My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
this is a fault code 43 which mean the out of balance switch is either faulty or the switch isstuck in the on positionfree up or replace switch which is located just under the main board
It can be due to fault in the program controller, it can be fault in the spin motor- if the common motor has a separate high speed winding the fault can be the failure of the winding.
Also the program drive is also a suspect within the program controller unit. The beep comes as the program is not advancing showing an error. So check these factors.
See Phoebe 112 latest solution! This is a common problem with these washers. For a quick fix you can usually get it going again by unplugging it for 30 mins. so the computer will reset. You will hear a slight buzzing noise when it resets. If it keeps doing it, go to the comment for Feb. 14, 2009 and try that if you are handy. Unplug the machine before doing any of this as with any machine that is electric or you will probably get the shock of your life.
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
You said, your Bosch dishwasher on auto wash will stop functioning in middle of the
cycle start beeping and there is an icon of a faucet on the display.
What is your model number and the year of the dishwasher?
You might have the end of cycle setting turned on. It will beep to let you know that the washer is done. Can turn off, under options on the control panel.
