Question about Softek International War Commander for Windows
My war comander is not work properly alway reconnect
I have good signal but always re connect
Recently replaced the driver information switches on the bottom of the steering wheel for a 03 silverado. Do I need to have something in the computer flashed to make these work properly?
Try disconnecting the battery and reconnecting it (wait a couple of minutes before reconnecting). If that doesn't work you can pick up a code reader on eBay for about $20 that will clear everything and its always good to have for those dang "Check Engine" lights
Jun 14, 2017 | Cars & Trucks
02 Buick LeSabre Ltd. Rear flashers work (blinking rapidly), front bulbs stay on, inside indicators also flash rapidly. Replaced control module under the dash. Did not help. What else could it be?
Hi there., when flashers/indicators work rapidly on the dashboard you should check whether it is the same on the actual bulds. Fadt flashing is usually a sign of a bulb failure somewhere. If everything is functioning ok externally I would consult a competent technician for a diagnosis.
Jun 08, 2015 | 2002 Buick LeSabre
Iphone 4s no network coverage at home
By no network coverage do you mean no cellular signal or can't connect to your home wifi? If wifi trouble push settings button on iphone. Select and turn on wifi. It will search for available wireless networks. Choose your home wifi, should be the strongest signal, most bars. If you don't know your ssid , look on the sticker on the modem. For instance ssid at&t 2345. Once you select your ssid you need to enter password which is also found on the sticker on modem. Enter password and select join. You should now be connected to your wifi. This will always reconnect automatically when you leave and come back home. If not wifi issue, are you just too far from cell tower to get good signal?
Sep 06, 2014 | Apple iPhone Smartphone
How to help in more wars in mafia wars
THATS BECAUSE PEOPLE HAVE THERE SYSTEM SET FOR AUTO AND THEY AUTOMATICALLY WAR HOPE THIS HELPS
Mar 31, 2014 | Zynga Mafia Wars Game
Some downloads on xbox 360 not working
please check if the game is downloaded properly and make sure that the game is not corrupted
Dec 20, 2013 | Video Game Consoles & Games
War comander suspended
my account in suspended in war commander
Feb 16, 2013 | youtube.com
Doing a job for a friend. Reconnecting all his gear to an Integra DTR-7.1. Everything works except for the surround. I can't get the rears to speak from the receiver. I have verified they work (wires...
if you have everything connected properly, then it wont necessarily utilize ALL of the speakers, unless you have a true 7.1 signal coming in. is it using optical or coaxial? make sure that the options on the receiver are set right......the rears on 5.1 and 7.1 dont work unless they are told to by the receiver....and the signal coming in from the external source ( dvd player, ps2, ps3, xbox....) tell the receiver what it is going to need, in order to utilize the full signal. everything is labeled, and it sounds like you know what you're doing, when it comes to hooking this up, which is always good. it sounds to me, like something isnt configured properly, so i would start there. it may take a while, but you get the idea.....
Sep 24, 2009 | Integra DTR-7.1 Receiver
D-Link Airplus di-524 wireless problem
Hello.
The status light is blinking in all dlink models, so that is normal.
The wireless radio issues have 3 possible solutions.
1. This model has a antenna that screws in the bnc socket behind it see if it's well screwed, or substitute it by another if 2 and 3 don't fix it.
2. On the advaced settings of the wireless configuration you have the ratio of radio broadcast from 25% to 100% check to see if it's on 100%, change channel to 11 if neer and 6 if far, make sure you have SSID broadcast enabled.
3. This models allow you to restart the AP unit and the router unit idependently, so it's always good pratice to restart your AP in the tools and system comands menu.
Hope that helps.
Feb 19, 2009 | D-Link AirPlus DI-524 Wireless Router
Can't connect in multiplayer
Opened ports 88 and 3074 on the router. Works great now!
Jan 13, 2009 | Microsoft Gears of War 2 for Xbox 360
Weak or no signal
you would need to know if the tuner is picking up analog signals in the air well( stick a wire a little bit in the tuner connection to see if channels pick up good or use an antenna , if so there should not be a problem with the cable being hooked up to it , if there is a problem even with an antenna then the tuner is bad and will need to be replaced , and the cable could have caused it to go out , but make sure that the tuner is working or not first.
Nov 27, 2008 | Televison & Video
Softek International War Commander for Windows Logo
120 people viewed this question
Top Softek International Video Game Consoles & Games Experts
James Wishart
Are you a Softek International Video Game Console and Game Expert? Answer questions, earn points and help others
