Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag Neptune MLE200AZW stacker-dryer sounds like an aircraft
The dryer is very noisy (squeals mostly, sounds like something with many RPM's) wondering if the wheels are worn down, if so how do you change them out? Also have had several items lodge between drum and back piece I think due to drum sagging...does this make sense?
  • 65 Answers
IT IS POSSIBLE FOR THE DRUM ROLLERS TO WEAR OUT TO THE POINT WHERE THE DRUM DROPS CAUSING A GAP THAT CATCHES CLOTHES. AS FAR AS GETTING TO THEM, ALL I CAN SAY IS START TUNNELING INTO THE MACHINE BY STARTING WITH THE SMALL PANEL UNDER THE CONTROLS THAT IS HELD IN BY TWO SCREWS. ONCE YOU GET THAT OFF, IT SHOULD BE OBVIOUS WHICH SCREWS COME OUT NEXT. THE CONTROL DOES HAVE TO BE REMOVED.
Posted on Jan 27, 2009
Dryer sqeaks while it's running
This could be the result of a loose/worn belt, or worn drum roller bearings. Is it a constant squeal or a squeak......squeak.........squeak, basically in time with the RPM of the drum? If that is the case, get new drum bearings. If the former is the case, get a new belt.
May 24, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer (MDE4000AYW) making a sorta grinding noise when the start button is pressed then the drive motor starts up & the grinding stops. It sounds like a starter or transmission problem but I...
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
May 04, 2011 | Maytag Neptune MDE6700A Electric Dryer
Maytag performa electric dyer makes dragging noise drum turns but acts like something catches and makes a dragging or scraping sound
assuming nothing is stuck around drum pull off the front and check the fan. If it is noisy for a few seconds after you stop the dryer then the fan may be stripped on motor shaft. while off you can check the front glides and the rear rollers
Nov 17, 2010 | Maytag Neptune MDE4000 Electric Dryer
Maytag MDE5500AYW 220V Electric Dryer. Makes a
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there.
Mar 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag electric dryer squeaks when it stars up and sometimes during operation.
most common causes of a noisy dryer are bad drum support rollers, a bad idler pulley or a bad blower wheel
May 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune gas dryer model #MDG3000AWW When I push the start button on my maytag neptune dryer it sounds like it wants to start but doesn't and then it gets this smell like something is burning?...
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Jan 29, 2009 | Dryers
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
138 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
