Question about Home
Shower and tub made togeather - Home
    New Friend:
  • 169 Answers
Please provide more detail of what the problem is.
Posted on Jan 22, 2013
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Danze opulence diverter handle does not work
you have to replace diverter....if its in the tub spout unscrew and go to lowes or plumbing supply and match up style and replace...use pipe dope and screw back on tight...good luck
May 01, 2012 | Danze & Single Handle Tub And Shower...
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
My Moen Tub and Shower have water coming out of both the tub and shower when I turn on the tub.
Take the handle back off and rotate the stem one half turn clockwise and put the handle back on.
You'll be good to go!
Mar 05, 2011 | Moen & One Handle Tub & Shower Faucet
When lever on tub spout is pulled up for shower use some hot water still comes out of the tub spout...reducing water pressure and temperature of water coming out of the shower head... Tub spout does NOT...
2 things can be happing here depending on the age of the tub spout. If the spout is more than 5 years old, you may need to replace it. if not that old then you may have a screen filter blockage in the shower head itself. remove the shower head from the shower neck and see if there is anything in the filter. while you have the head removed, try the tub spout again and see if problem continues. this should guide you in the next step to either replace the tub spout or just clean the shower head screen filter. Hope this helps.
Dec 29, 2010 | Cifial 295.604.625.SO Polished Chrome...
At what height is the shower rough in body installed
I set my valve were it feels comfortable when i stand up in there tub or shower.Most people shower any way.. the one sitting in the tub can still reach it I usually set shower valves at 42 to 44 inches and the shower arm at 74-78. You want it I usually rough the tub and shower valve spout at 4" above the tub rim, shower valve 10" above the spout. This is for tub and shower combo.
Aug 08, 2010 | Delta & Single Handle Shower Faucet
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
1 HANDLE TUB/SHOWER. WHEN YOU TURN THE SHOWER ON
The diverter is worn and needs to be replaced.
The diverter is the lever/button you pull/push to switch from shower to tub. When they get worn, they require more pressure to seal properly and divert the flow.
Aug 06, 2009 | Delta T13420 Chrome Classic Single Handle...
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Home Logo
23 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
