Question about Refrigerators
So water leaks out onto floor-Jennair side by side
Freezer drain pan frozen causing water to leak out onto floor daily.
What prevents Drain pan fron freezing normally?
  • 700 Answers
THERE IS A DRAIN LINE HEATER ON MOST UNITS now days, if yours is an older one what you need to do is make sure that it's level, and that the drain line is cleared so that the water has a place to go when it thaws during the defrost cycle.
Posted on Jan 27, 2009
Kenmore refrigerator model 363-58572892 side by side refridge/freezer. Water is appearing on floor in fron of freezer side. Appears to be coming from ice maker. Crack in cce mold? Clogged drain? filling...
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 29, 2011 | Kenmore 64802 Top Freezer Refrigerator
Lately there is a pool of water forming under and in front of the refrigerator . what can we do. It is a side by side Jennair?
Gene
Aug 12, 2011 | Jenn-Air JCD2389G Side by Side...
New whirlpool ED2GVEXVD side by side. Water leaks onto floor periodically. Water coming from door is not cold. Also, it is noisy. Any fixes
HI,
Recently, I ran into a wave of broken drain pan for the defrost water. When this occurs, the water leaks out on to the cardboard under the unit, causes the card board to warp and come in contact with the fan motor to cool the compressor. If this is so, you can either replace the pan or seal the pan with tape to prevent it from leaking. I have also notice the water valve is located above the drain pan too, if you have a leak it will over fill the pan causing the same problem. Those are the two easiest places to check first. You can remove the grill from under the doors and use a flashlight to see if water is under unit.
Lastly, is there water on the freezer floor? If so the could be a clogged drain tube in the freezer section.
I hope this points you in the correct direction..
Jul 27, 2011 | Refrigerators
Water is leaking onto the floor directly under the freezer of my side by side g.e. refrigerator. Water is frozen in bottom of freezer floor. Is this a costly fix? Refrigerator is 10 years old.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking onto the floor from freezer drain...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. .
Sep 20, 2009 | Freezers
Water is leaking into back of freezer and out onto floor jennair 2389 (lg)
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Jul 07, 2009 | LG Refrigerators
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from freezer
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from comming out the freezer door and leaking onto your floor and running down your copper pipe to the basement.
May 12, 2009 | Hotpoint HSS25GFP Side by Side...
Smeg fride freezer leaking
HI Mark,
The evaporator drain is blocked causing the defrost water to pool, freeze and then leak onto your floor.
Clear out the freezer, then use a hammer to break up the ice on the floor. Now remove the rear panel. You'll see more ice build up. Don't use the hammer on it! (Too close to the coils for comfort) Use a hair dryer to warm up/melt the ice below the coils.
You'll see the drain hole now. Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
SG
Mar 27, 2009 | Smeg FA561X Side by Side Refrigerator
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Refrigerators Logo
299 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
