Question about Apple Final Cut Express HD for Mac
After uninstallinb Final Cut Express I can't reinstall
Will not accept the serial number for version 3.
  • 2 more comments
  • jack491 Jan 27, 2009
    Sequence of events  leading yp to this p roblem.
    1. Opening iIkon for FCE came up ahd then disappeared repeatedly.
    2. FCE reinstalled with upgrade to 3.5. Did not solve problelm.
    3.  Used sodtware to uninstall FCE 3.5
    4. Restarted amd tjem e,[toed trash
     5. Attempt to reinstall thwaarted because  the serial number from original
    FCE was  not accepted. Tjis was a  freestanding  softwaare not an update.
    At some piont I think before the uninstall the PRAM was reset.
    This  serial number prooblalm  happened oon FCP but I don't remember the remedy.
    omment posted on Jan 27, 2009
    Sequence of events leading yp to this p roblem. 1. Opening iIkon for FCE came up ahd then disappeared repeatedly. 2. FCE reinstalled with upgrade to 3.5. Did not solve problelm. 3. Used sodtware to uninstall FCE 3.5 4. Restarted amd tjem e,[toed trash 5. Attempt to reinstall thwaarted because the serial number from original FCE was not accepted. Tjis was a freestanding softwaare not an update. At some piont I think before the uninstall the PRAM was reset. This serial number prooblalm happened oon FCP but I don't remember the remedy.
    I had done all the things suggested so far.
    Final Cut Express reinstall provlem.
    This is n ot an upgrade version. Installed previously on this c omputer.
    However the program failed and I am aftaid I have lost many fp files.
    I have previously posted this but no solution has been posted.
    Comment posted on Jan 27, 2009
    Any help appreciated.
    Jack
  • Apple Master
  • 19,396 Answers
The problem is not the software, the problem is mac os.
You need to back up all your files , then do a complete installation of Mac Os.
Posted on Jan 28, 2009
    Sergeant:
  • 320 Answers
First uninstall the previous version of your software and reinstall it again... or you can upgrade the previous version itselft and try the serial key for the upgraded version.. hopefylly itshould work..
Thank you....
Posted on Jan 27, 2009
    Sergeant:
  • 221 Answers
Http://dvcreators.net/discuss/showthread.php?t=19967
for how to uninstall completely.
the another link for
how to reinstall it again
http://manuals.info.apple.com/en/Installing_Final_Cut_Express_4.pdf
  • 86 Answers
According to apple´s support if you install Final Cut Studio 2 after having installed Logic Studio, the option to install Final Cut Pro may be dimmed so that it is not possible to install Final Cut Pro. Other applications can be installed.
This particular issue specifically occurs on systems on which Logic Studio has already been installed.
Resolution
Take the following steps to resolve this issue:
If it is still running, quit the Final Cut Studio Installer.
In Finder, navigate to /Library/Receipts/.
Locate the file named ProMediaIO.pkg and drag it to the Trash.
Run the Final Cut Studio Installer again.
  • Dr_Joseph
    Dr_Joseph Jan 27, 2009
    Also, if Logic is not the problem follow the steps below to completely reinstall a fresh copy of Final Cut Express.
    Open the Applications folder.
    Drag the Final Cut Express application to the Trash.
    Go to /Library/Receipts.
    In the Receipts folder, select the "FinalCutExpress.pkg" file.
    Choose View > as List to view the contents in a list.
    Click the Date Modified column header so you can easily see all of the receipts that were installed at the same time as Final Cut Express.
    Drag the FinalCutExpress.pkg receipt to the Trash, as well as any other items that have a modification date within 3 minutes of the FinalCutExpress.pkg's modification date.
    Click the Name column header to sort the list alphabetically.
    Drag any other receipts whose names begin with "Final Cut Express" to the Trash.
    Insert your Final Cut Express installation disc and install Final Cut Express.
    When finished, use Software Update (under the Apple menu) to update your software to the latest version.
    President:
  • 1,952 Answers
  • 2 more comments
  • mohammed marika thambi
    mohammed marika thambi Jan 27, 2009
    Are you sure you purchased the correct upgrade version 3?
    mohammed marika thambi Jan 28, 2009
    uninstall the previous version of your software and reinstall it new version then install anti virus
    -If you open Final Cut Express HD 3.0 on certain computers, you'll get a
    "Configuration Error" message that indicates that your computer is
    missing certain hardware or software, or possibly an AGP graphics card.
    In some cases the Final Cut Server client application may not open when
    you double-click the Final Cut Server.jnlp icon or Final Cut Server.app
    icon. This may happen after switching user accounts or restarting your
    computer from a volume other than the one you used to download the Java
    Web Start Final Cut Server client.
    Final Cut Server uses configuration data which refers to the
    administrative user that installed the software. This configuration
    data contains the User ID (UID) which is different than the username of
    the administrative user. There may be situations where the Final Cut
    Server configuration data does not match any existing UIDs of local
    administrative users. For proper functionality, make sure that the UID
    in the Final Cut Server configuration data matches the appropriate
    administrative user's UID.
    A new serial number can be generated in the event that yours is missing
    or invalid. Apple requires a valid proof of purchase to request a
    replacement serial number submitted via fax or email. The following
    guidelines will help you to determine what is best for you.Categories: Apple, Final Cut Studio
  • 153 Answers
Try uninstalling it and reinstall
r check for virus it may also cause trouble
    Brigadier General:
  • 3,614 Answers
What error message did you got on your screen?
  • micromaster
    micromaster Jan 27, 2009
    whta procedure you do to reinstall it again..
    Better Do a complete uninstall of the application and reinstall it again.
    Let me know
Need serial number for Final Cut Studio
Contact software manufacturer or distributor and they will assist you, otherwise the code will be provided with the software that was provided at purchase.
Apr 21, 2013 | Apple MA888Z/A Upgrade Final Cut Studio to...
Tip
How to Export Movie from Final Cut Pro (FCP) to FLV? After editing your own...
After editing your own movies on Final Cut Pro or Final Cut Express, you may want to put them on your website for presenting your introduction or promoting your services/products. For users with the older version of FCP, FCE or iMovie, it is easy to export FLV by choosing File > Export > Using QuickTime Conversion. However, if you could not find Flash FLV as output format from FCP/FCE/iMovie, you may need a FCP to FLV converter to get Flash videos.
Aunsoft Video Converter for Mac is the best FCP to FLV converter for you to handle videos on iMac/MacBook Pro with Snow Leopard or Leopard. The Mac FCP to FLV converter supports loading .3gp, .m4v, .avi, .dv, .flc, .mp4 videos from FCP/FCE/iMovie and converts FCP movies to FLV as short film. Below are the steps to export Final Cut Pro movie to FLV with Aunsoft Video Converter for Mac.
Step 1. Load Final Cut Pro movies to Aunsoft Video Converter for Mac.
After exporting movies from Final Cut Pro, run Aunsoft Video Converter for Mac as the Mac FCP to FLV converter, and click the "Add" button to load FCP short films for conversion.
Step 2. Choose FLV output format.
Click the "Format" option and choose Flash Video > FLV-Flash Video Format(*.flv) as output format. This format is compatible to most machines.
Step 3. Transcode FCP movies to FLV.
Click the "Convert" button under the preview window, and the Mac FCP to FLV converter starts converting Final Cut Pro movies to FLV for playing on webpage.
Tips:
1. After converting Final Cut Pro movies to FLV, you need Flash players to navigate the video playback on webpage. You can use free web players like JW player, Moyea PlayBox player and Flow player to present your short films on website.
2. You can set the video resolution of the FLV videos by clicking the "Settings" before conversion.
3. The above step-by-step guide with Aunsoft Video Converter for Mac also works for the movies exported from Final Cut Express and iMovie. In other words, you can also convert FCE movies to FLV, iMovie videos to FLV on Mac OS X.
on Jul 22, 2010 | Cell Phones
Tip
How to edit MTS files on Mac
Video editing software on Mac like iMovie, Final Cut Express, and Final Cut Pro still have big troubles in recognizing footages shot by AVCHD camcorders. The problem is especially obvious for those people who do not have the latest version of these editors. Because these AVCHD cameras such as Canon HF S11, HF S200, JVC GZ-HD620, Panasonic AG-HMC40, etc. are all recording videos in the format of MTS or M2TS, which have not got native supports from the above mentioned Mac editors to full extent. To make MTS files possible for editing on Mac, here I would recommend you Pavtube MTS/M2TS Converter for Mac, which will convert MTS to MOV and other container formats that are accepted by often used Mac editors-iMovie, Final Cut Express, and Final Cut Pro. The application works well on Mac OS X and handles TS, TP, M2TS, M2T format as well. The following guide tells you how to convert MTS files to a workable format for editing on Mac step by step. If you are frustrated by the similar problem, please read on it to find out the solution.
1. Run Pavtube MTS/M2TS Converter for Mac and click "Add" button to load MTS files shot by your camcorder to this program.
2. Click on the drop-down menu of "Format" to select a compatible format for your iMovie, Final Cut Express, or Final Cut Pro. I select "MOV-QuickTime (*.mov)" as an example.
3. Click "Settings" button to adjust audio and video parameters
You are allowed to adjust audio and video parameters like codec name, bit rate, aspect ratio, frame rate, and audio channel in the following window. In principle, the larger input values, the larger file size, but accompanying with the better file quality; the smaller input value, the smaller file size, but accompanying with inferior file quality. That is to say, if you want to do advance settings, you’d better make a balance between the file size and the file quality.
4. Start converting MTS files
Once all the above settings are finished, you can click "Convert" button to start converting MTS/M2TS AVCHD files into iMovie, FCP or FCE supported format. The interface below will show you clearly about conversion progress, time elapse, left time, generated file size, and estimated file size.  After conversion is done, you can easily find out the output files for editing via clicking "Open" button.
The end! Hope this helps.
For more: http://www.pavtube.com/mts-converter-mac/
on Mar 22, 2010 | Cameras
Can't find serial number for Final Cut Studio
Call Apple. 1-800-APL-CARE and ask to speak with "Pro-Apps".
Final Cut Express 2 won't Panasonic PV-GS320 minidv camcorder
hi,because final cut express only support .dv,mpeg-4 and .mov formats.
so you can convert your video files to .mp4.
you can use the third party software convert your video files to .mp4 format.
you can use Mod to Final Cut Express Converter.
http://www.fceconverter.com/mod-to-final-cut-express/
Jan 30, 2009 | Panasonic PV-GS320 Camcorder
Importing video from Xl1 canon into my Mac
you must use the third party software convert your video files format to final cut express support formats.such as dv,mp4,mov
if your video files is .tod format,you can use tod to final cut express converter.
http://www.fceconverter.com/tod-to-final-cut-express/
if it's .mod files format, you can use mod to final cut express converter
Mar 27, 2008 | Sony Handycam DCR-TRV18 Mini DV Digital...
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Apple Final Cut Express HD for Mac Logo
169 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
