Question about Hotpoint Aquarius WMA56 Front Load Washer
Aquarius tcl770 started making noise then stop spining
  • Hotpoint Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 22, 2013
Hi my condenser hotpoint Aquarius dryer TCL770 keeps beeping when drying ?? All filters clean ?? Do I need to look at the back by pump maybe .? Thanks
I also have the same dryer with a constant beeping while trying! Did as suggestion 4 and then took the back off, cleaned the heater matrix and thermostats, checked the rear draining pipes...so far so good!
Sep 15, 2014 | Hotpoint Dryers
My hotpoint aquarius TCL770 isn't drying clothes
Good evening
There is most likely something wrong with the electricity in the machine.
Kolbrun
Feb 26, 2012 | Hotpoint Aquarius WT540 Front
Hotpoint tcl 770 aquarius tripping electrics
REMOVE TOP OF WASHER AND CHECK WIRING ON FRONT RIGHT SIDE AS IT IS PRONE TO CHAFFING CAUSING AN INSTANT TRIP.
Jul 27, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
OCCASIONALLY STRANGE NOISE WHEN STARTING I DO HAVE A NEW BATTERY IN THE VEHICLE
If the noise sounds like a grinding/fast spining noise you probably have lost a tooth or two off the flywheel. To check, when it makes that noise stop trying to start it and if standard, put in gear move the car and try again. Or, if automatic put the car in R and move it. In both cases move it means like 4"s. If the noise goes away it is the flywheel teeth.
Jun 14, 2010 | 1997 Honda Civic
Hotpoint Aquarius condenser dryer model no. TCL770 . Switches on ok and can select program etc but as soon as I try to start the program it trips the electric. Any help please as to what is causing it and...
we had this, and it turned out to be the plug getting damp at the back of the dryer due to inadequate ventilation at the back of the dryer...we pulled the dryer away from the wall slightly, allowed the plug to dry out for a few days and the problem was solved.
Feb 28, 2010 | Hotpoint Dryers
Hotpoint Aquarius Model WD61 Washer Dryer working but it's noisey
If you've just installed it for the first time ensure that transporting locks been removed (big screws under usualy yellow or white plastic covers at the back side of the machine)
Make sure that machine is standing flat on the floor with no swinging whe you try to move it, this can be achieved by adjusting four legs of the machine (one at each corner).
If neither of those helps than you need to identify when the noise appears what machine is doing at that moment. If the noise appears when it's draining, pumping water out, than your machine's pump is wearing out, or if it's noisy when spining (final spin) than bearing of the drum is wearing out.
Update me about your progress
Good Luck
May 19, 2009 | Hotpoint Aquarius WD63 Front Load...
Belt tenstion
YOU CANT THEY ARE STRECTH BELTS MOST LIKE THERE IS SOMETHING WRONG WITH YOUR DRUM. THE COMMON SIZE OF BELT FOR THESE MACHINES ARE EITHER 1153 J5 OR 1158 J5 EITHER WILL DO THE JOB BUT IM GUESSING YOUR MACHINES HAD ITS DAYS. dOES IT MAKE A UNWANTED NOISE WHEN SPINING ?
Aug 03, 2006 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint Aquarius WMA56 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
