So I don't see any issues with the shocks. When I manually turn the drive shaft, it makes a lot of noise. Like the inside drum is out of aligment
  • Washing Mach... Master
  • 17,129 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 22, 2013
  • 1122 Answers
SOURCE: My kenmore front loader makes a knocking when it spins.
how old?sounds like the bearing are going bad,on yours the tub and bearing are one unit,so you have to change out the whole thing-mike
Posted on Mar 24, 2009
barkencoa
  • 3463 Answers
SOURCE: Drum makes grinding noise when turning
Hi.
spin the drum by hand, if it feels rough or is noisy, then you probably have drum bearing failure.
Another possibility is one or more of the drum paddles may have come adrift..
These can be replaced.
Posted on Nov 24, 2008
SOURCE: drum seems out of balance, lots of noise even
Chances are you have a rear bearing either gone or on it's way,had the same problem with mine manufactured in Apr. 2000. I am getting a repair price but I think replacement is more lodgical
Posted on Aug 06, 2009
  • 4090 Answers
SOURCE: Rubbing noise on front load washer drum
dont they have 4 shocks?
the drum is imbalanced i would wager
Posted on Aug 18, 2009
heatman101
  • 43501 Answers
SOURCE: Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Apr 15, 2010
Testimonial: "Ok that was my guess. That answer was lightning fast. Thx you very much. Will remove it. test it and post if the problem is fix. Thx again"
My terios 2006 make tiny noise on front left shock while drive off road
check shock bushings and shock shaft play, the shaft that moves up and down inside the shock and is attached at the top mounting, as a problem with either can cause a noise.
Dec 17, 2014 | 2006 Daihatsu Terios 1.3
Loud banding noise in my LG Tromm DLE7177
Check this link :
Feb 11, 2013 | LG Tromm Electric Dryer
Kenmore 970C45042 10 washer makes tremendous noise.
Check this link :
Feb 11, 2013 | Washing Machines
My neptune washer won't operate. The lights come on and won't shut off
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mountingis also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Now in this case the failure of the motor drive or the agitator shaft could have resulted in total failure of the spin cycle. Now remove the panel and check manually the movement fo the motor and the main drive, if the shaft is struck up or if the motor bearings/bushes are worn out. It is important to check the voltage on the motor as the absence of the voltage means that the controller has some fault - possible failure of the drive after a heavy load of the malfunction.
Thank You for using fixya
Dec 02, 2012 | Maytag Neptune MAH5500B Front Load Washer
I have a Westpoint Frontloader washing machine. Everything goes well untill it starts spinning. Then is starts shaking and there's a lot of noice. We did make sure that it is level. What else
It is so common that the washing machine can maketerrible noise in many ways and is a common fault. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that machine isvibrating when it is running then the motor /drum suspension has to beinspected. Since these fittings are located on the underside of the machine itis important that you look for the noise with a good inspection lamp. Manuallyturn the motor and drum and listen for the noise, if so the motor bearings, thedrum agitator shaft and fittings must be checked. Also the suspensions whichinclude the shock absorbers and springs, the body clamps must be checked to bein correct alignment and not changed in position. Tightening of themounting is also very important. Finallyin most cases a drop of OIL or smear of grease on the moving parts cane solvemost issues.Check this link :http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlFor replacement of bearings check for tips on thisvisual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jul 05, 2012 | LG Washing Machines
Front panel makes a loud vibrating noise when operating
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.The noise seen on the front panle is due to vibration from the motor drive
Sep 24, 2011 | LG DLG7188 Gas Dryer
Drum makes a lot of noise when turning worst on spin
Sep 06, 2011 | AEG Washing Machines
THERE IS A LOUD SQUEALING NOISE ALL THROUGH CYCLE. HELP! IT WORKS, BUT I CAN'T STAND THE NOISE! MAYTAG NEPTUNE MDG9700AWW
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 25, 2011 | Dryers
The washer makes a odd noise and tries to rotate the drum during the filling, wash and spin stages. The drum does not turn, the motor sounds like it is running, the pump runs, it fills with water, just no...
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. If the belt is worn out or is loose or damaged then it will not turn the drum but make noise. so this can be an issue in your case. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Jul 13, 2011 | LG WM0642H Front Load
My front loading ge adora washing machine makes a lot of noise on the spin cycle
Jun 15, 2011 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
