Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite duet 410 metal wire for gasket came off
The gasket came out of line and the metal ring which goes on it came off. Can't figure out where this fits to replace it. Can you answer this and give me some sort of diagram so that I can see where it is placed?
  • 1 more comment
  • Anonymous Jan 27, 2009
    This metal wire is circular and has a 2 inch section of spring. I think it slipped out of the groove when my husband pulled a small section of clothing that was caught in the door out when the washer was in motion. At any rate, I am trying to get the sping back into what looks like the right groove inside the opening of the washer and it does not seem to want to stay. Thanks. Magpie583
  • magpie583 Jan 27, 2009
    The wire is a circular wire with about a 2 inch section of spring. It came out of its groove when my husband tugged a small section of cloth caught in the door when the machine was washing. I am trying to get the spring back in the groove and am a bit perplexed as to how it's supposed to stay there. It looks like the groove is in front of the boot, facing the door. Thanks, magpie583.
  • magpie583 Jan 28, 2009
    Worked great when I figured out how far to pull the bellows. I was trying to go too far the wrong way. With my dtr. helping we managed in just a minute or so. Thanks again. magpie583
  • 5,911 Answers
If the outer door spring came loose, the following link will explain how to reinsert it:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
The link explains the entire procedure for replacing the door bellow (rubber boot). Read line item 12 for instructions on how to reinsert the outer spring. It will insert around the door opening in a small groove around the perimeter of where the rubber door boot fits to the door frame.
What can cause this spring to come loose is over stuffing the drum to the point where items are getting caught in the door boot and pulling. I don't know if this is your situation, but offered the advice just in case. While the washer DOES perform better when more items are in the drum, resist the urge to overload.
If you still have questions, please let me know. I hope this helps you.
Posted on Jan 27, 2009
  • Jeff Rockwell
    Jeff Rockwell Jan 28, 2009
    I know what the wire hoop is. That's what I explained to you in my previous post. This is called the outer bellow clamp. It installs in the groove around the perimeter of the rubber gasket where it connects to the door frame. The link I provided explains how the wire hoop is installed in step 12. Have you tried looking at the instructions I provided you?
    President:
  • Kenmore Master
  • 2,651 Answers
Is it a metal wire connected at bottom with a 2-3inch spring???? is so it secures the "bellow to the front lip of the machine. youlll need to stretch it over the front "bellow lip after installing the "bellow"
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
F11 code on kenmore elite washer
My Whirlpool Duet did the same code over and over again. A repairman replaced the doorlock which is what the code indicates but was costly and NOT a fix. I finally sent my circuit board to CircuitBoardMedics.com cost $75 and has been running smoothly since. I figured this was the problem since when I jiggled the wiring connecting it, it would work again. There is a tutorial on youtube on how to safely remove the board. Give them a call! I dealt with my problem for 4 years by wiggling and unplugging wires wished I had found them sooner.
Nov 07, 2013 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 gas dryer, how to fix blower assembly?
take it it's a front load, well remove the top panel, this will allow you to get to the screws to remove front panel. remove bellows pad (rubber gasket around door) remove with a screw driver carefully there will be a metalic ring, remove it fold bellows pad back.Now you can remove front panel and access the blower motor
Sep 19, 2013 | Kenmore Elite HE4 Electric Dryer
The dryer shuts off, keep getting an E1 code, what needs to be done
It sounds like this is a Whirlpool Duet or a Kenmore Elite Dryer due to the error code E1 being available only on this models. The problem here is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in accessing the thermistor.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Measure the resistance of the thermistor and refer the table below. Normal thermistor resistance is around 10000 ohms (10K) at room temperature.
Replace the thermistor if the resistance is significantly higher (or lower) than what it is supposed to be based on the resistance table above. Check the wire harness connecting it to the control board, if the resistance turns out good, and make sure the connectors are good and the wires are intact. Replace the wire harness if necessary. Consider replacing the control board if both the thermistor and the wire harness turn out good. The link below might enlighten you further on the troubleshooting of the thermistor.
Thermistor Troubleshooting on Whirlpool Duet and Kenmore Elite Dryers
Aug 21, 2011 | Dryers
Dryer will not start when pushing start button it just clicks once
This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Mar 23, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My duet washer is leaking beacuse the seal is not aligned right, the metal ring that holds the seal in keeps popping ou..any advice?
Carefully pull the nozzle from the window washer tube. Separate the plastic gasket ring from the nozzle. Insert the nozzle through the hole in the boot and slide the plastic gasket ring down the shaft of the nozzle so that the boot is securely trapped between the gasket ring and the nozzle ridge. Insert the nozzle shaft into the window washer inlet tube and insert the end of the water inlet tube into the boot. Fit the boot around the front lip of the tub so it rests smoothly and evenly. Fit the boot clamp around the front lip of the tub and tighten the screw. Be careful not to over tighten this screw. Damage to the boot clamp or the boot could occur.
Jan 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The new four prong has a green, white, red, and black wires. The cord we removed is not color coded. Not sure what goes where besides green
red and black wires go to L1 and L2 power terminals and the white wire goes to the N- terminal "neutral" terminal and green is the metal unit case safety ground wire
Jan 30, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore he2 plus washer door gasket is loose.
it goes on the groove in the gasket at the door , the side view of the gasket would be a V, it goes right in the middle. make sure the gasket is first snug on the metal frame groove. the spring is very tight, start at top then work down, use a flat screwdriver to pry it in at bottom. it may help to wet the gasket
Apr 27, 2009 | Kenmore HE2 Plus Front Load Washer
Gasket replacement
The following link explains the steps required to replace the door bellow on a Whirlpool Duet:
Read through the link thoroughly. An alternate method is to remove the washer top panel and work from the top and through the door. The method I mention, offers the best unobstructed access. The placement of the wire hoop is mentioned in step 12. If you have questions, or require additional assistance please let me know.
Feb 09, 2009 | Whirlpool GHW9400 Front Load Washer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
293 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
