Question about Brembo 2000 Porsche Boxster - S - Gran Turismo Slotted Brake Kit
Porsche wont take fuel
Sometimes when i put fuel it seems like the fuel chute is closed. it spits fuel back out and i have to trickel it it there and eventualy it takes the fuel. is there a simple fix or is this a shop job?
I'd think it was a malfunctioning charcoal canister purge valve
Posted on Jan 21, 2013
What could I damage on my boat fuel line? Primer bulb, any filter ... ?
There could be several reasons. I'd first look at stuck floats in the carbs. I believe there's 3 carbs and if all spark plugs are wet all floats are sticking.
But assuming it didn't overheat, and the spark plugs are wet with fuel (as opposed to water) - sometimes a defective coil will short out only when it gets warm (most time they short all the time). They can be tested.
A very good mechanic once told me there are only four things to concentrate on: Suck, Squish, Bang, and Blow. In other words, Fuel delivery, Compression, ignition system/spark, and proper exhaust. My experience has been that I've never had to worry about Blow (knock on wood) with an outboard. Others have however.
Additional advice: The number 1 cause of outboard problems is gas. Todays fuels are great for fuel injected cars but break down sooner than old gas mixtures. Always put a fuel stabilizer in you tank. It's cheap and only takes a few ounces to protect from hundreds of dollars worth of carb work - and avoid sticky floats.
Jul 06, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
My brush stop working
Barring any electrical failure or loose plug the most common cause for the vacuum brush to stop turning is belt clogged with debris or string.
Unplug the unit and check the brush for string or debris (Hair) wrapped around the pully on either end. Clear this and check the belt to make sure it has not broken, stripped or simply slipped off. Usually the bottom plate is held on with just a few screws. Easy to remove and check Belt slipped off or stripped replace. Belt slipped off you can sometimes put back on and be vacuuming in no time.
Anything wrapped around the spindle a pair of needle nose pliers comes in real handy here. If you have snagged a rug, sheet or sock etc.. check the manual for a reset button. Some vacuums have this and all it takes is clearing the chute then resetting the switch. Good luck hope this helps!
Apr 03, 2014 | Vacuums
Belt is broken. Not sure how to replace
1. Get a long screw driver (probably phillips head) a strip of tape.
2. Look around underneath your vac for screws... look carefully because sometimes they are sneaky and hidden in weird areas like under the wheels, etc.
3. Take screws out stick them in order on tape turned upwards. (remember how you took them out.)
4. Gently remove the bottom cover.
5. Clean and remove debris, hair, dust bunnies, rocks... whatever.
6. Determine where the belt goes, disengage the beater bar on that side (may need to unscrew something) Belt on beater bar gears. Other end of belt on motor end... then stretch belt with beater bar until it fits back in it's place and replace any screws, etc.
7. Make sure the belt is seated properly.
8. replace cover, screws... test.**
** sometimes belts require that you put a twist in them so it can transition from the motor's direction to the beater bar's direction... if you twist the wrong way... the beater bar will spit dirt out the front of the vac.. (it's bulldozing it) In that case remove cover and twist the belt the other way.
Good luck.
Mar 12, 2011 | Vacuums
Vacuum cleaner not picking up and sometimes spits ouit dirt
Check to see if bag (or if not bag then chamber is full).
Check to see if filter is clean.
If your vacuum has a bag, check to see that it is properly mounted.
Sorry I couldn't be more specific but it would help if you would specify what type of vacuum you have, whether you are using the hose or just the floor part, and where it is spitting the dirt from.
Hope this helps. If not, let me know the answer to the above questions and we'll go from there. Good luck!
Mar 13, 2010 | Vacuums
While vacuuming, debris spits out the back.
that's normal. try lowering the heght adjustment
Mar 18, 2009 | Hoover U5753-900 WindTunnel Bagless...
Kenmore vacuum - no suction, brush wont turn
sounds like the vacuum is clogged and putting too much stain on the agitator, so I would clean out the entire passage way for the vacuum and replace the agitator belt, you must clean out all the hoses it is clogged somewhere
Jan 29, 2009 | Kenmore Vacuums
Kenmore vacuum- no suction, brush wont turn
Sounds to me like you have a plugged vacuum. Check all the way through.
Jan 29, 2009 | Kenmore 22812 Bagged Canister Vacuum
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Vacum will not pick up
Due to the way carpets are made - new carpets sometimes have a lot of loose fiber. This is NORMAL and it may take 3-5 times to vacuum the carpet till it goes back to normal. Spitting out fuzz balls is a bit weird. Make sure you have the belt installed right - see video on www.goodvac.com. but the fact that belts keep breaking I am assuming that you have them installed right. Give it a few more belts and if the problem presists - let me know.
Rocky
Dec 26, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Brembo 2000 Porsche Boxster - S - Gran Turismo Slotted Brake Kit Logo
20 people viewed this question
Top Brembo Vacuums Experts
JoeVacs
Are you a Brembo Vacuum Expert? Answer questions, earn points and help others
