Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
Green Image - Can't WB
I am working with a 2100 whose image appears green tinted in both the viewfinder and LCD. Previous recordings seem to play back w/accurate color but new recordings still look green. All users presets that have been reset and both auto and manual WB tests yield the same result. I think one of the chips is fried- any possibility of something else?
  • 1 more comment
  • Jeanine Corbet Aug 30, 2007
    I sent it in to Sony and it was covered. Thanks for all your help!
  • Jack Pati?o
    Jack Pati?o Dec 19, 2007
    Our company DCR-VX2100 is suddenly plagued with a pinkish/reddish tint in the view screen, and the video comes out with the same color. My boss has tinkered with all the buttons plus reset the camera with the battery removed, but it is still showing and taping in pink. Could it be one of the "chips" or "CCDs" has gone out?
  • VJCAPONE Apr 14, 2008
    Camera will not white balance.
    Tapes recorded on otehr cameras play fine. Tapes recorded in the vx2100 aquire a green tinge which shows up when played in any camera
For this problem u need to show this camera to a professional cemera repair person. As per my knowledge it is the fault of ccd connector which may be dusty.Cleaning this with cleaning sol'n. It will definatrly work. Otherwise the CCD need to be replace. Regards, Shailesh Ramteke Service Engineer (sony camera's & VTR's) [email protected] 9920313597
Posted on Aug 09, 2007
It's a known problem at sony, check this site: http://esupport.sony.com/US/perl/news-item.pl?mdl=DCRVX2100&news_id=118
Posted on Aug 11, 2007
SOURCE:
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
My LG flatscreen image emits an intermittent green tint and then reverts back to normal colors.
Sep 09, 2010 | LG 42LC2D 42 in. LCD HDTV
No image on LCD screen
It sounds like you're receiving partial information on the LCD screen and that the image sensor isn't sending information to the screen.
If you know the sensor is working by recording some video on an SD card and being able to view the recorded video on your PC, then there is a disconnect between the LCD and the image sensor.
If you are not recording video to your SD card and only get black images or no files, the image sensor is damaged.
If you are recording video, but no image appears on your LCD for internal viewing/playback, you can try a firmware update if one is available from www.insigniaproducts.com, but this is a discontinued item so there's not much available for support.
Hope this helps!
Apr 25, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Image green tinted.
TRY VIDEO CONVERSION OPTION IN THE MENU,,IF NOT TRY NEW CONNECTERS
May 15, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Photo appears saturated green when set on manual setting
The image you selected for Custom WB is probably inappropriate - it may be shot somewhere else with different lighting or not enough of the image is white/grey. To do a proper Custom WB, take a picture of a white or grey card in the same lighting conditions as your subject. Go to menu, select Custom WB and choose that image. Then set your WB mode to Custom (if it's not already).
When you move to another site to take other photos, you must change your Custom WB image to another 'current' one. As the sun progresses through the day, your Custom WB will need to change as well. Auto WB will, in most conditions, be able to deal with changing light if you prefer not to keep updating your Custom WB.
Feb 22, 2009 | Canon EOS 40D Digital Camera
Lcd screen on sony dsc f707 is green
After much money at repair shop for green viewfinder,
3 minutes ago I rapped my F-707 sharply on the
camera bottom, and green disappeared. Everything
else appears to be normal now.
Jan 05, 2009 | Sony Cyber-Shot DSC-F707 Digital Camera
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
DSC-F707 viewfinder black
This same thing happend to me awhile back. Camera seem to be dead for several weeks until one day I tried turning on and then off the night vision. The was the usual click inside the camera and all was well after that. I still use the camera.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
286 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
