Question about Alpine CDE121
There is no sound coming from the speakers
Installed into my 1998 Toyota Corolla
    Sergeant:
  • 475 Answers
Maybe you have your wires crossed and make sure you have the volume up.
Posted on Mar 12, 2013
1998 Toyota Corolla, Fresh battery...when the ignition is on the lights come on and the radio will play...each time you try to start car...starter will not engage, but the horn will sound!
so a jumper cable start fails? (like AAA tow does) ????????
yes then
crank in neutral yeat (a/t im guessing) automatic trans.
wiggle key and PRNDL lever at same time?
no?
hot wire starter with keys in pocket crank engine, a 5min job.
Jan 26, 2015 | 1998 Toyota Corolla
No sound coming from speakers
check wiring that goes into speakers or your main speaker wires at back of stereo
Jan 21, 2013 | Alpine CDE-121 In-Dash CD/MP3/WMA/AAC Car...
Toyota corolla 2004 radio and CD player stopped working same time while driving on the highway.
have you had any speakers or bass boosters installed in your car that werent in the vehicle before you purchased. Watch for wiring issues or possibly even battery voltage issues.
Jul 06, 2012 | 2004 Toyota Corolla
I want to change my factory installed speakers on the ae100 toyota corolla. I do not know the size of the speaker
for the front door speakers,the size is 4 inches and the rear speakers are 5 and1/4 inches ok. hope this info helps.take care and good luck, manny
Apr 10, 2010 | 1993 Toyota Corolla
Transmission not sifting correctly
Automatic transmission? Check the pressure on the transmission. That really sounds like the pump has gone south on an automatic transmission.
Mar 11, 2010 | 1998 Toyota Corolla
Where is manual gearbox oil in a 1998 toyota corolla?
Shoud be two plugs in side of Trans,1st check the
upper one, If no oil comes out remove lower one,
oil should come out. Replace lower plug and fill from top til it seeps out, then replace upper plug
Dec 30, 2009 | 1998 Toyota Corolla
Need to install radio
This maybe due to the fact that all manufactured wiring harnesses installed in the corolla are standard looms, you will probably find that you do not have rear speakers installed, however the wires are located beneath the speaker grill by the parcel shelf. the standard corolla stereo only uses front speakers,but the loom has the ability to connect 4 speakers.most manufacturers always fit 1 standard loom as it is cheaper to install a full loom than make variations for different specs and models.check your stereo to see if it is used with 2 or 4 speakers. regards neil
Aug 02, 2008 | 1998 Toyota Corolla
No sound from my 2005 Corolla speakers
The likely problem is that somehow one of the wires going to the speakers has "grounded out", meaning a wire for some reason is touching the car chassis, therefore shorting out the circuit the same way a lightning rod conducts the lighting into the ground, instead of your home.
A decent car stereo installer should be able to determine the problem. Either it's grounded out, which they can use a meter and connect the probes between ground and each of the 8 speaker wires to determine -or- the radio is faulty, and a new radio can be as cheap as $150, +fit kit, + wiring harness. Don't buy a factory radio replacement because it is a huge rip off and aftermarket ones are much better.
Nov 19, 2007 | Car Audio & Video
Alpine CDE121 Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
