Question about Motorola Mobility H700 Wireless Headset
Reposition boon need to change for use on other ear..set for left ear need to right ear
  • 25 Answers
Hello! take the ear piece and unfold it to 45 degrees, than pull it off . see the little splits on the end where the earpeace goes onto the body off the tooth? thats motos design for slipping it off the pins. than turn the earpiece around and put er back on. a little bit of a tussle till you get use to it. if your confused as i was put the earpeace on your other ear and the light will turn on and youll go (like me) oh yea!! i see, than youll go easy breezy. good luck. m.m.
Posted on Jan 27, 2009
Just moved to new location and hooked up i com. Am only getting sound in left ear. Have rechecked everything and all connections seem sound???
this is an oxmoron you cant have checked every thing
left and right ear audio on CBs come from a common mono signal
so the right ear signal is missing or the headphone on the right ear piece is busted
sherlock....
Nov 27, 2014 | Icom Ptt Over Ear Mic / Ear-phone For...
My tascam us-144 only plays in left ear, and I do not have cubase, need fix!
Hello you can download a manual and other stuff here:
http://tascam.com/product/us-144/downloads/
You need adobe reader to read the content.
Good luck
Dec 12, 2012 | Tascam US-144 Sound Card
After interference, the needle won't reposition left or right properly.
sounds like something got damaged or broke & the machine needs to be checked
Mar 24, 2012 | Brother CS6000i Computerized Sewing...
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
In recent days my headset (590A) has only been transmitting sound on the right ear via bluetooth connection, when I use the 3.5mm jack (connected to left ear) both ears work. Is there a fix for...
Your headset can be used as stereo headphones or a wireless microphone for a bluetooth enabled device like a cell phone or a computer. When you plug the headphones into a device with the 3.5mm jack the headset automatically turns into stereo headphones and disables the microphone(headphone mode). It sounds like whatever device your headset is connected to via bluetooth is using the wireless microphone protocol where sound only comes through the one speaker and the microphone is on(microphone mode). The bluetooth protocol settings of your device may have been changed accidentally. You will need to go into the bluettoth settings of your device you are using with your headset and change the protocol. If it is a cell phone you will need to go into the bluetooth settings in the settings menu. If it is a computer your can adjust the bluetooth settings in the control panel.
You can download the pdf file of your instruction manual for your headset here
I hope this was helpful and let me know if you have any other questions. Thanks for using FixYa
Oct 15, 2010 | Plantronics Pulsar 590A Wireless Headset
When I used these headphones this morning, I noticed that the sound from one of them was far less powerful than the other one. I've tried different songs, to see if it wasn't just the song, but the problem...
had the same problem with the right ear bud and I don't know if it is suggested in the manual, but cleaning the mesh on the ear bud with a cotton stick dipped lightly in alcohol (almost dry) helped with me, the sound is back 100%.
I hope it helpes with your too.
Mykab
Sep 05, 2010 | Sennheiser CX 300 Consumer Headphones
How to install bobbin
In the shuttle area there is a silver round piece- called the shuttle race cover. It has a black ear on the right and a black ear on the left. Push the right ear to the right, and the left ear to the left and the silver ring should come out. Behind the silver ring is the bobbin case stuck in the hook. Remove that, jiggle it, move it, just work the bobbin case out of the hook. Now put the hook back in the machine. In the machine there is a driver that looks like a half moon. Your hook looks like a half moon- make a full circle out of both of them. Re-install the race cover, pushing the left ear to the right and the right ear to the left to secure the race cover, and your problem should be solved.
Jul 07, 2009 | Necchi Sewing Machines
Bobbin don't turn
Jul 01, 2009 | Brother SE-270D Computerized Sewing...
A Bose headset is buzzing
The speaker in that Ear Cup may be blown. You should consider replacing the set with a newer one.
If you listen to this with that static noise you risk serious injury to your ear.
Jan 04, 2009 | Radio Communications
Motorola Mobility H700 Wireless Headset Logo
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
