Question about Canon PowerShot G9 Digital Camera
I'm reposting because fixya said it had solution, but it was for someone elses question. There's was stuck open, but making a chugging noise when the lens was trying to open. My camera has the
    Genius:
  • 1,019 Answers
Sounds like the drive motor assembly has quit. this needs to be repaired by shop, probably had nothing to do with the cold.
Posted on Jan 25, 2013
3 Suggested Answers
SOURCE:
  • 11967 Answers
SOURCE: it states lens error, restart camera
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 11, 2010
SOURCE: Lens error
Powershot S3 IS: lens error message, lens juddering on startup but not coming out. Tried all tricks on internet without success, so decided to dismantle camera. Localised fault to optical position encoder on first transfer gear of the ultrasonic motor which controls lens position. Sensor was misaligned and/or dirty, so the camera could not detect motor rotation. Removed sensor, cleaned it, glued back in position with cyanoacrylate glue. Reassembled camera (only one internal bolt left over - not bad!) Working 100% again.
Posted on Jul 29, 2010
MY washer fills, sometimes stops without completing the wash, sometimes it shows a completed cycle but the clothes are too wet to dry, sometimes during a cycle it will turn off with the door locked.
Sounds like a draining problem - Check the drain filter isnt blocked, if fitted before doing anything else - remove the filter and clean it. Then, can you hear the drain pump running on the drain cycle (drum not moving but pump should be) - a chug chug chug noise and water should be flowing down the waste pipe. Door WILL lock if the machine is full of water or is slow to drain - to prevent floods. Do NOT force the door open without draining - you will only break the door handle.
If water not flowing on drain - and filter clear - may be blocked pipe, sock stuck in sump hose - coin or counter flipped on edge in a pipe and blocking it - something like any of the above. Clothes too wet to dry is classic partially blocked drain pipe symptom - or spin aborted as drum out of balance.
Feb 01, 2018 | Washing Machines
Frigidaire refrigerator makes chugging sound
Hi - Generally speaking, it is normal for Frigidaire refrigerators to making a vibrating, snapping, dripping noises however not a chugging noise. From what you have described it sounds like it could POSSIBLY be the drain sucking in air or it could be refrigeration through the evaporator. A constant noise could indicate a serious problem with one or more components. This is a repair that should be left to a refrigerator service expert.
Oct 16, 2012 | Refrigerators
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
Amana Dryer LEA30AW
usually the humming sound is coming from the motor,try this,open the door,turn the drum with one hand and hold the door switch in with your other hand and have someone else push the start button at the same time,this might help the motor turn on but if it does you need a new motor,if you can't turn the drum you could have something stuck in the blower wheel or something jammed in the motor like a broken belt but like i said a humming sound is usually the motor.
Feb 22, 2012 | Amana Dryers
Mower makes chugging noise like it's gonna stall
Check the air filter to see if it is clogged. If you can park it somewhere that does not kick up dust or grass, then you can remove the air filter and then start it and see if that is what was keeping it chugging. If running smooth, tie the dead man lever or get someone to hold it and then slip the air filter back in place, if it chugs you know that is what it is and just needs replaced.
I hope this helps.
Jul 20, 2011 | Mtd Garden
Hi have 1992 cressida, water running out at rear of engine around gearbox, also making a grinding noise, any idea of what may be wrong? also can someone email manual to jimbo_james2001@yahoo.com.au.
water running out between motor and transmission can be a freeze out plug rusted out or a frozen motor block, by rules at fixya.com can't e-mail you personally,but you can repost any questions you may have.the grinding noise may be a blown engine. sorry for your trouble,but all diagnoses are not the same please just repost your problem,an expert will be happy to assist.thank you for choosing fixya.com
Dec 28, 2010 | 1991 Toyota Cressida
2002 Saturn Vue automatic. upon acceleration it makes really bad sounds like a sewing machine "chug-a-chug-a-chug-a-chug" and very fast. It seems to lack power when accelerating. When the vehicle is up...
I had a similiar problem and actually my gear changer in the car was getting hard to move and eventaully stuck.turns out the gear changer was only moving the gears part way and created a wierd sound.Anyway my mechanic found a new gear changing mechanism and installed it .Since then no problems---thank God.
Aug 15, 2010 | 2002 Saturn VUE
'Chugging' noise when trying to get flow of water from steam tube
You must press the hot water/steam button to make sure it is set on hot water. The chugging noise is the pump slowly putting water through the steam boiler for steaming. When you open the steam knob make sure it is all the way open, you will hear the microswitch click when you reach full open(test it out with the machine off). Red light also means heating and low on water, since you are using all the steam faster than it can make it hence the red light.
Jun 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Canon PowerShot G9 Digital Camera Logo
124 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
