Question about Garden
Honda 4514 mower transmission locked. It will not roll in neutral, even if the transmission is released
My mower has been working great. It wouldn't go, so I released the transmission with the switch under the seat so I could roll it off the trailer, but it won't roll. The brakes seem to be nonfunctioning, too. Don't know if that's related.
  • 37 Answers
SOURCE: mower dies when i try to engage blade
Hi, what you wrote is exactly what's is suppose to do. what is it about the mower that's not doing?
Posted on Nov 23, 2008
  • 25 Answers
SOURCE: simplicity mower stalls when brake released
There is another safety switch connected to the parking/service brake. Check that one too. Sounds like its the one.
Posted on Jun 23, 2009
  • 59 Answers
SOURCE: engine dies when brake released on huskvarna model gth2548
check switch on brake
  • 95 Answers
SOURCE: engine dies when clutch brake released on husqvarna gth2548
First check the seat switch,make sure it is plugged in tightly, these plugs have a safety tab built into them that will cut the engine off if you unhook it,sometimes the plug latch pulls out slightly and this will cut the engine, There are two other switches in the system one on the foot clutch and on on the mower clutch, if you follow the white wire from you ignition switch it will lead you to both of them,check those connections also.
Posted on Jul 31, 2009
SOURCE: Murray Riding Lawn Mower won't start or move
The Drive Belt keeps coming off as soon as I engage the mower I replaced the Drive Pulley and put on a new belt but it still comes off. Any Ideas.
Posted on Aug 15, 2009
Transmission issues on a 2003 Buell XB9S Lightning.
sounds like shift lever adjustment problem
take it into a service center and have it properly diagnosed and a quote
Sep 09, 2016 | 2003 Buell Lightning XB9S
Mower wont move forward or backwards and makes a ticking noise when pushed.
Just a thought , maybe the key that locks the pulley to the input shaft on top of the transmission has sheared and the pulley is just spinning on the shaft or the key on the axle shaft that locks the wheel to the axle and that would allow the brakes not to work.
May 19, 2016 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Bike will start in neutral but is not rolling something in the rear is locked
ok- you've got an old honda dual mode transmission. It will start in neutral and will run in gear but you can't transition from neutral to gear-clutch issue,I think its a hydraulic clutch may require slave cylinder or rebuild-first check for clutch plate movement b4 rebuilding-clymers/haynes manual great investment. Next the battery: either the battery is pooched- can't hold charge or the stator/regulator is malfunctioning or has failed and your battery is the only thing powering the bike thus it runs until the battery has been used up, good luck.
Nov 09, 2012 | Motorcycles
Trans remains locked even after releasing park brake. Trans release lever for moving mower while not rumming doesn't release either.
Hi, even though you have released the park brake, it may be locked on the transmission end. Under the back of the mower on the side of the transmission you will find a short arm which the brake pedal attaches to. It is probably locked forward due to lack of lubrication. Pull it backward and it should release. It will need lubricating with crc or inox or similar until it releases freely. Hope this helps. Regards Phil
May 02, 2011 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Car starts fine. stopped at redlight, went to take off and car would not move. it's a 5 spd 91 accord. put car in neutral let go of clutch and it kills.HELP! it's like i had my foot on the brake or...
One immediate possibility occurs to me, if letting out the clutch in Neutral kills the engine - transmission failure. Locked brakes would not cause the engine to die in neutral. Your trans is siezed - so if you connect it to the engine (by releasing the clutch) it dies. Your front wheels cannot roll for the same reason.
Oct 24, 2009 | 1988 Honda Accord 4 Door
Trying to push riding lawnmower up ramps to take it to repair shop and the back wheels are locked. We can't get them to move even if in neutral. Help! Can't get it fixed if we can't get it to the shop. Too...
The brakes have locked up. Look under the right rear side of the mower, between the wheel and transmission. You should see a disc, similar to disc brake on your car but a smaller version, There is a nut you can turn to take the pressure off the brake pad. Should take a 1/2" wrench to do this.
Loosen it enough to get the mower to move back and forth then you should be able to load it up on your truck.
Sep 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Car wont roll forward or back even in neutral
I assume it's a manual transmission.
If the car will not roll backward or forward in neutral (with or without the clutch engaged) the transmission is most likely locked in two gears at the same time.
This may happen if gear selectors are excessively worn. If you are able to examine the gear selection levers external to the gearbox, ensure they are in the 'neutral' (no gear selected) position when the gear lever is in Neutral. If not in correct position, you may be able to manually reset the levers to correct neutral position and thereby unlock the gearbox.
In any case, if it's happened once, it will happen again, so get the gearbox and gear selection mechanism checked for wear or breakage.
Jul 31, 2009 | 1997 Subaru Legacy
My poulan riding lawnmower will not roll. The
Hi..my name is Keith..and it sounds like the neutral rod on the back of the mower needs to come out further to fully disengage the transmission so you can roll it..it should have an adjusting nut on the rod..and i would turn the nut in a couple of turns until the lawn mower will roll..i hope this will help..if not please write me back
Jul 12, 2009 | Garden
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
