Question about Frigidaire Affinity ATF7000ES Front Load Washer
Bad wax motor in door lock assy. Where I can buy just wax motor?
Have a Frig. front load washer M# ATFB6000ES0. Sets code E47 (Thinks door not locked) Wax Motor checked open first time. Removed, opened, reassembled, checked again @ 1587 ohms. Later at 1890 ohms. (Should read approx. 1500 ohms) Suspect heater in motor flaky. Also, output driver chip on main control board that energizes heater reads a high resistance short. (225k ohms) Should be infinite resistance across common and out pins. I have a sourse for replacement chips to fix main control board but hate to buy whole door lock assembly if Wax Motor is available somewhere. This machine is only 2&half years old!
Do you know where I can buy just the wax motor??
Thanks, Bob
    New Friend:
From what I found it looks like if you want new, you'll have to purchase a whole door latch assembly. BUT ebay is a wonder and I got mine for $28 bucks. Otherwise you'll have to salvage and hope that the part is in good condition.
Posted on Jan 09, 2013
  • 65 Answers
TRY WWW.MARCONE.COM OR WWW.SEARS.COM UNDER PARTS. IT WILL GIVE YOU AN EXPLODED VIEW OF THE LATCH.
Posted on Jan 27, 2009
My fridgidaire model #LTF2940ES3 is giving me an error code E47 what is this
Very likely the problem is a bad door lock. It is very common problem with Frigidaire front loaders. You have to measure the resistance of the wax motor in the door lock assembly (the orange piece on the right side of the picture). I don't know why Frigidaire call it PTC. Very confusing. The normal reading should very close to 1500 Ohms. Otherwise verify all wires from the door lock assembly to the control board and, if everything is fine, replace the control board.
showpartimage.aspx?forumimg=ap4455026
If the door switch is bad, replace with this part.
If the control board is bad, replace with this part.
Oct 15, 2012 | Frigidaire ATF6000ES Front Load Washer
Maytag Neptune front loader door latch won't release
rewpa, 98% chance the door latch has stuck in the locked position. Yes, follow Maytags suggestion to access the "rip cord" for the door latch... (this is the mechanical override for it) to get the door open. After it's open, run another load of wash and see if it happens again. If it does, it is the door latch assy. that's the problem. BTW, the door lock light is activated by a switch in the door latch assy. There's a "motor" in the assy... it's made of WAX! Yes, a "wax motor". Before the computer goes into spin, it sends 120V to this motor. The electricity heats the wax and it expands. As it expands, it pushes a plunger forward. This plunger trips both the door lock AND the switch. This sends the signal to the door light AND the computer saying "I'm locked! Go ahead and Spin!" When the cycle is complete, the computer drops the voltage to the wax motor. The wax cools off and contracts. This retracts the plunger... opening the door and shutting off the light. So... if this light stays on, the plunger is still extended and can be overridden using the rip cord. If this happens again, let me know and I'll step you through disassembly and replacement of the wax motor.
Aug 18, 2007 | Maytag Neptune MAH5500B Front Load Washer
LTF2940ES E47 code repair
The E47 error code is usually an indication of a failed door lock/latch. To verify this, you will need to ohm out the PTC on the door lock. If the door lock does not ohm out correctly, then it will need to be replaced.
How to test the door latch on your washer
Nov 18, 2011 | Frigidaire ATF6000ES Front Load Washer
My machine wach but do not spin a the end.
Note: This solution is intended only for asker qualityisc as per Live Chat session discussion. Error code reads E47 which means the Control board thinks the PTC circuit (wax motor) is open.
Unplug the machine then remove the spring-loaded wire loop that holds in place the front of the bellows over the lip of the door opening in the front panel.
Using needle nose pliers, start where the spring and wire are connected at the bottom of the bellows and pull the wire out of the groove of the bellows then pull the bellows off of the lip of the front panel.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine and disconnect the electrical connections.
Measure the resistance of the wax motor. The normal resistance is around 1500 ohms. Shorted or open circuit wax motor means the door lock and switch assembly needs to be replaced.
Simply
replace the door lock and switch assembly (part #131763202) if the wax motor reads shorted or open to address the issue. But if the wax motor resistance is normal, check the continuity of the door lock and switch assembly wire harness, particularly the wax motor wire harness. Start with the continuity of the red/black wire of the wax motor harness to each of the red/black wires of the door lock and switch assembly harness. They should all have continuity; otherwise, replace the harness.
Remove the top panel to access the control board if further continuity test is necessary or if the red/black wire of the wax motor harness has continuity with the all other red/black wires of the door lock and switch assembly harness.
Remove the screws attaching the top panel to the rear of the cabinet then lift the panel off. The console can be removed from the cabinet to completely access the control board connections, particularly the door lock and switch assembly harness connections. Check the continuity of the red/black wires at the door lock and switch assembly to the red/black wire of the harness connected to connector J2 on the control board.
The problem is in the control board if the wax motor is good and the door lock and switch assembly wire harness has all the necessary continuity. The only viable solution, should that be the case, is the replacement of the control board.
Oct 03, 2010 | Frigidaire GLTF2940ES Front Load Washer
My washer wont do the spin cycle. everything else work fine but no spin
The reason the washer won’t spin is due to the either of the latches on the door.
This model uses a two stage lock that latches the door when the load starts, and then when it is time to spin, the second lock engages to ensure the door is properly secured prior to beginning the spin. When this second lock engages, it also closes a set of switch contacts (the auxiliary door switch) telling the control board the door is closed and locked. If for some reason this switch is not closed, the washer will tumble during what would normally be the spin cycle until the entire cycle is complete.
On the entire Frigidaire ATFxxxxxxx line of front load washers, if the secondary door lock fails, the unit will not spin. If you suspect this is the reason your washer is not spinning, do a check of the error log and you will find an E47 error has been logged. This error indicates the control board thinks the wax motor has failed because the auxiliary switch never closed. The customer will not see this error in the display, but it will be stored in memory. A quick resistance check of the wax motor will tell you if it has failed. Expect 1K to 1.5K of resistance from most of the wax motor heaters.
After finding the E47 error stored in memory, I would request you that the switch be removed from the outer door seal spring so you could pull the switch out the front. A quick resistance check showed the wax motor was open electrically so it was no longer working. Install a new switch assembly
, reattached all the wires along with the door seal. And now the washer will wash and spin.
Thank You for using Fixya.com
Jul 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Won't start flashes dL then F
or lock failure. Probably a bad wax motor. get ahold of your authorized dealer. This is a defect on these machines. They have a new and improved wax motor. Raise enough hell and they will fix it for you.
Mar 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
ATF6000ES won't spin on the spin cycle
I had the same problem. It was under warranty...they replaced the main motor, the water/drain pump, the upper control panel and the lower motor control board. All these items cost more than the washer! I read a blog that said it could be the door lock assembly. My door lock assembly was working so I did not think that could be the problem...I took the assembly apart and found out it has a primary magnetic(electrically charged copper coil) lock that activates any time there is movement or water in the machine. That was working. The secondary lock is a wax motor that locks safety locks the magnetic lock during high spin. The wax motor also closes a circuit that tells the main board that it is locked and safe to go into high spin mode. The wax motor was bad...and did not engage so the machine, out of safety would turn off with no Error Message. You can replace the entire door lock mechanism for about $50, or if you wan to take 2 minutes to disassemble the door mechanism and replace the wax motor, it will cost you about $10!
The Neptun wax motor will work...Frigidaire only offers the entire lock mechanism replacement part.
I hope this helps you out!
Steps remove the top panel...Open the washer door....remove the two phillips screws...take off the three terminals. Replace...Should take 10 minutes.
Mar 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Door lock failure
It sounds like your door lock unit has a bad wax motor. There are 2 wax motors on the unit. 1 which actually locks the door and 1 that presses down on a check switch to tell the computer board that the door is locked. The wax motor that is bad is the one that presses down on the check switch. It is not a part that can be replaced on its own and you will need to change the entire door lock unit
Jan 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
No final spin- washer tub rocks back and forth and times out
e47 i believe is a door lock issue, although its locking shut there are multiple switches in the lock mechanism
Feb 22, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
1,680 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
