Question about Universal Remote Control DIRECTV Universal Remote Control
Volume of direct tv does not work with my tosihiba.
The volume with my D TV works with all my tv except my toshiba, What can I do? Ps reg cable volume works on it
    Top Expert:
  • Universal Re... Master
  • 74,383 Answers
Check to set it with an other code to your Brand TV.
Posted on Jan 22, 2013
  • Lucy Jan 25, 2013
    How do I do this?
dmathwizard
  • 113 Answers
SOURCE: Won't turn tv on & off and won't change the volume
Reset the codes using the manual
http://www.sentryindustries.com/category/remotes/remotes_rmc10.asp
If not get a new one.
Posted on Mar 05, 2008
SOURCE: direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Posted on Jul 29, 2008
SOURCE: very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Posted on Jan 24, 2010
SOURCE: need to program my Harmony880 pro to work with new
Hi.
You'll need to download and install the Harmony remote software. You can get it at http://logitech.com/myharmony and click on "Downloads".
Once you have the SW, create an account and follow the fast easy setup to get your remote working.
Hope that points you in the right direction. :)
Posted on Mar 09, 2010
  • 9 Answers
SOURCE: No Volume.
Try another remote code for that brand tv, there are many different codes for the same make.
Posted on Jul 22, 2010
My Toshiba tv goes to max volume every couple of minuets by itself
Do you have something new in the room that emitts IR signals?
You need to isolate the TV from a possibly rogue IR signal.
Try turning everything off in the room, unplug everything except the TV and Cable box if you are using one.
Turn off all the lights and turn the TV on and select a channel.
Is everything working, is the volume OK?
If you are still experiencing volume issues then this is TV problem and you will need to see a service centre or repair shop.
But if the sound is OK, then you can now start turning things on one at a time to see which device is causing your issue.
It could even be a light that is flickering at just the right frequency to cause your issue.
If it is a CFC or LED light, try a different manufacturer
Nov 04, 2017 | Toshiba Televison & Video
Volume problem--laptop to tv
I'm confused, are you trying to use a VGA cable for both video and audio? VGA cables don't have sound built into them, nor do DVI. If you had an HDMI plug on your laptop it would be best to go with that since HDMI contains video and audio.
You could just use an Aux cable from laptop to TV. Pretty much it would be a aux to analog type. It's like a speaker plugin, that side is for your computer. Then the other side coming out would be an analog red/white or left/right cable.
Another one, if your TV supports pure aux cable (it's a 3.5MM jack that speakers plug into) Like, my tv has a built in aux port for audio for my computer. So I just use pretty much a standard cable to cable setup.
Feb 24, 2013 | Toshiba Satellite Computers & Internet
The volume doent work when using the remote. I have tried the cable remote and the original tv remote and the volume works at times but less and less.
Try imputing a different toshiba code into each of the remotes. 0156, 0060, 0154. If that does not help, then unfortunately it is your tv.
May 14, 2010 | Toshiba 36A41 36" TV
My digital comcast remote will do everything except change the channel on my magnavox TV. Volume/power control is fine. How can I fix it?
your tv needs to stay on the same channel for the cable box to work with the tv and you change the channel on the cable box not directly on the tv
Jun 12, 2009 | Philips Magnavox 20MC4304 20 in....
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
My sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Dec 19, 2008 | Televison & Video
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Oct 01, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
83 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
