Question about McCulloch Garden
Diagram throttle cable mcc1435a
Routing trigger to carb
4 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: i hace a muccullock mcc1435a
Look at eReplacementParts.com and the parts diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 15, 2010
  • 2239 Answers
SOURCE: I replaced fuel and carb
It is quite difficult to explain exactly how it fits, the cable always looks too long and has to curl around on itself back to the trigger, the picture shows quite well how it goes, the end of the cable with a dog leg in it goes to the carb, as far as i remember it goes to the upper hole in the carb spindle, just push it into the hole and turn through 90%, the other end fits into the throttle trigger.adw1_9.jpg
Posted on Sep 10, 2011
latinoboytx
  • 46 Answers
SOURCE: I can not reassemble carb cable/trigger mechanism
heres the parts ipl should help
http://www.poulanpro.com/ddoc/POUI/POUI2008_AAaa/POUI2008_AAaa_PP4620AVX_952802146.pdf
Posted on Sep 23, 2011
How do I connect throttle cable to throttle trigger?
Search for online manual, that has the diagram, showing the location the end of throttle cable at the trigger. You will have to take apart the handle assembly, to access the cable and trigger.
Nov 05, 2015 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Throttle connections on poulan pro 210 chainsaw
The precision bent throttle connecting rod can only go in one way CORRECTLY.... if it has to be forced or bent, stop and figure out the puzzle before any damage is done.
I'd suggest placing the carb temporarily on the mounting studs on the side of the cylinder. Don't install the filter and nuts etc yet. Take the throttle rod and lay it in place this way and that way until it looks like it matches the trigger end AND the carb end. Usually the carb end has to be installed on the carb while it is removed from the engine as tightness of space won't allow moving it all over to poke it in the hole. Once it is on the carb and you are sure of the orientation, slide the carb once again over the studs and lay the throttle rod by the trigger.
You need about three hands to hold the trigger, trigger lock, trigger return spring and the handle together while you figure out how to snap in the top of the handle and start a screw under the handle.
Jun 20, 2014 | Poulan Garden
I replaced fuel and carb lines on my Poulan 2450 chain saw. I cannot seem to find the correct path/attachment for the throttle connection. Parts diagrams do not show this. Can someone provide a diagram...
Sep 10, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need a diagram for the path of the inner throrrle cable.
throttle cable goes around the metal guide and then under the wire loop and then push the ball up into loop, try your throttle to make sure it doesn't bind when it's hooked up... the cable will ride on the little round cover (metal) then set in the u in the rod from trigger. long as it moves freely and has the carb range , it's good
Aug 21, 2011 | ECHO, Inc. PB-251C Handheld Blower
How to install throttle cable for c77 motorcycle need routing of the cable
Keep the bends gentle. Go from the grip toward the tank down under the tank to the carb.
You may take the tank off and route cable beside frame. If the old cable is there well follow the same route. After you install cable insure that it works freely.
The other cable will lay beside the throttle cable.
Feb 04, 2011 | Honda CB 100 Motorcycles
How do I adjust the throttle cable on a C430 String Trimmer? When I depress the throttle cable, the linkage on the carburetor only moves about 1/16 inch and will barely turn the cutting head.
The throttle cables aren't adjustable. Make sure the other end is on the trigger correctly and that it is routed through the handle and the engine cover correctly. Also, make sure the throttle shaft and throttle plate (inside carb) are free and easy in their movement with the throttle cable off. The engine idle speed adjusting screw may be in too far also. Back it all the way out and then back in with the throttle closed Once the speed screw touches the throttle lever (what you hook cable into) on the shaft, give it about 2 turns in. This is about all you can do. If the cable is stretched badly (rare), it would need to be replaced.
Oct 26, 2010 | Ryobi Garden
Idles at full throttle
Be sure the throttle cable is routed correctly and is not being stretched. When disconnected from the carb, does the inner throttle cable operate freely? Lubricate it. Also check that the cable connections at throttle and carb are seated properly. Does the slide move up and down freely? Remove the air filter and twist the throttle while looking inside the throat of the carb. LIGHTLY seat the throttle screw and the air screw then open each of them one and one half turns outward.
Aug 02, 2009 | 2002 Honda CR 250 R
Replaced throttle cable on pw50 but can't seem to get it adjusted
If I understand your problem correctly this may help. There should be a spring just a bit smaller diameter than the slide that mounts between the top of the slide and the bottom of the carb cap. No spring means no snap-back. I am assuming there are no kinks in the cable and the cable was routed correctly when installed. Lots of times if the cable is not routed properly the gas tank will "stretch" the cable when the tank is re-mounted. Route the cable properly and the problem goes away..... As far as the slack in the cable, there is a an adjusting screw on the top of the carb (where the cable ends) and an adjuster screw at the hand throttle also where the cable ends. Some bikes have an extra adjuster mid cable but I don't think yours does, (working from memory here). If none of the above work then my guess is that the parts counter handed you the wrong part.
Mar 14, 2009 | 2000 Yamaha DT 125 R
Throotle sticking on my FE400e 03 model
Hi ..... The majority of throttles close with the use of a second cable and/or the return spring on the carb. Make sure you have approx' 0.2 of a movement before throttle starts to open, second cable (closing one) is 'tight', it can be adjusted at bars and carb and that the cables are correctly routed (manual will have a diagram). Try lubricating cable(s) and throttle tube on the bars. It'll be something simple .......... let us know how you get on.
Dec 22, 2008 | 2000 Husaberg Fe 400
Garden Logo
155 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
