No signal at all
Second night this has happened in a row at about same time 9 or 10 o-clock
  • 3,904 Answers
Check the sleep timer on this. Could have a setting for turning off at a programmed time.
Posted on Jan 21, 2013
I have a radio controlled clock I bought from Aldi I cannot get the time to set from the time signal can you help please
Depending on where in the world that you are, the time signal might bot be strong enough to reach you.
Dec 18, 2012 | Watches
Second hand has stopped working. Stopped on # 11. Have tried new battery and resetting clock by reinserting battery. Sometimes second hand will work for a limited time. Clock keeps good time with hour and...
Hello
Just setup the clock once again by replacing the battery and check. If this also does not help you, the the press fitting of the second is loose. you have to open it to make it pressed firm.
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
OK.
Jul 03, 2011 | La Crosse Radio Controlled Atomic Clock
It looses time and the radio controlled feature does not bring it back to the correct time. I put in a new battery and it still happens. It is a La Crosse Technology Radio Controlled clock Model:WT-3101
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Jan 24, 2011 | La Crosse Radio Controlled Atomic Clock
I have a model CKA-1000 with the 20 ne problem. Last night I pressed the time zone button like it said in the forum and the correct time popped up. This morning, however, it was back at 20 ne. I again...
It is asking for the time signal.Try moving the clock/radio to another area in the house. The atomic clock will pick up the signal from Boulder, Colorado is on a frequency of 60 kHz. Unfortunately house current 120 volt is also 60 kHz and may be interfering with the signal.
Hope this manual will help you out solving the problem
The CKA1000 series will have same manual.So you can use this manual for reference.
Click here downlaod manual1
Click here download manual2
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 08, 2010 | Emerson CKA1000 Clock Radio
Clock keeps working plus 1 hour Lexibook RP200GB set the time but every night it resets to 1 hour ahead can't find user manual please help
Hope this helps I had same irratating problem
1. The RP200 is designed to automatically synchronize its calendar clock once it is brought within a range of 1500km of the Frankfurt DCF77 radio signal. When the RP200 is brought within this range, its auto-control mechanism will override all manual settings.
2. The clock automatically starts scanning the RF 433MHz signal after new batteries are inserted in the main unit. When receiving the RF 433MHz radio signal, the Radio Tower symbol starts to blink. A complete reception generally takes about 10 minutes, depending on the strength of the radio signal.
3. When the reception is complete, the Radio Tower symbol will stop blinking and remain solid
4. For an optimal reception, place the clock away from metal objects and electrical appliances (i.e. television, computer, monitor, etc) to minimize interference.
Notes:
• The unit will receive the RCC signals every day at 2am.
• The RCC signal can also be triggered by holding the key for 2
seconds in time mode.
• When the unit is searching or receiving the RCC signal (which lasts
about 5 minutes), none of the keys is working except the key.
• Press and hold the key for 2 seconds if you wish to stop to the
RCC signal search.
If the RP200 is brought outside the range of the Frankfurt DCF77 radio signal or if the signal is interfered, please set the time and date manually according to the instructions below. If the unit is located within the radio-controlled range, you may want to customize some of the clock settings.
Note: When no key is pressed for more than one minute, the unit returns to time mode (time, date and temperature display
World Time Clock
This function allows you to adjust the clock to a time zone. It is
particularly useful for travelers. Set the clock to the city you are located in, or to a city in the same time zone.
1. In time mode, press [MODE] twice to select the world time clock.
2. Press the key to select the city in which you are located.
3. Press to adjust the summer saving time function.
4. Press and hold [SET] to set the world time as the local time. When the local time is the same as the world time, the icon flashes.
May 15, 2010 | Toys
I just changed the batteries on my Skyscan Anavoo U Model 87700 clock and it has the wrong date and time. I even tried different batteries and it still will not work.
Successful reception of the time-synchronization radio signal is indicated by a radio waves icon to the right of seconds in the upper section of the display.
The best reception is at night and may take a few days to sink up.
Feb 13, 2010 | SkyScan 86709 Atomic Wall Clock
Canon P170-DH
for calandar
turn on.
press clock calandar button, top row second from left.
press time set button, second row from left, 3rd button from top, (has time set printed diretly above)
enter numbers, say 03 05 2009
press time set button 3 seconds
press CE/E, red key at bottom left corner.
turn on
press clock calandar button once, date will show
press clock calandar button 2nd time, clock will show
press time set once
enter time
press am/pm button (below time set)
press time set for 3 seconds
press CE/E red button to return to calculation mode
thats it
Jan 10, 2009 | Canon P170-DH Calculator
Accuwave DS Clock
The radio may not be able to get a strong enough or clear enough signal to process (night is best away from TV, computers and radios).  To regain "control" of the clock, take the battery out, wait 30 seconds and then reinstall it.  This will reset the clock.  You can then manually set the clock.
Press SET for a few seconds until the hour starts flashing in the display.  Then press the ADJUST button to set the hour.  Press SET to move to the different functions (Hour -> Minutes -> Seconds-> Month -> Date -> Year) each time using the ADJUST button to correct the setting.  Finally press MODE to exit the setting mode.
If the time zone is incorrect for your area (default is PST), press MODE to enter the Alarm Time Mode; then press SET to flip through the time zones; then press MODE again to exit.
The little "reset" is for use if the LCD display doesn't come on when the battery is changed. It doesn't affect any of the clock settings per se.
Nov 02, 2008 | Audio Players & Recorders
Can't receive atomic signal
You can get it serviced at www.casiosalesandservice.com or call them toll free 877.659.0761
Jun 03, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
SHARP ATOMIC WALL CLOCK RESET
I have a sharp 12 inch atomic clock...cant get it to reset and dont have instructions...please help
Oct 13, 2007 | Audio Players & Recorders
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
