Question about Refrigerators
My icemaker still dosent work after i replaced the filter
Could the line just be clogged
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Do you have a water dispenser on this refrigerator? If so does it work?
Posted on Jan 21, 2013
3 Suggested Answers
  • 1122 Answers
SOURCE: GE side by side refrigerator
DOES THE FILTER HAVE SHIPPING SEALS ON EACH END?DID YOU TURN THE WATER BACK ON?IS ANYTHING COMING OUT THE DOOR DISPENSER?THANKS-MIKE
Posted on May 30, 2008
App King
  • 55 Answers
SOURCE: my icemake does not make ice
Hello.
It sounds like it is time to replace your icemaker. It is not requesting water and it is not going to restart once it fails. The part number is 2198597 and it is about 130 dollars. You can try to look around for a cheaper price but don't buy a generic unit. You will regret it.
Posted on Jul 16, 2009
PFSF5RKZC Icemaker stopped making ice.
Most of the time is the ice maker itself that is defective. inside ice maker is an small circuit board that freezes up, if you take ice maker out and leave it overnight out to melt any ice inside the board it may work after that.
Apr 03, 2014 | GE Refrigerators
Icemaker not working
It is possible you have a speck of dirt in the ice maker water line, there is a very small jet that the water comes thru with a filter in it. I would remove and using an air tank blow out the lines in reverse to clear, also check the water filter for clogs.
Nov 11, 2013 | Hotpoint Refrigerators
Palm springs icemaker no ice
replace the inline water filter,if no filter it is clogged in the water inletfeed to ice maker,run a piece of wire or coat hanger threw it ,to break theclog up.
Dec 24, 2012 | Refrigerators
The water dispenser quit working,i can hear motor/unit turning,would a plugged refrig filter be part of problem?
Yes a clogged filter could indeed make the water dispenser not work...it too would affect the icemaker as well, is ice being made?? if yes icemaker is working yet no water being dispensed what ya need to check for is a cracked or broken line and instead of water is leaking out of it somewhere.
GENE
Sep 23, 2011 | Kenmore Side by Side Refrigerator
ICE MAKER NOT WORKING
Good day!!!!
The water filter may be plugged with sediment, or you may have low water pressure. The water pressure for icemakers needs to be at least 40 psi, and up to about 120 psi for proper operation. Water filters need to be changed every six months. If you would like to test your water pressure, we have an Icemaker Water Flow Tester available from our website. This will help you to determine if the water pressure at the supply line is high enough for the icemaker to function properly. To determine if your filter is plugged, look for water both before and after the filter. It may be hard to determine if there is water flowing through the filter. Sometimes it is necessary to pull the filter out of the feed line to see if water is flowing from the exit of the filter into the refrigerator or freezer. You can do this over a bucket to catch any dripping water. Some models have a filter bypass plug to help determine if the filter is clogged. If so, you would remove the filter and replace it with the filter bypass plug. Now test your water flow.
If your refrigerator has a water dispenser, you can hold a large cup or glass under it for 20 seconds. You should have poured about 13-14 oz. of water in that 20 seconds. If the amount is less, try removing the filter and bypassing it. If you now get the 13-14 oz. of water, the filter was clogged and it's time to replace it. If not, you have low water pressure in the line, and your icemaker may not work properly.
On occasion, the water inlet tube will freeze where it enters the icemaker. This can happen because the water is dripping slowly, or the freezer is just set too cold. A hair blow dryer can be used to thaw this, but be careful around the plastic tubing. You don't want it to crack or deform. You may want to turn the thermostat up a little bit if this is a regular occurrence. If you have a constant, regular drip, you may want to invest in a new water fill valve.
Another reason that your icemaker may not be making ice is the bail arm along the side of the icemaker. This arm must be in the lowered position for the icemaker to operate. If the arm is stuck up, it has shut the unit off. This is a safety feature of the unit. Normally, if there's too much ice in the bin, the arm will get stuck in the raised position and keep any more water from entering the icemaker. You must lower the arm to begin making more ice.
I hope this solution will be helpful...
Thanks for using fixya and don't forget to rate and write a testimonial if it is work..
Aug 31, 2011 | Refrigerators
The ice machine seems to work but the water won't fill anymore.
It could be one of three issues.
1. The water lines could be clogged with buildup.
2. If you have a filter it may be clogged stopping any water from filling the Ice tray.
3. You may have a short in the icemaker.
I would first check the water lines and/or change out the filter. This fixed the same issue on mine.
Mar 02, 2011 | Amana Microwave Ovens
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
May 30, 2008 | GE Refrigerators
Icemaker does not work
Hello Netmindr32,
You will need to replace your inlet valve. The problem is the water is slowly leaking into your icemaker fill line and freezing up. You will have a double inlet valve and the line going to your dispencer may be working fine but the one going to the icemaker is not sealing off. Be sure to defrost all the ice out after replacing the inlet valve. And please allow several cycles of your icemaker before it makes its first batch. It can take 2-3 cycles to fill lines and filters depending on your model. Lots of luck to you and please let me know if this helped you. Mca0824@aol.com
Apr 30, 2008 | Refrigerators
No Water in Ice Maker
before u call a repair man i would unplug the fridge for 12 hours about depending on weather to let ur line unfreeze if thats the problem the dispenser in the door and the one to the icemaker are two different lines so just because the door works with water dispensing doesnt mean the freezer line isnt froze over
Mar 20, 2007 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
