Question about Refrigerators
Amana Freezer Model U16W compresser wont start
Freezer won't start, there is a clicking and it sounds like it wants to start but doesn't. Stops and then tries again and again. I just shut machine off so nothing would burn out
    New Friend:
  • 169 Answers
When the clicking stops, how long does it take for it to start again?
Posted on Jan 21, 2013
  • Mike Lee Jan 23, 2013
    The clicking goes on for approx 20 seconds and then off for approx 30 seconds and then clicks again and so forth continuously.
5 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Buzzing intermittent
most likely the compressor relay is the clicking noise but i think the problem is most likely the compressor is starting to go bad and is lcoking up. if the refig is under 5 yrs old it is most likely still in warranty by amana
Posted on Dec 11, 2007
could be a relay failing, a long 2 -3 seconds hard electrical hum could be the compressor failing & the relay overload is doing it's job shutting down your overheating compressor, unplug it for 30 min plug it back in a slight hum & click off is most likely just a relay but a long hard electrical hum is bad news Compressor & if it has no warranty left on the compressor repair could run $500.00- $700.00.
Posted on Dec 21, 2008
  • 16 Answers
SOURCE: Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Posted on Jun 02, 2009
  • 2468 Answers
SOURCE: Freezer & fridge works great for two weeks
its probably the defrost heating element located just below the evaporator coil,remove the evaporator cover and check the terminals on the element,then disconnect one wire off the element and check it for continuity
Posted on May 10, 2010
My kitchen aid fridge and freezer is not cooling
have you smelled anything burning like an electrical smell or pull the machine out,remove the bottom panel and listen to see if you can hear a clicking sound coming from the compressor like every 3 to 5 minutes,you could have a bad start device located on the side of the compressor or a bad computer board,also if you remove the bottom kick panel you should find a tech sheet either tucked in the panel or taped inside the cabinet down there,it will tell you how to do some tests,when you open the freezer door,do you hear the fan running,if so i'd start at the start device,unplug the machine,remove the clip and cover on the side of compressor slide off the device and shake it,if it sounds like there's pieces rattling around in it that's the easiest way to check it
http://www.repairclinic.com/PartDetail/Start-Device/67005560/1159182
this is the new device or read out the overload and relay with meter,the compressor will probably be red hot so keep it unplugged it ain't cooling anything anyway and you won't damage the compressor
http://www.searspartsdirect.com/partsdirect/part-model/KITCHENAID-Parts/Refrigerator-Parts/Model-KBFA20ERWH00/0593/0161000/W0511068/00003?blt=06&prst=&shdMod=
here's a picture of the board part number 5 and board number W10207861,it definitely sounds like the compressor so i'd check the start device first.hope this helps
Jul 30, 2012 | KitchenAid Refrigerators
My kenmore refrigerator / freezer (model #2539338710 mfg: 4/95) won't get cold enough. The freezer & the refrigerator are both @ 49 degrees with the controls in the freezer & refrigerator
HI JOHN.both at exact same temp.sound like your motor is not running due to failure or relay or overheating due to con/fan ;cond/unit blocked or again motor.check these first good luck Ali
Jun 29, 2012 | Kenmore Refrigerators
Amana ars2464 won't make ice
first check that the icemaker is getting water
second, check the temperature in the freezer. the freezer needs to be below 10 degrees to work.
if both check out, then you need a new icemaker
May 06, 2012 | Amana Refrigerators
Amana - Top freezer model ATB1915HR. Freezer is not cooling. The fan is running. Tried increasing and decreasing cooling settings. Emptied and cleaned out.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Amana ATB1830 Top Freezer Refrigerator
I have a Kenmore side by side, model#106.52572. My power went out Wednesday night and the freezer & refrigerator sounds like it's running but it won't cool and the icemaker even sounds like...
heatman101
Aug 26, 2011 | Kenmore 57029 Side by Side Refrigerator
Amana ABB222DE is the overload/capacitor the same thing as the compressor relay? I just had the compressor relay replaced in amana bottom mount. Frig cools fine but every 2 days or so buzzing noise...
I have been doing refrigeration for over 30 years and I have never seen a compressor with a chip inside of it. Have you tried cleaning the condensor coils? I almost sounds like you have a weak start capacitor. Let me know if i can help you any futher.
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana bottom freezer not working on model abb2524deq
I replaced the solenoid and my ice machine starting working again.
May 02, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Dec 09, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
