Question about SimpleTech by Hitachi SimpleDrive Rev. 3 1000GB, USB 2.0 LS-100
My hitachi simpledrive 3 1tb hdd keeps going into a sleep mode after 15 mins
My hitachi simpledrive 3 1tb hdd keeps going in to a sleep mode when i connect it to my xbox 360 when i am watching a movie when i try to continue watching the film after i mpause it it seems to loose the connection any help would be appriatiated
Hi, i have connected 2 32" LG LCD tv with my
You go into the power settings, in the control panel, and switch it off.
Aug 21, 2013 | Computers & Internet
My computer keeps going into sleep mode after 2 min, how can i solve this?
Open up CONTROL PANEL and look for POWER OPTIONS. In there you can set when the harddrive and monitor shuts down to preserve power. You can also put in "never" to avoid it going into sleep mode.
Apr 23, 2011 | Computers & Internet
This drive 250gb hitachi is not being recongnised by my computer.
maybe its in the bios settings that set to first boot was your external hdd,,,open bios settings and set first boot to harddisk drive,to boot your primary hdd so your external will be now detect
Feb 12, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
My trutech tv goes off about 15 to 20 mins after i turn it on, why is that?
Check the sleep mode might be on?Sleep mode on like 30,60,120 times all up,run out will go off.Will automatic,tv will shup off.
Feb 01, 2011 | TruTech PLV16320 Television
Phillips lcd 32 inch(PFL-3403) tv picture is going off after 10- to 15 minutes of working since 26.01.2011.
Check whether timer is ON mode or OFF. If it is ON set it to OFF mode.
Check whether sleep after 15 mins is after
set it to NEVER or OFF mode(sleep means if you won't change any channel or iuf you din't did any thing for 10 it will goes to sleep mode..... and again you have to turn it ON)
Thank you
Jan 27, 2011 | Philips Televison & Video
Should I Leave my PC in sleep mode after use?
Go green & use hibernate instead.
Well, actually a lot also depends upon what is the duration of you not using the system between breaks. Hibernate anyways is quicker than a normal boot process. I would highly recommend hibernate.
Sleep - is a combination of stand by and hibernate. Be default most of the newer system will write the memory info into hibernation file & put your system to stand by mode. After certain period say 2-3 hours your system will go into hibernate mode. (these are standard settings & unless you keep coming back in 15-20 mins you should use hibernate & contribute towards environment too)
Oct 07, 2010 | Computers & Internet
HITACHI 26LD2550B,AFTER SWITCHING OFF OVERNIGHT,SWITCH ON NEXT DAY ONLY GET SOUND FOR 15 MINS,THEN PICTURE COMES ON PERFECT
This maybe due to capacitors dried up in air conditioned room. Keep the TV in standby mode, will keep the large electrolytic capacitor cured at all times.
Aug 15, 2010 | Hitachi Televison & Video
Computer asleep
I have to keep my pc in safemode now as mine is also in constant sleep mode and I can not get it out, It is the only way it will load up! :-(
Apr 09, 2009 | HP vs15 15"LCD Flat Panel Monitor
Mikomi ak-808u keyboard
When you press your power button your system goes to sleep mode as per your system settings. To awake your system just press any key or 'Awake Key' (if its present on your keyboard), then your system will be back. No need to wait.
Thanks
Iqbal
Mar 11, 2008 | Computers & Internet
SimpleTech by Hitachi SimpleDrive Rev. 3 1000GB, USB 2.0 LS-100 Logo
65 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
