Tv shuts off once I plug cable tv up to it . - Televison & Video
    Genius:
  • 1,003 Answers
Does Tv stay on with out the cable connected?
Posted on Jan 21, 2013
My roku streaming device is froze on this blue screen and will not change?
Glenda, Are you connected to your tv by HDMI or AV cables?
The blue screen is usually an indication of one of two things.
1: The HDMI cable has come loose but not entirely disconnected (Turn off Roku and TV unplug the HDMI cable from the Roku AND Tv and reconnect them making sure to seat the ends securely and turn on TV and Roku in that order)
2: your TV or receiver may not support HDCP (a content copy-protection solution) over HDMI. This is generally true for older TV models that have early HDMI implementations that do not follow current standards. Try connecting your player with the included A/V composite cable instead.
Mar 23, 2013 | Televison & Video
Hooked up hd cable to ps3 and tv, now have no sound
Be sure to check the cables. You may need to replace them.
Try the cables with another component, if possible.
Also, try using AV cables to verify that it is not the TV and to simply troubleshoot:
To get back to default AV settings:
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until it shuts off again.
Once you have verified that AV is working, turn off console, take out AV cables.
Plug in HDMI cable and turn system back on. Switch TV input to HDMI and it will ask you if you would like to use the HDMI cables, select yes again and verify.
If you cannot get sound, again, check the cables..
If new cables do not work, then your HDMI output is going bad, not from use rather normal wear and tear of the motherboard.
To get the best non HD picture, you will need to get some 'component' cables, rather than the standard AV (red, white, yellow).
Good luck
Jan 27, 2011 | Sony Playstation 3 (PS3) Console
Why does my t.v. automatically shut off after 15 seconds?
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Jan 16, 2011 | Sylvania SRCD227 27 in. TV/DVD Combo
Just bought a stereo mini to rca cable. i have a macbook and a 32" dynex tv. I dont know where to insert the cables on the tv.
you need a mini to two rca plugs cable; once you have this: connect the red rca plug to the left TV stereo rca connector and, the white rca plug to the right TV stereo connector
and, the mini stereo plug to your speaker jack on the macbook You will now have sound.
then: connect the video to you macbook using another either s-video or, vga cable to the TV
Aug 03, 2010 | Televison & Video
Hello, I am trying to hook my computer up to my tv and I used an HDMI cable from my tv to my pc and it won't read it, unless just turning on pc or tv?
Unfortunately it's not plug and play. The system(your pc) has to be shut down and powered up in order for your pc to properly recognize your tv. Once recognized it should be good, but if the cable is unplugged then the process has to be repeated.
Mar 26, 2010 | Philips 47PFL7403D 47 in. LCD TV
Panasonic TH-46PZ85U Plasma TV All 3 HDMI was working fine with cable box, PS3, XBOX360. I used to connect my pc to the tv with a dvi-hdmi cable, but recently unplugged it. So I tried to plug in the same...
Symptom:
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
Cause:
There is an abnormal AC voltage entering the TV from one of the input cables or AC
outlet.
Remedy:
Follow the Testing procedure to determine if there is a problem external to the product.
Concept
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
protection.
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Jan 27, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
I have a Craig Model CLC501 and have to use both Comcast's control and the TV control in order to shut off TV. I have programmed everything else but can't seem to get tv to shut off with Craig control. Do...
Most cable supplies provide a switched receptacle on the rear of their cable boxes. Plug the power supply for the tv in there if you want the cable box to shut the tv off when you shut the cable box off.
Sep 24, 2009 | Craig Televison & Video
Our tv turns green and shuts off every 5 min. or so
try plugging the cable line directly into the tv skipping the cable box,then let me know what happens
May 20, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
My Panasonic TV
Many TVs, including some Panasonic models, have an Auto-OFF feature that will automatically turn the set off after a few minutes, if the TV thinks it is not receiving a video signal. By reinserting the coaxial cable, you are probably restarting the Auto-OFF timer inside the TV. There are several possible things that could cause the Auto-OFF to falsely activate. Try and change the coax cable going from the VCR to the TV, if you have a spare. If not, plug the cable from the cable box directly into the back of the TV. Make sure the TV is on the correct channel, usually Ch 3 or Ch 4. (Do not use the original cable that was running from the VCR to the TV, just in case it is intermittent.)
Sep 07, 2007 | Panasonic CT-36D32 36" TV
The TV and Cable box both continue to shut down; Please Help!!!
Do you mean that the TV shuts off and the cable box also shuts off? Is the TV plugged into the back of the cable box? This sounds to me as if the cable box is defective and the TV is plugged into the cable box instead of the power strip. To prove whether or not the cable box is defective, plug the cable directly into the TV, plug the TV directly into the wall outlet and watch one of the lower channels. If the TV acts up and shuts off, have the TV serviced. If the TV plays fine, replace the cable box.
Jul 02, 2007 | Daewoo DTQ-29S1FCN 27" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
