Question about Compaq Presario CQ60-220US PC Laptop
I have a HP Pavilion g series laptop. The laptop was working fine, I closed the lid for a few minutes and it turned itself off and will not come back on. WHY?
I have already tried with power cord, taking the battery out and using only the power cord.. I simply don't know what else to try!
  • Compaq Master
  • 27,725 Answers
If your laptop won't turn on, you could have any number of problems. The problem might be a genuine power issue derived from either battery failure or simply a loose AC adapter. Conversely, it may only appear to be a power failure, and the problem may lie with another component. Errors in brightness settings and LCD display malfunctions can both make a laptop appear to be powered off, and all these problems will need to be corrected. Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings. Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet. Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary. Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover. Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced. Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver. Pop off the bezel carefully and remove it. Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too. Disconnect the inverter cable, which is plugged into the inverter. The inverter is located just beneath the display, at the bottom-center of the laptop. Then, pull back and slide out the old display, and replace it with the new. Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place. Replace the bezel screws. Hope this helps.
Posted on Jan 21, 2013
  • 4 more comments
  • nana_deb
    nana_deb Jan 22, 2013
    Thanks, but its not the monitor - - the laptop is not powering on. Any help there?
  • Brian Sullivan
    Brian Sullivan Jan 22, 2013
    have you checked or cleaned the battery Plug the adapter into the wall outlet or power strip. Most laptop power adapters have a small LED light; the light will illuminate when power is being transferred from the outlet to the adapter. If the light illuminates, chances are you have sufficient power to supply your laptop. Wiggle the power cord if the LED light did not initially illuminate. If the light turns on and off when you wiggle it, you might have a loose cord in the adapter, or the outlet could be faulty. Plug the adapter into another power outlet, preferably a different circuit in another room, if the LED light did not illuminate the first time. If it lights up from the second outlet, the first outlet either does not work or other devices were using too much power on the initial circuit.Connect the other end of the adapter to the laptop and turn the laptop on. When the computer starts up, you should see an indication of how the laptop is being powered in the lower right-hand corner.If you see a battery icon, then the laptop is being powered by the battery, not the adapter. Make sure both ends of the adapter are securely connected. If they are, and if the LED light on the adapter is lit, then you likely have a faulty wire that is not properly connecting to your computer. If you see a plug or adapter icon, then the laptop is successfully being powered by the adapter.
  • nana_deb
    nana_deb Jan 25, 2013
    I took the thing all apart and cleaned everything I could - - YEAH now it comes on and powers on and off just fine!! But NOW, I can't get the WIFI to work - the red light is on, but I can't get it to turn green, or find the router - any help out there???
  • Brian Sullivan
    Brian Sullivan Jan 25, 2013
    Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look (((·))) Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. Select "View Available Wireless Networks." Select the wireless Internet connection you want to use. Wait for the laptop to connect to the Internet. if still no connection Click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. if still cant connect Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
  • aseidner Jan 25, 2013
    I am going to guess a bad connector in the laptop or a bad cable near the laptop on the power cube.
    O sorry I see you get it to come on, Alan S.
  • 883 Answers
SOURCE: My laptop armada m700 gets no power
the hard drive was damaged. Inside the drive, the tiny moving head took the hit. They really are not designed to take shocks like that. Many laptop mfgrs offer "industrial" duty laptops that have on-board shock absorption suspension for hard drives.
Posted on Aug 26, 2007
SOURCE: Lap Top Automatically Goes into Stand By Mode
needs either a new battery or power cord
Posted on Nov 06, 2007
  • 56 Answers
SOURCE: HP Pavilion ze5300 laptop/ Charge light on, when I try to power up it goes out and I have to reset to get light back. No boot
can you boot with the AC adapter? maybe the battery is completely dead.
Posted on Jan 05, 2008
SOURCE: My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Posted on May 30, 2008
rockitman187
  • 2559 Answers
SOURCE: Laptop Doesn't Turn On At All
To take out of hibernation,press the power button for less than 1 second.
Then go into the control panel and disable hibernation as described below.
Disable the your mouse's "ability to wake up computer" in device manager.
Use keyboard to wake up your computer.
Click Start > Control Panel > Performance and Maintenance > Power Options > Hibernate tab.
Then clear the Enable Hibernation check box.
If this doesn't resolve the issue,Please post back.
Please rate this a fixya.
Posted on May 17, 2009
Where is the lid close swith located when looking directly at the hp pavilion laptop dv2000?
Not sure on that model but if it has a visible switch it's near to or underneath the hinges, the right one usually.
Feb 08, 2012 | HP Pavilion dv2000 Series Laptop Full...
My hp pavilion ze5200 isn't turning on
1- open back lid and evolve the battery.
2- wait 15 minutes and put the battery.
if doesn't work:
put a valid battery in your notebook and turn it on.
and if doesn't work again:
i'm sorry to tell , surely your notebook is damaged so take it to a guarantee center.
Jan 08, 2011 | HP Pavilion dv6000z Notebook
When I turn on my HP dv9000 I get a constant loud beep. have to hit escape button to stop it several times
Re: dv2000/dv6000/dv9000 recall ubatz - Just got my laptop back from repairs a couple of days early. Cosmetically it's perfectly fine.
I kept the easy peel plastic on the lid, had an extra one and covered all around inside the keyboard (but not the keyboard itself). Got a page that says the LCD cable was fixed.
The rubber circles at the bottom of the LCD panel are pushed in at an odd angle but I'm afraid if I try to move them back, they're going to pop backward and disappear altogether behind the LCD.
I did order my Vostro last night and changed my sig file a few minutes ago to remove the DV9700T from it.
I haven't turned it on yet. Mixed emotions. Ah well.
Oct 21, 2009 | HP Pavilion dv9000z Notebook
Tightening HP Pavilion DV9000 17'' LCD Hinges
you may find the hinges parts from eBay which is cheaper price:
http://shop.ebay.ca/?_from=R40&_trksid=m38&_nkw=HP+Pavilion+DV9000+hinges&_sacat=See-All-Categories
how to replace your laptop hinges:
1) take out the screws at back of laptop under the hinges base
2) or take out the screw at side of laptop near the hinges base (if you find any screw there)
3) there are two cables connect between LCD lid and laptop base
you do not need disconnect those canbles. just careful them
4) take out all scews on the front of lid cover( the scews is covered by thin plastic cover), then take away front lid cover.
5) take out the screws at beside hinge base and side of LCD panel(2-4 scews at one side), you need check the back of lid cover can separate to LCD panel a little., be care replace only one at one time .
6) put back all screws step by step.
hope help you fix it, please take a rating let me know how much you are helped, thanks! any question please let me know!
May 18, 2009 | HP Pavilion dv6000z Notebook
Locks screen when I close the lid on my hp pavilion dv9740us
computer has gone into hibernation. Best to shut that function off, and replace with standby.
If you want it to hibernate, press the power button once, and it should come back on to the log in screen.
Mar 14, 2009 | HP Pavilion DV9740US Laptop
Pavilion dv 1000 won't reboot, stand by nor turn off
I had this kinda problem solved on a Acer 5920 LAptop. The webcam driver was the culprit. Remove the cam driver for the same, the windows driver will take over and then i guess it will work fine. I figure its a driver issue or a TSR program not quitting. If this fails try uninstalling recently addes program or driver.
Jan 05, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 works fine on CRT but no LCD screen
Sounds like the LCD backlight or inverter went bad. More probably the inverter,and that's good because,of the two, it's usually cheaper and easier to replace.
Before considering those,check the lid switch to make sure that it is operating correctly and not stuck down.
Ron
Dec 10, 2008 | HP Pavilion dv1000 Notebook
Lid switch location??????????
HP DV 5000 LID switch location is here:
If You want test lid switch, just connect A+B together for a monent!
If the monitor flashes on...? Lid switch is faulty.
It is too dificult to change the lid switch, so the easiest way is connect these pins together forever. :))
Dont forget to turn off your notebook... he wont sleep anymore ;))
Greetings from Latvia.
lauris@bttehnologijas.lv
Feb 01, 2008 | HP Compaq Presario V5000T Notebook
The screen goes blank at start up
If you can not see anything, then it may be your inverter (Replacement part cost is around $50.00), if you can see a dark image then your CCFL (Cold Cathode Fluorescent Lamp) is out. (Replacement part cost is around $15.00)
Check websites like http://www.ccfldirect.com/
Oct 16, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
Compaq Presario CQ60-220US PC Laptop Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
