Question about Gemini Sound Products Gemini Napco Gem-p800 Security Alarm System Keypad
We just moved into a house with a Napco Gemini Alarm system. We do not have a phone line in the house, and do not wish to be monitored. We would, however, like to be able to set the alarm. But since there is no landline, the alarm #3 (communication failure) is highlighted on the screen. And, had we not silenced the keypad, the keypad beeps at all times to let us know! How do we override the communication failure and set the alarm without the obnoxious beeping? PLEASE :)
2 Suggested Answers
  • 78 Answers
SOURCE: I have a Napco Gem-P800 Security System and the
First thing its not the resistor. The resistor is there only to make sure the siren wires are ok and not tampered with. Second found this in an install manual.
Bell Test
Enter this command to turn on the Bell, keypad
sounder and keypad LEDs for 2 seconds. The
battery is tested during a Bell Test, and automatically
every *24 hours to ensure proper battery
operation under load. The Alarm output
requires a battery in order to supply the specified
output. If the battery cannot sustain the load, a
low battery indication will be displayed. A battery
test is also performed on power-up after a 3
minute delay.
if the battery fails test replace it and try again.
Assuming no programming changes were made to the zone types that would diable the bell output. if this does not help, time for an upgrade. : ( GL
http://www.napcosecurity.com/images/panels/GEM-P800_WI850a_INST.pdf
Posted on Jul 27, 2011
Telephone Comm. Failure message from security alarm
Sounds like your alarm panel is not hooked to a active phone line. FutureSmart Networks are made by Honeywell. Go to the website below and contact their support desk. They should be able to get you a operation manuals for their products:
http://www.security.honeywell.com/hsc/contacts/index.html
Mar 14, 2014 | Safety Technology Wireless Home Security...
How to change code user 1 on a gem-rp8
I am in the same boat. We bought a house with this system installed in it. How can we change the user 1 code?
Nov 10, 2013 | Gemini Sound Products Napco Gemini Gemrp8...
I bought a home with this system and need to be able to use it. Who can help me set it up?
i bought a home with a gemini system in it / i dont have the old codes can i reset this key pad
Oct 07, 2011 | Gemini Sound Products Gemini Napco...
I have a Napco Gem-P800 Security System and the horn or horns have quit working. The manual says the horn output is 12vdc, checked voltage in alarm mode,but no 12vdc. The schematic shows a 2.2k resister...
Bell Test
minute delay.
Jul 27, 2011 | Gemini Sound Products Gemini Napco...
I have a gemini home security system and do not know the access code. Can u help me?
Your system is manufactured by Napco Security Systems of Amityville, New York. Call them at 1-800-645-9445 and request that they provide you with a security dealer in your area. The dealer should be able to access the system's internal data and retrieve the user code for turning on and off your system.
Jan 21, 2010 | GE Security Simon 3 Wireless Home Security...
I can't find the manual to our gemini secruity
What is the model# Contact the Professor
AlarmProfessor.net
Dec 02, 2009 | GE Security Simon 3 Wireless Home Security...
I have a JVC TM 9060U and a JVC BR 9050U (CCTV Monitor and recorder) which interfaced with my Gemini 3200 alarm system. I can't find any diagrams or instructions for the hardwire connections provided which...
The Napco GEMP3200 Control has 2 built-in alarm outputs. One on terminals 3, 4 & 5 and the other 6, 7 & 8. The first output is normally for burglary and is factory set for 12VDC output on terminals 3(+) and 5(-). If you don't have sirens in your system you can convert this output to a dry (no voltage) relay output by cutting Jumper B on the circuit board which is just right of those terminals. Likewise terminals 6(+) and 8(-) can be used as a relay output by cutting Jumper A which is also right of the terminals. However to use this output you will have to reprogram the system to make this output for burglary also. The easiest way,if you are currently using sirens in your system, is to go to a local electronics store and purchase a 12 Volt DC relay module for about $15. Run wires from terminals 3 & 5 to your relay's + and - inputs. The relay should provide a dry closure output which you can then run wiring to your recorder. When your system alarms it will not only set off your sirens but also trip the relay.
Nov 27, 2009 | Home Security
Removed alarm system; now phone won't work
In the alarm system there was a jack called an RJ31X. This jack is suposed to have the line run from the teleco interface to it and then back out to the rest of the house(except for DSL, it stays ir front of the alarm jack). When the alarm jack was cut out the line bridge was eliminated. To make the line active find the wire that went to the alarm jack and and connect the red wire to the yellow wire and the green wire to the black wire. that should pass the line through to the remainder of the jacks in the house.
Oct 13, 2009 | Lands Phones
Simon 3 system not communicating with monitoring center. I tried a manual test of the alarm and no siren at all. New battery 1 year ago,monitoring center has no record of power or battery problem. Powered...
Todd, when you trip the system does it seize the phone line. (meaning does it cut off the plone line to your house phones.) if not you have a wiring problem. also security systems are designed to talk to the monitoring stations reciever on standard pots(annalog) phone lines, not on a dsl line with out a dsl filter. not over voip lines,. you may want to see if your monitoring station can connect to your system remotly. any good security company should be able to do this for you. if they cant you may want to look for a new company.
mj
Apr 15, 2009 | GE Security Simon 3 Wireless Home Security...
Gemini Sound Products Gemini Napco Gem-p800 Security Alarm System Keypad Logo
146 people viewed this question
Top Gemini Sound Products Home Security Experts
Lawrence Oravetz
Are you a Gemini Sound Products Home Security Expert? Answer questions, earn points and help others
