Question about Exercise & Fitness
Aspire tredmill stops working suddenly and has error message e1
    Top Expert:
  • 12,223 Answers
See the detail and fix it.God bless you
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
However test the s.sensor for open and faulty. Clean it, and tigh the connector very well. see the diagram atached.
Aspire tredmill stops working suddenly and has err - 1_21_2013_11_18_00_pm.gif
Posted on Jan 21, 2013
3 Suggested Answers
SOURCE: tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Posted on Dec 20, 2009
ercupa190
  • 12223 Answers
SOURCE: I have a HSW1175 Hornet Tredmill which goes for 7
This conditions is abrupt shutdown of the belt as motor detect a sharp increase a drive currente and inmediately stop driving belt.Ohter situation is jammming the belt, may cause this error.Extreme care and analysis for service technician, required.
E.CUADRA
Posted on Nov 03, 2011
My Hamilton beach 40996 kettle Suddenly it stopped boiling. The on button lights up and reads temp but never boils. It worked and then suddenly stopped. Any chance this is a program problem somehow?
What a crazy over-complicated kettle!
Disc element kettles do tend to have a limited life that is a small fraction of the lifespan of standard kettle elements. The ones I have had usually only last until the guarantee has expired. To discover whether it is the kettle or the base it will be necessary to use a multimeter to check the supply from the base.
Nov 17, 2015 | Hamilton Beach Kitchen Appliances - Others
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
After being idle for a short period of time my IE stops working or works very very slowly - I have to reboot and varying error messages show usually relating to the OS
I would try using a different browser. This will show if the problem is with IE or your operating system. You should also run your Anti-Virus software, just to be on the safe side.
Aug 20, 2013 | Acer Aspire E1-571-6650 Laptop
E1 error. After 15 mins on tredmill
see the diagram. test for open or faulty. clean it and tight the connector very well
God bless you
Jan 21, 2013 | Exercise & Fitness
I have a HSW1175 Hornet Tredmill which goes for 7 seconds then has a E1 error, please explain???
E.CUADRA
Nov 03, 2011 | Exercise & Fitness
Error Message E1 Dries for 3 minutes then stops and gives the error message
E1 means open thermistor. Clean lint duct assembly and blower. Make sure you have good air stream from the vent outside. If this doesn’t help, replace the thermistor.
Oct 17, 2009 | Kenmore Dryers
Tredmill error code e1
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Exercise & Fitness Logo
60 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
