat . Now the timer won't work properly. Did you find a solution?
Feb 05, 2011 | Whirlpool LER5636P Electric Dryer
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
Dryer won't shut off automatically
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Thank you!
May 09, 2010 | Maytag MED5800TW Electric Dryer
Why is the dryer not turning off
Hi, If your dryer seems to run forever and doesnt turn off, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Apr 15, 2010 | Roper REX4634KQ Electric Dryer
Tumble dryer will not dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 19, 2009 | Dryers
May 20, 2009 | Dryers
Kenmore 11070702990 Gas Dryer - Timer does not work
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Gas dryer wont trun off after drying
May 08, 2009 | Dryers
Dryers Logo
Top Dryers Experts
