Question about Ryobi 10 in. Portable Table Saw with Stand RTS20
10" portable saw table zero clearance insert for Model # RTS30
Zero clearance inserts
2 questions re Craftsman Tablesaw 137.218072 since the young men in that dept at our Sears did not know what a table saw was!
You can find a nice quality feather board that will fit your table saw from www.leevalley.com. They have one that comes with both 5/8" and 3/4" table bars and sells for about $15. I have one and it works great, Look under the Woodworking tab and type in feather boards. Look at the brand Versatile Featherboards. http://www.leevalley.com/US/wood/page.aspx?p=60022&cat=1,240,45884,60022 You may want to call Lee Valley to see if they have a zero clearance insert that will fit your saw. Otherwise, order a new insert from Sears Parts Direct. From the picture on their website I believe it comes as a blank and you will need to cut the new opening in the insert. To do that lower the saw blade all the way below the table top, install the new insert, move the rip fence over top of the insert but not over where the saw blade would penetrate, turn on the saw, and slowly raise the blade up through the insert.
e1e75b0f-dc3b-4bbe-bf84-360a611e8e41.jpg b3efb051-1d00-43f6-bc27-d2f9d84da710.jpg
Oct 02, 2014 | Craftsman 10" Table Saw
How to tighten the bevel lock on a RTS30 Ryobi table saw
I have a RTS30 that has a problem that I am learning is quite common. The "pad" (part 0890370080400) that is under the bevel locking handle, splits and falls out. This leaves the locking handles cam loose because of excess clearance.
Oct 08, 2013 | Ryobi 10 in. Table Saw with Wheeled Stand...
Need to purchase delta 36-979 dado head table insert for 10' table saw
Use an appropriate pc of mdf that is same thickness of throat plate already installed. Use a router to flush trim to that throat plate. Now, insert and hold down with clamps and scrap panel. Raise Dado head ,while running, enough to do the job. This completes a zero clearance throat plate. No need to buy!
Dec 31, 2012 | Delta 36 979 10 Inch Left Tilt 1 1/2...
I cannot attach the anti kickback device to my dewalt 10 inch table saw.
If you lost the instruction manual go to dewaltservicenet.com and you can download them, but in the meantime there is a lever that removes the guard lift up on it and then towards the back is a slot for the pawls, depress the button on them and insert into the slot making sure they lock replace the guard and make sure everything moving freely up and down movement of the saw and free movement of the other safety devices. Let me know if you need more assistance.
Aug 23, 2011 | Dewalt DW744S 10" Portable Table Saw with...
I have a craftsman table saw model 113.27870. I need a table insert for a dado blade. I looked on the sears website and it said parts for this saw are no longer available. Will a table insert for a newer...
Maybe you could try using the outline of the regular insert to cut a new insert out of a piece of polycarbonate (lexan) or ABS plastic. The clips that hold my dado insert barely hold it in place on mine, and I've seen other saws that use plastic.
Aug 02, 2010 | Craftsman 10" Table Saw
Ryobi 10 in Portable Table Saw modl #BTS12S won't turn on
Look for a trip switch on the saw motor
Nov 02, 2009 | Saws
Zero clearence isert
I'm not sure why the instructions said to change the blade in order to cut the slot. I've made several of the zero clearance inserts (for different blades) and always made the slot with the blade I intend to use it with. Of course, you need to match the inserts to the blades (I just tie wrap them together.
Aug 05, 2008 | Dewalt DW746X 10" woodworker's table saw...
Ryobi 10 in. Portable Table Saw with Stand RTS20 Logo
103 people viewed this question
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
