Question about Philips Magnavox 9P6034C 60" Rear Projection Television
The picture is not clear anymore. It seems as though the picture has gotten gradually darker. We still use the television, it is just not clear enough. When watching nighttime scenes, we cannot see mu
It is especially hard to watch when its daytime because the sun adds a glare to the screen making it even difficult to view the screen. The picture is not completely black. We can make out what we are watching easily, however the color is just darker. When we watch at a different tv in our house, the picture is significantly clearer than the phillips.
  • Philips Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
578the picture is not clear anymore. It seems as thou - 65af323.jpglass=
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Posted on Jan 31, 2013
techman
  • 3130 Answers
SOURCE: TV Screen
Yes there are several and the ones I am posting for you have been used by folks who I know. You will most likely need to get the telephone number and call around, and they will probably need the exact dimensions of the screen good Luck http://www.projectorcentral.com/screen-suppliers.htm http://www.screens-usa.com/largescreendisplays/index.php http://catalogs.infocommiq.com/AVCat/mcs.cfm?mlc_id=223&SID=972124&mrc_id=1495&SUBCATID=1170
Posted on Jun 05, 2007
SOURCE: Picture size too large
We have the same problem with the same model. We already had the main board replaced. The picture has gotton so bad that you cannot adjust the pixels anymore. Well, you could never get to the pixels that were off the screen because the picture is too big
Posted on Jun 28, 2007
premtech
  • 934 Answers
SOURCE: blury picture, convergance problem
What you're describing is probably contaminated coolant in the crts. Between the outer part of the crt and the lens is a chamber filled with a coolant (ethyl-glycol) which can become contaminated and cause blurred picture. I'd strongly recommend taking this to a shop the procedure for changing these is a bit beyond the layman level.
Remove Crt assembly. Mark the Crt lens position for accurate reasssembly.
Mark the centering ring's postions to make easier realignment and carefully remove lens assembly by removing the four torx screws. Keep Crt assembly vertical so you won't leak the fluid...
Remove the inner lens by carefully prying up on the edge of it.
Dump out the fluid in the sink and wash the face of the Crt and chamber with water to remove all the fungus and crud. Flush the chamber with isopropyl alcohol to kill all the fungus and dry thoroughly.
Reassemble inner lens and outer lens and tighten all four torx screws.
Remove side filler plug and fill chamber with approved new Crt coolant, reinstall and converge.
Repeat this procedure for the other two Crts. It will need this done whether it looks clear or not !! The green and blue Crts in this unit are prone to this failure.
Hope this helps
Bill
Posted on Nov 14, 2007
  • 579 Answers
SOURCE: Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Posted on Jan 02, 2008
Slinteriors
  • 8617 Answers
SOURCE: Magnavox Projection
When You say glare are you refering to the color bleeding off an image, or is it more of a halo effect around a certain color? Color bleeding is a sign of a shorted gun in the CRT whereas a halo or hasiness around can be CRT coolant needing replacement. Which mode do you have.
Posted on Jan 03, 2008
My samsung led tv is getting dark
With a DLP TV, getting a darker picture means it is time to change the bulb.
Feb 16, 2015 | Samsung Televison & Video
Sharp LC-65d64u. Does this tv use a lamp that can be replaced
Refer its user manual and see there is any description about lamp repalcement. If yes, there is a lamp. If not there is no lamp. OK?
Gopakumar Gopalan Google
Feb 17, 2014 | Sharp Aquos Televison & Video
Why is my picture getting darker?
If CCFL lamps are weak, this might happen. Check the control voltage comes to backlight inverter board from the main board too. It should vary according to increase in brightness.
Jan 23, 2013 | Polaroid Televison & Video
Problem with the Philips Magnavox 9P6034C 60 in. Rear Projection Television, had TV for 16 years. Picture gradually got darker and less clairity
the projection tubes do wear out over time and there is no fix but to replace them. you might first check to make sure the lenses and mirror are clean, do not use compressed air to clean as you may force dust between the lenses. if the picture is darker at the edges or a different hue then the coolant is likely contaminated and needs changed
Dec 15, 2010 | Philips Magnavox 9P6034C 60" Rear...
Samsung 56 inch lcd tv..picture suddenly got darker not clear anymore....what can it be??
I belive this is a rear projection tv and if the picture has gotten darker.... most likely the problem will be in your TV Lamp.
Apr 30, 2010 | Samsung HL56A650 56 in. TV
I have a pioneer elite pro 100 projection tv. the picture seems to be getting darker and darker. and the color seems to be fading as well what could be wrong? and i havent tried to turn up the brightness...
hi..first check it out the brightness.It is available in the
menu button,available on the top of the tv.If it still doesnt
work Projection TVs have a high intensity lamp as the light
source. They wear out and gradually get dim.You probably
need to replace it.
check it out..
thank u..
rate my response..
May 05, 2009 | Pioneer PRO-100 TV
My screen has gotten much darker
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 24, 2008 | Hitachi 53SWX12B 53" Rear Projection...
Zenith z44sz80 Dark picture
i have same problem. i replaced lamp but picture is still dark.
Aug 22, 2008 | Toshiba 46H83 46" Rear Projection...
the lamps have to come out. the fluid has to be sucked out from the bottem.
Jan 05, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture has gotten darker
Nov 26, 2007 | Hitachi 53SWX12B 53" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
51 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
