Question about Vizio VO47L 47 in. LCD TV
The picture looks pinkish sreen - Vizio VO47L 47 in. LCD TV
  • Vizio Master
  • 933 Answers
Does it do this on all inputs? I had a problem like this, turned out to be a defective LVDS(cable from the main board to the t-con board)cable. To see if you have this same problem, wiggle the LVDS cable at both the main board side and t-con board side. If wiggling the cables clears up the problem, your cable is bad. They can be ordered for about $15
Posted on Jan 22, 2013
Testimonial: "Thanks for the help, it was helpful and i might need the part number for the LVDS cable to see if i can buy one."
  • baluvaga
    baluvaga Jan 25, 2013
    I did open the back of the TV wiggle some cables that run from the main board to the tv, the picture became normal but after a while it turns into a reddish or pink hue around the picture edges. I have tried the same process twice but its not getting the picture to normal. If i inrease the brightness to 100 it disappears but the picture looks bad
My picture is pinkish and glossy
If the overall picture has a pinkish hue to it and skin colors appear to have pinkish blotches. White scenes have a pinkish hue to them then it is is likely the main display board, 6871QCH029A. This board is located next to the Y sustain board. Need to remove the tv from the stand to get to the main display board. I just fixed my Z50PX2D that had the pinkish hue to it by replacing the main logic board. Check ebay for boards.
Jun 23, 2012 | Zenith Z50PX2D 50 in. Plasma HDTV
To whom it may concern, Slightly blurred red/pinkish LCD screen when camera is switched on. If I look at pic's taken before this happened they look ok on LCD screen. 1 week ago I switched the camera on...
Do the pictures still look this way when they are downloaded to your computer or just when played back on the camera screen? Was the camera exposed to high heat (like being left in a hot car)?
Mar 08, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Picture color is pinkish and out of focus
there might be a problem with ur monitor.
Step 1 - check these pics on sumone else's comp or open sum other jpegs just to check
Step 2 - If the pics are fine on sum other comp then ur monitor needs attention
Otherwise
use Adobe photoshop
adjustments ----> color balance to get rid of pink tint
Apr 05, 2010 | Canon PowerShot A95 Digital Camera
The picture-taking display is unclear and pinkish
Check if this is in all the SCN.
If this is on the printed pics also or just on the LCD.
If this is an intermittedly problem if there is a pattern in the occurance.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 28, 2009 | Kodak Easyshare M753 Digital Camera
I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
Jul 04, 2009 | Samsung Televison & Video
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
Pictures have horizontal lines and they look pinkish
Try tech support on Canon website for starters but this looks like a board fault. Depends how long you have had it. if they offer any tech help like a replacement
May 21, 2007 | Canon PowerShot A85 Digital Camera
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
Vizio VO47L 47 in. LCD TV Logo
122 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
