Question about GE Ovens
Hookup for large burner for general electric model j as03 002ad stove
Wiring to large burner reattached but which wires go to burner to attach?
  • 178 Answers
SOURCE: Whirlpool electric stove
The ideal thing to do, would to be to replace the elements themselves. Most heating elements for stoves are universal and can be bought at lowes stores. I found your model number specific burner elements on a supply website for 42.00 each on the 8 inch and 35.95 each on the 6 inch elements. I am almost certain, you'll find these parts at lowes or home depot much cheaper. If this doesn't help, let me know, we will try another route.
Posted on Apr 15, 2008
  • 10865 Answers
SOURCE: Gas oven electrical hookup issue
Hello. I can help you. What you have there at the wall is a circuit with 120 volts of power available. Your Gas oven requires 240 volts of power, thus the additional [red] wire. That said, they do not match up.
You will have to run a 240 volt wire from your electrical panel to rear of your stove opening with the correct circuit breaker in the panel, the correct amperage wire to the stove, the correct receptacle for the stove and the correct plug on the stove.
This is serious electricity here so do not proceed on your own as you could get seriously hurt or worse.
Posted on Aug 02, 2009
SOURCE: Electric Diagram for Kenmore Model 790
I have a Kenmore Model 790.91062601 and it has stop heating. None of the burners or the oven will heat. Any solutions
Posted on Aug 30, 2009
  • 220 Answers
SOURCE: Im putting in new stove. i have 3 wire(6 gauge)
You should have three terminals on the back of the stove the middle is neutral if you measure from the line on the left to the line in the center you should get 110 and the same from right to center.test each line from the stove to ground if you have power on the middle one it is hooked up wrong.
Posted on Sep 16, 2009
  • 250 Answers
SOURCE: Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
Posted on Jan 26, 2010
No stove wires hooked up to neutral
The older electric hookups for ranges used only the 2 hot wires and a ground. Somewhere on the range the neutral and the ground should be connected together. This connection is no longer accepted by the National Electrical Code, but no one is going to force you to change the wiring unless you change the range.
Where is the ground wire attached? Some ranges had a metal jumper to connect the neutral to the ground. Your oven element is 240 volt only. It does not need a neutral. The ground/neutral wire is for some of the controls and the clock.
Aug 13, 2015 | Kenmore Stove / Oven / Range Bake Element...
The gas in the oven goes on then off
follow this instruction. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Ovens
I walked by my stove and noticed heat coming from it and I opened the oven door and heat was coming from it. I did not turn on the stove top burners or the oven when I noticed it. The switch was OFF. I...
You most likely have a problem with the temprature contol knob and the thermostat.
This is all contained in one unit. The controller has a long metal "wire" that sends the temp info to the controller. The "wire" ends inside the oven.
This whole assemblage needs to be replaced.
I would need the type of stove, gas or electric age and model to give you replacement directions
Jul 01, 2011 | Ovens
My four burner electric stove top is not heating properly. When I put it on simmer it goes way too hot on all the burners? The switch? The thermastat?
need model # not a common problem when all will do that, if only one bad burner switch but when all do that could be shorted wiring
Oct 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Aug 02, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Jul 23, 2009 | Ovens
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
We have a frigidaire stove. The bottom element has broken in two. We have purchased the new element but cannot locate our manual to show us how to install the new element. Can you give us instructions?
Hello the first thing you do is unplug the stove before doing anything ,open the oven door remove 2 screws holding the element to the back wall pull element forward remove wires with insulated pliers attached to the element ,reattach wires to new element resecure to back wall and test. good luck
Dec 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Stove
Go to page 8 here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=JKP15AAAA
Essentially, you need a 220 volt hookup kit from any hardware store. Match the plug to your outlet. Several styles are out there. There are three wires in the cable. Knock out one of the holes in the box on the oven. Install a strain relief for the cord into the hole and clamp on the cord. Generally, they're in the kit. The Red and Black wires are 'hot' and white is neutral. The connections are labeled on the stove. Make sure your connections are neat and tight.
Dec 05, 2007 | GE JKP15 Electric Single Oven
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
55 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
