Can't get full power
Only get half power
    Genius:
  • 1,003 Answers
Replace power supply
Posted on Jan 22, 2013
Dash gas gauge stops showing proper gas level once it hits half a tank. Then gauge will fluctuate between empty (light will come on), full and anywhere in between but seems fine from full tank to half
If the trouble with the gauge started after you worked on it then you likely damaged or created a restriction to the movement of the sending unit. You will have to remove the tank and double-check your work.
Mar 01, 2013 | 2000 Buick LeSabre
Fridge is working intermittently just stops working when it's full, sometimes not even half full.
Have you checked for blockages if you have and there is none then your thermostat could on it way out
Jan 24, 2013 | Refrigerators
What makes the bike spit and sputter then get full power for a bit then go back to spit and sputtering
check your shutoff valve on the tank you might have a small piece of junk blocking it inside your tank...easy way to tell is when you have loss of power stop and shake bike side to side
Sep 08, 2012 | 2006 Harley Davidson XL 883R Sportster
Yamaha waverunner gp800r missng
Just a thought, take the covers off the power valves(small squareish plates,port side of cylinders) and make sure the things inside there are all in tact, connected and moving freely. you may have to disconnect the link bar and pull the port raiser out completely to ***** its condition.
Aug 22, 2012 | Water Sport
Ok, I have a half size GE 30 amp tandem breaker I want to install in place of a full size breaker to make room in my box. If I move it down one opening it will fit in, but not in the origional place of the...
Yes, but you should put in another half size breaker even if you don't use it so that you don't leave a hole in the front panel, unless you can find a half-size cover instead. I am puzzled about why the half-size breaker won't fit in the original spot. Maybe you are replacing a pair of full-size breakers that are linked together to provide 220V? If that is the case DO NOT replace these with half size breakers. Good luck.
Aug 05, 2012 | Electrical Supplies
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
When i press power botton half way works when i press full sometime work sometime don't
the switch is bad and would need replaced. MAKE note of the wiring if you attempt to do this yourself. Get back to me with the brand and model number and I will try and find you a parts source and breakdown.
Jan 24, 2012 | Drills
I've had a severe loss of power. There is vibration through the gear stick. Feels like lack of fuel, but is still half full. Won't go more than 30 mph.
Hi, Vibration, It could be the drive shaft is not strait anymore. Replace it. Also check you tires that they are ballanced properly. Good luck
Jun 27, 2011 | Land Rover Discovery Cars & Trucks
My copier is having a system error E-805
E805 0000 Fan failure
only one in this copier>
The fan is faulty. -
Check the fan connector.
- Replace the fan.
- Replace the DC controller PCB.
Switching between full-speed rotation and half-speed rotation is controlled as described below.
1) Full-speed control
When the CPU on the DC controller outputs a fan full speed signal (FAN_FULL), the fan drive voltage switching circuit supplies a +24 V fan drive voltage to turn
the heat exhaust fan at the full speed.
2) Half-speed control
When the CPU on the engine controller outputs a fan half speed signal (FAN_HALF), the fan drive voltage switching circuit supplies a +16 V fan drive voltage to
turn the heat exhaust fan at the half speed.
E805-0000 (Main body fan error)
When the cooling fan of the main body starts, the fan lock detection signal (FAN_LOCK) has been held at the "H" level for longer than the prescribed time.
also check your low-voltage power supply
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Canon iR 2016i Black and White Copier
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
