Question about JUMP START SYSTEM
My dad has a Power on Board jump start system that will not take a charge, can I replace the batterys?
Power on Board Jump start system model VEG012POB
  • 3,904 Answers
Yes you can replace the batteries but that is the bulk of the cost of the unit. For probably just another 20 bucks you can get a new one. Worth checking into but all you have to do is take it apart and grab the batteries inside. Batteries Plus will carry them and in most cased you can get them from auto parts stores.
Posted on Jan 21, 2013
Do you have to get the bcm flashed or reprogrmed every time the battery goes dad on a 2006 buck lucern
All systems should reset after disconnecting and reconnecting a good charged battery. However, before going any further you should remove the dead battery, have it checked and either replace it or charge it out of the vehicle. Then, install it and see if that works. If not, you probably will have to replace the BCM. Jump starting a dead battery is a very bad idea unless it is done very carefully, and even then, it can cause damage to modules.
Dec 28, 2016 | 2006 Buick Lucerne
How to use a compact jump start system
The Jump Start replaces another vehicle when jump starting. Make sure unit is fully charged. If you need a jump start because of a dead battery in your car, connect Red lead to + battery post on your dead battery and Black lead form jump start to - battery post on dead battery. Turn unit on and start vehicle.
Sep 01, 2014 | Power Center Jumpstart 11-411
Need battery charger for jump start vec021stc
If your model jump starts 12v batteries, it likely will be the same as this generic replacement charger on Amazon. http://amzn.com/B009DF2J52
I replaced mine and the open circuit (no load) voltage of the charger is from 18-19 volts. But it charged perfectly.
Mar 29, 2014 | JUMP START SYSTEM
2004 buick rendezvous loses power after jump starting, while engine idlies battery power dies. Unable to restart again unless I jump start. Also, battery light comes on. Battery was replaced 5/28/13.
Sounds like the alternator. A jump can start you but if the alternator is bad your battery will not charge and just die after you use the power you got from the jump.
Aug 04, 2013 | 2003 Buick Rendezvous
We have a 2003 dodge caravan and have been having problems with keeping a charge. the alternator has been replaced, so has the battery. several weeks ago I had driven up to 7-11 came out and it would not...
Testing the electrical circuits an componets is the way to find the problem , not guessing . Testing power an grounds . Voltage Drop Testing the Charging System Plus this charging system is computer controlled .Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model , engine size . Under system click on engine , subsystem click charging system .
Mar 30, 2017 | 2003 Dodge Caravan
LOOKING FOR REPLACEMENT BATTERY. P/N CB19-12 12V19AH BATTERY IS FOR A POWER ON BOARD JUMP START SYSTEM. POSSIBLE MODEL NUMBER VEC012POB THANKS
I have the Same problem, cheaper to buy a new jumper pack. think I paid about $49 for mine at West Marine.
Nov 10, 2010 | JUMP START SYSTEM
Batt dead jump start does not seem to charge
Sounds like a dead or shorted cell battery. Charging system is probably working but is showing overcharge since it is trying to charge a brick. Replace the battery and all should be well.
Jun 02, 2010 | Toro Lawn Mower With Toro Power Tools
1994 Chevi Lumina APV (van)
If you havent replaced the battery I would start there. If the battery has a dead cell in it then it will effectively remove the charge that your alternator is putting out causing your vehicle to stop running because it has no power. I would jump start the car without the battery hook up and remove the cables and see if it runs that way. If it does you have a bad battery.
Apr 07, 2010 | 1994 Chevrolet Lumina APV
My vector start-it elite jump starter is not holding charge even after days of charging. Why?
Hi Ydja,
The batteries on these jump boxes don't last very long. I've been through three of them. Never again.
Now I just carry an extra battery. It's more powerful and has laste longer than the three jump boxes put together.
Best regards
Mike
Dec 12, 2009 | Vector VEC010S Jump Start System 300 Amp...
JUMP START SYSTEM Logo
826 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
