My Noritz remote controller RC 7646M-2 shows a yellow/orange "Priority" light. Is this normal, or is it telling me something?
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
There is something wrong with your remote control. Almost all remote controls emit infrared rays, and is invisible to human eye.
Posted on Jan 22, 2013
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
How to reset RC-569M remote controller to factory defaults.
Not sure if it's the same, but for the Onkyo RC-799M controller the reset sequence is:
To reset the remote controller to its factory defaults,
while holding down RECEIVER, press and hold down
HOME until the remote indicator lights (about 3
seconds). Within 30 seconds, press RECEIVER
again.
Jan 05, 2015 | Onkyo Audio Players & Recorders
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
Need help wiring this theromostat. I ahve the following color wires.....Green Red Black Blue White Yellow and Orange. Need to match them to the following connections: G RC RH Y/O W/B Y1
G= Green Wire (Fan) RC= Red Wire (Power Cooling) Y1= Yellow Wire (Cooling Contactor) RH= Black Wire (Power Heating) WB= White Wire (Heating Control) YO= Orange Wire (Damper Control)
Blue Wire is usually to C= Common
Nov 28, 2010 | Heating & Cooling
Noritz remote controller "RC-7646m-1" seems to need to be restarted several times throughout the day. Usually what happens is out of nowhere, it'll just lose it's temperature reading (at usually 140), and...
You are actually getting a 90 error code. This error code occurs if the unit is dirty and overheating. I'd recommend contacting a servicer to clean your heater with compressed air. They'll need to remove the fan motor and manifold plate to fully clean the burner chamber and heat exchanger.
Jan 21, 2010 | Noritz 6.3 Gallon Residential Tankless...
Have Clarion DB148R cd car stereo but no wiring diagram
matching colors are the speakers, red it the accesory, needs to be hooked up to an alternating current, something that works with the ignitions, this will turn the sterio on and off, yellow is 12 volt or memory, constant power, blue is a remote wire for an amp. black is a ground wire and orange is normally an illumination wire, so when you dim your dash lights your stereo also dims.
Sep 04, 2009 | Clarion DB148R CD Player
RC 201 POLAROID TO WORH DISHNET
Try calling the Dish network customer support phone number. Only they can tell you the code for the remote you have, that matches the box you have.
If you have the manual for the poloroid it should tell you if the Polaroid is a universal remote and show codes in the manual. If no codes in the Polaroid manual then it is not a universal, so it can not be done.
Mar 23, 2008 | Televison & Video
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Electro Med Services...
