Question about Kohler 3386-6 Rialto Skylight Round Front Toilet
My kohler 2007 toilet lever came loose; want to know how the parts fit.
Toilet's serial number is ST733BMX2.
  • 979 Answers
The bolt that holds it on is a reverse threaded bolt. Retighten it going the opposite direction. This should do it.
Posted on Jan 30, 2013
bearsfan7538
  • 119 Answers
SOURCE: I have 2 K3466 model Kohler toilets and just had a
There is a volume control screw on the valves usually a plastic thumbscrew on side of valve turn clockwise until they quiet up the plumber should have adjusted that these are very tempermental toilets but when adjusted properly are excellent toilets I have 2 in my own home
Posted on Nov 15, 2009
  • 82 Answers
SOURCE: Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
Posted on Dec 30, 2009
heatman101
  • 43501 Answers
SOURCE: CAN'T IDENTIFY THE MODEL OF MY TOILET AND SEAT
Look inside of the tank the number will be stampes into the porcelin of the inside of the tank...
heatman101
Posted on May 28, 2010
Testimonial: "thank you great help Ira Beu"
  • 3600 Answers
SOURCE: How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Posted on Jun 01, 2010
  • 100 Answers
SOURCE: I have a 6 month
Toilet flush levers are always adjustable. For the most part, there are two types of chains that attach to the lever. Ball chain or linked chain. Either way, you'll see that there is a rod behind the toilet handle lever. That rod has many holes. Re attach the chain to the proper hole on the rod that makes the chain taut and not loose. Hope this helps!
Posted on Dec 04, 2010
Can i put a fluidmaster 400A in a Kohler Rialto
Save that valve... !
Use a fluidmaster (diaphram) part #242 as a replacement substitute!!
Easier than most pill bottles... !!!
(turn off the water)
The valve seems to be very thin plastic but mine lasted 20 years before needing a new diaphram. I cold hear the water going (seep. seep, seep))... and changed the flapper valve... Wrong!
I actually bought the new white plastic one to experiment on... but never got that far... Great price ($26) from Amzn (new spare... still in box)
The white VALVE (right) end of the 1068030 twists off easier ... over the top (clockwise: less than 1/8 turn... there is a little white lock bar on the very back that has to be pressed in to allow rotation).
Ignore the (blue) float lever... you wont be turning anything that far.
The expensive & unavailable KOHLER diaphram can be substituted with a $2 FLUIDMASTER #242 diaphram... available everywhere... Home Depot, ACE, General Plumbing Supply...
(Amazon = $4 +/- shipping, (local "dealer" had nothing in stock... of course)).
Kohler.com ships for a whole lot more!
Sadly... THAT very SAME FLUIDMASTER #242 will also fit in the "Kohler 703" valve everybody seems to be throwing away (the easiest valve I have ever repaired).
The GRAY "703" valve seems to be very thin plastic but mine lasted 20 years before needing a new diaphram.
That is a hard twist 1/8 turn: counter-clockwise... same #242 diaphram... 5 minute job!
Six minutes if you hold a cup over the valve and rinse it out like you are supposed to do...
Dec 03, 2012 | Kohler K-3386-0 Rialto one-piece...
The toilet tank doesn't fill up properly. I have replaced the flap several times during the past 24 months. I have come to the conclusion that the whole flushing system has to be replaced with...
Kohler toliets can be a pain to repair. I have found with them that the only thing to do with them is go to a plumbing company, take the model number with you and replace all in the inner parts to it. You will replace the fill valve and flush valve. After I do this on Kohler I don't have anymore problems with them. It should work for you, just make sure they are Kohler parts. Good Luck
Tool Belt Diva
www.toolbelt-diva.com
May 16, 2011 | Kohler Toilet - One Piece with Ingenium...
I need to replace the flapper on my kohler model 703 toilet but don't know that part # can you give that to me please.
Kohler toilets normally have the part numbers on the underside of the the tank lid. I was not able to find the 703 model listed on the Kohler sites; check under the tank lid there for a more complete model number and possibly a specific number for your toilet flapper.
Here is a fairly user friendly site with an illustrated selection of Kohler replacement parts. You may be able to match your model number or measure and visually match a suitable replacement:
http://www.toiletexperts.com/index.php?main_page=index&manufacturers_id=12&sort=20a&filter_id=2
Your other option is to turn off the water supply to your toilet; remove the flapper and pay a visit to your local plumbing supply store. In some cases you will be able to use a universal repalcement part as long as the means of attachment and the size are the same.
Feb 05, 2011 | Kohler Home
I have a 6 month old Kohler toilet that has a very loose flush mechanism handle- how do I tighten it?
Nov 21, 2010 | Kohler Home
I have Kohler toilet ...I believe it was a Rialto model....the numbers inside the tank are T33 K2402P3 ...
picture is of a kohler rialto
looks like you can get the parts or retro fit newer kohler flush parts
ring around for a plumber or kohler toilets seller that can supply kohler cystern parts
Apr 28, 2017 | Home
How do we replace the seat on a Kohler K-3386-0 Rialto one piece toilet? The screws/nuts holding the seat down are inside the toilet and aren't accessible. Is there a way to replace the seat without...
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
Oct 06, 2010 | Kohler K-3386-0 Rialto one-piece...
Tank serial # looks like this? S 00 K 4520 ...
that is a Kohler model 4520<br /> the other numbers are for manufacturer codes.<br /> <br /> is this an older toilet? Kohler discontinued that model.<br /> <br /> <a href="http://www.designtool.kohler.com/us/detail.jsp?item=9654702">http://www.designtool.kohler.com/us/detail.jsp?item=9654702</a>
Aug 31, 2010 | Cadet Manufacturing American Standard...
We have a 1.6 gallon single unit Kohler toilet that just started leaking at the top of the flushing mechanism (inside the tank). The toilet serial number is K3386DA - 20190. The flushing mechanism is...
http://www.lockeplumbing.com/detail.asp?c=Toilet%20Parts&s=Kohler&s2=Float%20/%20Fill%20Valve&sku=KOH-1068030&r1=WHE-USS25C&r2=&r3=
See if your filler valve looks like the one in the picture from the link above.
Aug 21, 2010 | Kohler Home
LOOKING FOR GASKETS & BOLTS BETWEEN TOILET & FLUSH BOX
go to any howm center, plumbing section. The replacement gasket is not the same as the original, however, they do fit. The other choice is go to Kohler resaller.
May 20, 2009 | Kohler Home
Kohler 3386-6 Rialto Skylight Round Front Toilet Logo
41 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
