Question about Whirlpool Dryers
No blowing heat on dryer
WGD5820SW0
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
There are safety sensors that will stop the flow of electricity if there is excess heat. Sometimes these sensors fail and have to be replaced. You must use an OHM meter to determine which ones have failed.
Posted on Jan 22, 2013
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Dryer heats in a 'no heat' selection
it sounds like you have a grounded heat element and the heat will stay on all the time,very easy to check,unplug the dryer,pull the two wires off of the heat element,with a meter touch one lead to the outside metal cover of the heater and the other lead to one of the element,then check the other side of the element the same way,if it shows continuity on one end of the element it's grounded and needs to be replaced with a new heating element.and every year or 18 months you have to clean out the dryer,i use a shop vac and a leaf blower,unplug the dryer,remove the bottom panel,remove the lint filter and the metal duct that the filter slides into,vac up all the lint you can see,brush out the hole where the filter goes and with a long thin screw driver dig out the lint that's in the right and left sides of the plastic slots where the filter slides in,now with the shop vac set it to blow and blow all the lint from the back forwards and blow the motor off and vac up the lint,after you clean out the cabinet go to the back and remove the vent line from the dryer,stick the leaf blower into the vent line and blow it out to the outside,if you do this every year you'll have less problems with the dryer,your clothes will dry on time and you don't have to worry about a dryer fire.
Feb 01, 2014 | Kenmore Elite HE4 Electric Dryer
Dryer has no heat
If it is blowing but no heat at all check the thermal fuse, cutout fuse, all thermostat's & centrifugal switch on the motor. Check the heating element also check if the heating element is grounded to the heater box. First clean the vents inside the dryer and all the way to the outside completly. Hope this does the job
Dec 18, 2013 | Whirlpool Dryers
Mt Moffat clothes dryer keeps blowing thier own fusses
You have heat sensors on the Heating Element. If one allows the heat to get to high it can trip the Breaker. It more than likely is a bad Circuit Breaker in the Breaker Box. These can go bad. It is a Double switch, one is for the heat, one is for the Motor.
Jan 18, 2013 | Dryers
The dryer doesn't blow any heat 11074972300
Check heating element with Ohm meter should read something.
Infinite reading means the coil has burnt out. replace.
Nov 04, 2012 | Kenmore 95087 Gas Dryer
My Whirlpool Super Duty Imperial drier won't produce heat. I made sure the outside vent was unclogged; it is blowing cold air.
When a dryer doesn't heat, either the heating element is bad, or the flap inside the venting of the dryer is opened allowing air to bypass the dryer instead of blowing the air into the dryer.
Jun 24, 2010 | Dryers
Dryer isn't heating. It turns and blows air but
make sure lint screen and vents are clean. next shut off electric and check heat element for broken element. then get model # and serial # order and change thermocutoffs located on heater box and fanhousing ck these steps one by one
Dec 09, 2009 | Kenmore 75962 Gas Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
